Tigersteve
Everything posted by Tigersteve
  1. No surprises here, Erik. Another superb planking job. Well done! Steve
  2. I would suggest gently wiggling the bulkhead forward and aft while holding the keel to remove it. You need all the bulkheads square before planking. After you free the bulkhead you can gently file the excess glue and reset the bulkhead. I used Elmers wood glue throughout. It makes redoing things a lot easier. (I did this a lot!) Steve
  3. Looks like a solid start, Per. I will follow along if you don't mind. What a change in size from the longboat! Steve
  4. Congrats, Per! I have to agree with Erik. More photos needed to see the details. What's the next project? Steve
  5. Learning a lot from you, gentlemen. Erik, nice tutorial. You are helping a lot of folks. It's going to turn out great. Steve
  6. Thank you, gentlemen! I have all the plans for the rigging and layout running through my head. Needed to get a reference photo out here. I'm unsure if the rudder will be installed or stowed. I don't want to obscure the details inside the boat. The windlass handles will most likely be installed as well. The oars will need to be kept on the gallows bits. Yes, the ME line looks like a lost cause. I will use Syren rope for the Mayflower. Steve
  7. Paint touch up and refinishing some parts before stropping blocks, seizing line, and creating rope coils. In the meantime, I have been planning the layout of all parts inside and out of the boat. I took my first reference photo. All parts are not included yet. Steve
  8. I appreciate all the feedback and likes. I remade one chainplate/deadeye as I did not like how it was sitting higher than the other deadeye. Found a better way to make it by wrapping the wire around the deadeye and making the seam near the opening for the nail. Decision made about the rigging. I will present it partially rigged and lashed down (mast and oars on the gallows bits). Thank you, Cathead, for the encouragement! I think I was leaning towards this from the start. I unraveled the ME line. It seems useless for the tasks ahead. I picked up some poly/cotton thread. I'm going to get a spool of brown as well. Take a look at the line that came with the kit compared to the spools I purchased for about $1.50 each. Steve
  9. Nice! Your photos are clear. No worries. Have not forgotten about your surprise.(missing windlass) Glad you're enjoying rigging. I'm looking forward to mine as well. Steve
  10. This is really inpressive work! Steve
  11. Bowsprit step, deadeyes, chainplates installed. Needless to say it was difficult. You'll notice filled holes on the display base. No iron rings will be installed. Annoying lesson learned. Now to make a decision on the rigging: fully rigged (boat unlashed) or partially rigged with mast on the gallows bits along with oars and such stowed in the boat and on the bits (boat lashed to four eyehooks that would be installed on the base. Many rope coils will be needed. Any thoughts? Steve
  12. Thank you for the info. I will return the thread I bought and pick up some poly/cotton. I just about completed adding chainplates and deadeyes. I completed the iron rings for the display but didn't like the way they looked. Ended up filling the holes. I have to refinish it. I will post a photo of the stand and boat when that's compete. I have to adjust one deadeye. Steve
  13. Nicely done! Chuck's boats are well designed, but tricky. How long is that boat in inches? Just curious as I'm building the longboat kit, which has a length of 6 1/2". Steve
  14. I was considering that presentation as well. I'm leaning towards fully rigging her though. For now at least. I really want to lash her though either way. (Sounds terrible, doesn't it? ;-) I picked up some cotton thread at the craft store for the rigging. I may use the kit provided tan for the lanyards and grapnel coil to add some dimension to the rigging. In my head it all looks great! Steve
  15. Thanks guys! Nirvana, I had those thoughts, but I could not resist following through with this idea. Originally, I hadn't planned on planking the base. Now I must decide: iron rings or no iron rings. I'm thinking a row of 5 on each side. (Below photo shows rings dry fit and need to be blackened) Have no fear, when the oars are placed on the gallows bits, it balances the presentation. Steve
  16. The display base is inspired by the Brig Syren's longboat lashed to its deck. I used Chuck's practicum as a guide for designing the gallows bits and tried to proportion the measurements. Attached is a photo of the measurements I used. I ended up using the 3/16" planking stock from the Pinnace kit. I plan to use maple for that kit anyway. The kit supplied display board was warped and unusable so I used a 4"x8" basswood board, which was planked over with the 3/16" stock. This display will allow me to present the oars on the gallows bits. Haven't decided if I will "lash" the boat as well. I'm considering adding "iron" rings to the base/deck as well. Any thoughts?? Steve
  17. Thank you everyone for the likes and kind words! Mike, I appreciate your comments. I do a little bit of work at a time in efforts to keep it "crisp". ;-) Steve
  18. I just ordered the lamp also! Steve
