tlevine
Everything posted by tlevine
  1. And now back to building... Work continues on the rudder assembly. After all the metal work done over the last few days I can vouch for the fact that sawdust smells much better than lubricating oil. The metal work on the rudder consists of six pintles, the straps by the tiller and the spectacle plate. I made the pintles from four pieces: two straps, a pin and a center piece pierced for the pin. All holes were drilled before assembly. The joints were all silver soldered. I use a silver solder paste, which has flux already in it, and the Smith Little Torch which uses propane and oxygen for its gases. The first picture shows the pieces after they are removed from the pickling solution. The next pictures show how the pintles look after soldering and before cleaning up. Once I got a rhythm, I was pleased with how things came together. Each pintle took about an hour. The spectacle plate is on the aft edge of the rudder. Chains attach which help prevent unshipping the rudder accidentally. They were straight-forward to make. All of the metalwork is recessed into the rudder. In this picture only the recess for the spectacle plate has been finished. There is a strap above the topmost pintle but I am not sure how I will fabricate this. The circumference at this point is smaller than the head of the rudder. At this point I am leaning towards simply pinning it in place, bringing the ends together without actually joining them. I still need to clean up the metal work, finish the recesses for the pintles, make the tenon for the tiller, and finish the metalwork at the head.
  2. Michael, this one is for you! Isn't there a beer commercial with a very similar jingle? These are my display cases. They are made of mahogany left over from construction of the house. There is a can light in each bay (I think you Canadians call them pot lights). The glass floor of the upper tier allows light into the lower tier. Some of the occupants of my dockyard are Mantua's Peregrine Galley (the first POB ship I built), Mamoli's Roter Lowe, Amati's Prince (abandoned because of terrible plans), Sergal's Cutty Sark, Model Shipways' Fair American, the Lumberyard's Oneida and Mantua's Victory. Then there is my triplet of small ships, Scientific's Cutty (we're not even saying what decade that was built), Admiralty Model's cutter and Chuck's longboat. Finally, there is a small display for my other hobby. Those eggs take up a lot less room than a ship! There is a running theme with these ships. I discovered that I truly dislike rigging. I keep telling myself that I will finish the rigging on the Cutty and Victory, especially the Victory, but so far it hasn't happened. That is why I have converted to hull-only models. Sorry about the photographer in one of the pics, those mirrors make photographs difficult.
  3. Thanks, Tom. And thank you everyone for the likes. Remco, I will just have to keep your mantra in mind as I attempt the metal work..."Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime". Michael, the space is difficult to photograph because of all the reflections but when I am home and there is some sun I will give it a try. Cannot use flash because of the mirrors.
  4. The bearding line was drawn on the fore edge of the rudder and cut in with a chisel. The advantage of the 4-part rudder blade is apparent here. The junction between the port and starboard halves of the rudder make an easily followed line. The width of the bearding is narrower at the bottom and gradually increases towards the top of the rudder. The bearding stops below the mortise for the tiller. The rudder was positioned and the locations for the gudgeons were marked out. The recesses for the pintles were drawn and then cut out, leaving a little extra wood for final positioning later. The width of the rudder is the same thickness as the stern post and tapers top to bottom. I took measurements off the sternpost and drew them into the pintle recesses for easy reference. The taper was sanded. I had taken the sole plate off earlier but have temporarily replaced it so one can see the amount of wood removed. Next comes cutting the mortise for the tiller and then the dreaded metalwork.
  5. Looking good, Mike. The black paper is used to simulate felt that was placed in joints located under water. This is a thicker line than that achieved with a graphite line on the planking. Please do not use a marker unless you test it with your finish first. Many of them will bleed with solvent finishes.
  6. Druxey, since the sole plate is the last piece applied, it shouldn't be too much work to shorten it up a bit once I get all the other heights correct. Thanks, Dave. Mark, painting on paper has the advantage of avoiding uneven absorption of paint on the wood surface. Even with a hardwood like castello, there is still enough grain that I think painting on paper and then applying it like wallpaper is safer.
  7. After being inspired by Remco's build, I have decided that this is the perfect time to start building the rudder, The blade consists of two pieces which are tabled together. The top of the rudder is different on Atalanta than on other Swan class ships. The top of the rudder is stepped and the metal work is more complex. I followed the suggestion in TFFM and split the blade in the midline to form the joints. The tabling was marked out and the mortises were cut on the Preac and cleaned up with a chisel. The same black paper I used on the keel and stem was used to line all of the joints. As you can see, the two sides of the blade are mirror images of each other. The two halves were then glued together and the backing piece and sole piece were applied, again using black paper to simulate felt. The plan showed the bottom of the sole piece extending all the way to the baseline. I will shave that back a bit once the final height of the rudder is determined.
  8. Your well is a work of art as built. How could you make it any better? What finish are you using now and why did you stop using the Minwax?
  9. Greg,here is a picture of the display case. These wrap around two corners of the room. Hannah in the center of the picture with her NRG medal. To the left is an incomplete model of Amati's Prince which I started back in 1984-ish and never completed because of the inadequacy of the plans. The reflected ship is Dapper Tom. I forget which kit manufacturer. I have finished the rest of the hull friezes. Extra material was left around the quarter badge, as I am not sure how this will exactly fit.
  10. When the NRG had their annual meeting in Annapolis a few years ago there was no restriction based on citizenship. Less than an hour away is the National Naval Museum at the Washington Navy Yard. www.history.navy.mil Proof of ID is also required.
  11. Jim, Maury, Christian, thanks for the kind comments. I hope to have the frieze finished this weekend, except for the stern. I need to examine the building process to see when it would be most appropriate to install that component.
  12. Thank you Dave. Greg, I have built in display cases in my living room for all my ships. The back wall is mirrored so I can see both sides of the ship without opening the doors.
  13. Thank you everyone for your kind comments. I agree, Remco, the frieze changes the whole attitude of the hull. Druxey, I was surprised that the animate characters look cartoonish on the draught rather than realistic. However, since my drawing skills are "zip", I went with the frieze as drawn on the draught. I only hope this was not some cruel joke on the Admiralty by the draftsman.
  14. I took everyone's warnings to heart regarding the frieze and was determined to stretch some paper. I am not at home this week and therefore have no access any tools to attempt a frame like Michael demonstrated. I had been using masking tape to hold the paper and decided to try gummed packing tape, as recommended in TFFM. The local Staples does not carry it. Something about "Nobody has used that for years". I tried a series of clamps instead of tape but did not get equal pull across the edge of the paper. So, with nothing to lose but time and patience, I decided to make the friezes from the paper painted with enamel. In examining the draughts and a photo of a contemporary model of Atalanta, it appears the shear plank is much narrower than that called for in TFFM. The lower row of friezes buts up against the inferior edge of the shear plank. Consequently, the lower frieze is positioned too low and does not extend across the top of the gun port openings. This left me with four options: 1) remove the shear plank and all the planking down to the lower edge of the gun port, resizing the width of four rows of planking, 2) redraw the lower frieze so that it is 2 mm narrower, approximating the width of the upper row of the frieze, 3) keep the dimensions of the lower the frieze and install it below the too-thick shear plank or 4) skip the frieze. Well, number 1 was not going to happen and I really wanted that splash of color the frieze would provide. I felt that narrowing the lower frieze would make the decoration seem out of balance. That left me with option 3, installing the frieze below the shear plank, knowing it extends too low on the hull. After carefully examining the draughts, I did not see any problem in proceeding with this last option. After a little experimentation, the technique that worked the best for me was to cut the piece of frieze a little long to overlap the gun port openings. Next, apply a thin layer of undiluted yellow glue to the back of the frieze. Grasp the end of the frieze with a watchmaker's forceps and position the end at the edge of the gunport. Slowly place the rest of the frieze in position. Moisten the surface to remove any excess glue. Finally, gently burnish it in place with a piece of planking. This has to be done quickly because the glue is set within a minute. Once completely dry, the edges of the gun port are cleaned up with an 11 blade. The slivers of blue above the gun ports were added separately.
  15. Druxey, after reading your post I took my trial frieze and glued it to some scrap wood, expecting the worst. I used a very thin coat of full strength glue on the paper and the wood and let it almost dry before applying the frieze. No wrinkles! I think the enamel provides just enough strength to the paper to decrease the risk of puckering. The downside in using this technique is that there is no ability to finesse the location of the frieze. Remco, with your talent the friezes would be a snap. It comes down to the aesthetics, or in my case, the challenge of something new. Christian, thanks for looking in. Does Alert have any stern lettering? The same technique would be applicable.
  16. OK, Druxey, here is my step by step. I am no artist and the results will probably reflect that but so far the results don't look too bad. I made the first trial section of frieze only to discover that I painted it upside down and without enough background aft to run out to the hance of the forecastle. So I used this "opportunity" to document a step by step method for painting the friezes. For my technique I used the instructions given in Vol II of TFFM. I also had the pleasure of sitting in on a demonstration of frieze painting by David Antscherl at the most recent NRG national meeting. The first step is to have a background of the correct color. I chose a blue background although there is a contemporary model of Atalanta in the NMM holdings that has a red background. The next step I found to be the most difficult. David says to moisten bond paper (aka printer paper), stretch it gently, tape it to a flat surface and allow it to dry. Then the background is painted. The prestretching is supposed to prevent the paper from wrinkling when the acrylic paint is applied. Well... I tried three different types of paper, different moisture levels, different tape and weighting the paper under a sheet of glass. I occasionally ended up with a strip of paper that looked passable. After that I painted the paper with artist acrylics and ended up with wrinkled paper! I could not find any blue archival markers. Ink would cause the same problem. Regular blue marker would bleed when I apply my solvent based finish. I seriously thought about printing a sheet of blue paper but was concerned about the lifespan of inkjet pigments. My solution was to use enamel spray paint without prestretching. Three coats with a quick sanding of 600 grit between coats gave me good depth of color while smoothing out any imperfections in the paper. It is still flexible and accepted acrylic paints well. Although there is no freize shown on Atalanta's plans, there is one for Fly. I used these for my design. I traced the design on to regular bond paper. The plan shows the starboard side but I am putting the frieze on the port side. So I turned the paper around and traced the sketch on to the back of the paper, giving me a mirror image. The drawing was placed on the painted paper and transfer paper was used to transfer the outline. Transfer paper is found at any craft store and is used for stenciling and applying patterns onto cloth. It comes in several colors. White is best for this application. The images were painted with two coats of ochre. All the paints used were Liquitex artist acrylic. The highlights were applied with a mixture of ochre and white. The lowlights were applied with a mixture of ochre and burnt sienna. Finally details such as the stems and leaf veins were added with a mixture of burnt sienna and burnt umber. I used a pencil eraser to remove any white lines and powder from the transfer paper. At these extreme magnifications, the detail work is a little heavy. At normal viewing it looks much better; definitely better than I thought I could do.
  17. As I get ready to start the rudder on my Swan class in a few weeks, all I can say is that your rudder assembly is inspiring.
  18. An alternate option would be to purchase resharpened carbide drill bits. These have a standard 1/8" shaft that fits the Dremel collet. I would be surprised if there isn't someone in Canada you could purchase these from. I use Drill Bit City here in the states. The advantage of using a collet rather than a Jacobs chuck is stability of the bit, especially when drilling holes that need to be accurately positioned.
  19. David, John, Ben, Maury, thanks for compliments. And thanks to everyone for the likes. Nothing more will be getting done until after the holiday. The friezes are next and considering my (lack of) artistic talent, I am terrified!
  20. Remco, I cannot believe you actually simulated something. Maybe you are human.
  21. Looks fantastic. Make sure you get in there are fair the hull while there is still an opening to get your arm into.
  22. Remco, Joe, Nils and Grant, thanks for looking in. This is the first time I have used holly for lower hull planking and am pleased with its working characteristics as well as its appearance. The finish also applies nicely and dries quickly so multiple coats can be added in a single day. The only problem (other than the fumes) is that its working time is about a minute so one has to work quickly. Chris, I have thought about leaving a viewing port on models but don't plan on doing so with Atalanta. It is interesting that you linked to LGV as this is on the short list for my next build, whenever that occurs. It is too bad they did not clean up the model for the photographs.
  23. I have proclaimed the lower hull planking finished! In the end I applied three coats of sanding sealer and one coat of flat finish. This was sanded to 1200 grit. The finish coat adds luster without shine and is a harder finish than the sanding sealer. The upper planking will be finished with Watco's to match the rest of the Costello after the channels, moldings, etc. have been installed. I repainted the wale and put her back in the cradle.
  24. It does look better with the dark line. Just tell people that it is dirty!
  25. Greg, initially I was not too sure about the dead flat finish but it is starting to grow on me. The wale definitely needs more than just touching up. It is painted with dull enamel so it should be reasonably easy to control application. It will be good practice prior to attempting the friezes! And yes, druxey, I am glad only one side is planked. I never want to see another treenail again, at least until I get to the quarter deck. But seriously, leaving one side exposed gives me two models. The exposed side demonstrates just how crazy I am to fabricate all those parts and the planked side shows the beauty of her lines. The other models that I have made this way are displayed in a case with a mirror on the back wall to show both styles.
