garyshipwright
Everything posted by garyshipwright
  1. Hi Mark. Am not sure but in the AOS Bellona shows on page 65 that the sweep is set back by one beam compared to what you showing and maybe that is were the goose neck fitted on the back side of the sweep. It shows blocks further forward on the end of the tiller and looks like the tiller rope is going from those blocks, through a eyelet then to a block at the side. Finally going fwd to be guided up to the wheel. How right this is am not really sure. Will see what I come up with. I added a photo of my sweep with the rollers. You just make them out on the far right and far left side with bolts holding the rollers in place. Gary
  2. Thanks Johann and wefalck for the information and links. Will take a look. Gary
  3. Mark being able to exchange information and note's with your self and other's is outstanding and I for one really like sharing what I know to any one who is open to it. Being able to give some thing back is my way of thanking others who have given this to me.
  4. Hi Johann. Thank you for the how to post on making those tiny blocks and your work still leaves me on the speechless side. I took a look at the reference you gave on the Atlas du Génie Maritime and think am going to hang on to that one. Do you know off hand if they have published the Atlas in book form since then? Could be a good one to get. Only item I have that comes close to this is the Encyclopedie Methodique Marine, 3 vols set and 1 vol of plates. Thank you. Gary
  5. Thanks Alan for the info. . As far as being a beginner at ship modelling have a deep feeling that we are both in the same boat and learn a lot from watching your build log as many others do. Do believe you are far from a beginner good sir and thank you for helping the student. Gary
  6. Hi Alan. I noticed that you have three carlings per side from the fore hatch to the second beam aft of the stem and was wondering if this was done in Elephant's time. From what I have read in the contracts I have it would of been something like what Mark shows on his. The contracts I have says that their was only two per side from the fore hatch to the stem. They did have one in the middle from the fore hatch to the back of the fore mast partner with the carling stopping at the aft beam of the mast partner. Believe it was called the furnace/stove carling and was 12 inches wide but don't hold me to the 12 inches. This one was put up underneith those beams and believe it was set in to the beams by 2 inches. They also installed short carling on top of that long carling between the beams and filled the space above that carling. If elephant was different would love to know how they did it during her time frame. You can see that carling in dashed line running below the beams in the 6th photo in the Hector plan above. You probably already know this so forgive me if you do. Thank you sir. Gary
  7. Hi Guys do you mind if I crash the party. What you have put on the log just goes to show us that the decks were all done just a bit different and like your's self's it really hard to figure them out. On Alfred it shows that she has one center deck beam with two arms per side but the two most forward beams have the same as what you show for your deck's. Now coming up with hanging and lodging kness, now that is were the real fun starts. Am using Alfred deck plan to lay out the beams but using Hector to fill in the knee's and the way the aft part was laid out. Now on the carling and ledges am using the contract's to figure out how they were laid out. Hoping that maybe am on the right track to how they may of been done. Hay Mark, Alan your plan's of the upper gun deck is out standing but have a question and you may of already address it. Mark the carling you have forward of you mizzen mast may get in the way of the fitting's for the rudder ropes which go up to the ships wheel. When I work Alfred's out I used a x set of carlings with sheaves to guide the ropes up. Of course with out looking back am not sure if this was done the same way. Seems French way of doing this was one piece attach to the beam with two sheaves at different angles I believe. Mark when you said Conway what book are you talking about? You know me I just love books. Thanks guy for letting me in on the party😊Gary
  8. Welcome aboard good sir and your welcome with open arms.
  9. John according to Peter Goodwin the water way and the margin plank was two different pieces of wood. . The waterway was a strake of specially fashioned plank worked fore and aft along each side of the ship across the ends of the deck beams. The function of the water way was to form a watertight seal between the side of the ship and the deck. If water was able to enter at this vulnerable area of the ships structure both the ends of the beams and the ships timbers to which they were joined would become rotten. It was in the shape of a L as a easy way of looking at it shape. The margin plank ran parallel to the ships side and fayed to the waterway. The function of this was to pre vent the normal straight deck planking from being tapered to a fine angle where it met the curvature of the ship's side at the fore and after ends. The margin plank was thus fashioned to receive the butts of those planks. I added a couple of photo's showing how I did this on my Confederacy and a photo showing the Alfred. John if you put the waterway plank at the bottom underneath the bulwark planking and then butt the margin plank up next to the water way that would be my way of doing it. I am not sure but am thinking that the bulwark planking and the spirketting are the same thing. Hope this helps sir.
  10. John could you share a photo or two of you deck? It would be a big help to us to be able to help you? Gary
  11. Hi john this may help you. The drawing came from Model Ship Wright and the author was David White.
  12. Hum wait till you ask your daughter were your phone is and she tells you your talking on it. I was a bit red face over that one. Well good sir am going to hold you to that part.😊 Gary
  13. Looking good Mark and will follow along. Always nice to watch a real shipbuilder work his craft. Gary
  14. Thank you Hubac's and I do enjoy his videos. I think a beginner would be helped by watching his rebuilding the Tally-Ho project and even I have got something out of it from his rebuilding the frames to installing the beams. Thank you again.
  15. Thanks Mark it is Astonishing what they did with just a adze and a two man saw. . They were real craftmens of their time. A really good you tube video on how they did it is of Leo rebuilding the Tally ho and have enjoy watching him from the very start. Not every thing they do is just like 1760 but does give you that feeling and of course they use electrical. Now if only we can get Jim to make us one of those shipbuilding band saws that they use for building our little ships. Of course don't pay any attention to the fork lift. 😊 I think the bird is the real star and after you watch some of it am sure you would agree. 😍
  16. I have to second that druxey. Mark the stove was a real joy to build and most of the info came from Arthur Bugler book, HMS Victory, Building Restoration and Repair. It gives you the full size dimensions and with out it would have been a pain in the butt. Gary
  17. Ok guys, been looking for this term in all of my books for what it means and have come up short. It such a great term that they havn't even put it on Wikipedia but probabley show up in the future. 😲😆😜. O forgot good job Mark just love your updates.
  18. Hi Vaddoc. Nice job so far and thank you for feeling me in on your build. As far as reusing the same holes this is what I do, well at least I try. I usually us pin's to hold things together and after finally finishing the parts install treenail's/trunnels in the holes. Every once in a while I end up with a hole or two out of place but use saw dust that is the same color to fill those holes. Thanks again for sitting me straight. No worry's sir am behind you 100 percent. Helping each other is what its all about. Gary
  19. Hi Vaddoc. Just a question for you sir. Are you planning on putting filler blocks in between the frame/bulkheads. Once sanded down should give you a even better full surface to plank over. Most use balsa wood and can be picked up at hobby store's depending on where you live. Gary
  20. Hi Jim. I have a couple, but they are made of metal and was interested in the one you got. Am also thinking about modifing one of them in to something more easily gotten in to smaller places. Thank you. Gary
  21. Hi Kurt. Guess what, it showed up and for some reason I knew if I asked about it, it would show up. it did on the 24 aug. God bless Bob and wish him the best.
  22. Hi Jim. Can you give me some info on the profile tool that you show in the second photo might just have to get one. Thank you. Gary
  23. Thanks Kurt. St. Louis would be great and the others that you mention to. Gary
  24. Hi Kurt. Is there a possibility that the conference will be held on the east cost like Virginia , Florida,maybe some place like where the Constitution is in the future. Last one I went to was in Chicago and really had a good time. Thanks. Gary
  25. Hi Christian. Am not sure this will work but will give it a try. As far as any figures in a smaller scale am not sure but will check. It does seem that they have quite a few figure's to chose from but not sure on the scale. Gary
