Everything posted by Hubac's Historian
Siggi, I like the way your sheave blocks stand just proud of the surface. You have given me a very useful idea for simulating this in plastic.
In order to do something about the upper bulwark thickness, I decided to increase the sheer cap thickness by a 1/32” - about 3”, at scale. This will be your primary visual reference for the upper bulwark thickness. I thought about planking the bulwark interior surfaces, but decided it wasn’t worth the extra effort because of the way that the bulwarks join with the lower hull
- 244 replies
- heller
- soleil royal
Thanks, Michael. Kirill and Dafi are very talented, and I watch those guys as well. Nice tip on the bobbin thread. I remember when sewing stores used to be a thing, and thread was easily obtainable and discernible, in person. The other thing that I wonder about is what type of CA glue - super thin?? - and whether you wait to fix with glue until all of your lines are up and set, so that you can adjust tension. The worst, for me, is when one line going taught causes another to slack, when it shouldn’t be.
- 222 replies
- reale de france
- heller
The main thing that intimidates me about ship modeling is the rigging; in particular, neat servings, and lashings make such a huge impact on the model’s final appearance. Do you have any advice, Michael, with regard to how you first learned to approach these techniques.
- 222 replies
- reale de france
- heller
Roter Löwe 1597 by Ondras71
Hubac's Historian replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Clever sanding forms - can’t fail. -
MONTAÑES by Amalio
Hubac's Historian replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
This is an interesting presentation of sistered pairs of spindles. I really like the uniqueness of the design, and I may find a way to incorporate this into my ship’s quarter deck companionway. -
Thank you, John. It is the challenge of figuring out how to do something, and present a picture of the ship that is both functionally practical and beautiful. I am determined to show a coherent marriage of the Berain stern to these quarter galleries, in the hope (perhaps vain) that some may finally see that they have more in common, than not. It is a passionate argument that propels me forward in a way that is hard for me to explain. Yes, I will incorporate a radiant burst of sun energy emanating from all around Apollo and his horses, against a deep ultra-marine ground; this will be a nod to the artistic portraiture of this particular subject that I think will be a fitting coronation to this magnificent work of art that LeBrun/Puget/Berain evolved over time. I sympathize with you, re: Brexit. I have a hard time understanding how insular politics benefit anyone in the modern age.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
I have always thought that La Reyne was the most suitable subject for a Heller SR conversion project. The three broadside drawings of the ship, together with the survey drawing of the stern provide more than enough information to represent her with a pretty high degree of accuracy. Cedric has chosen an interesting and extremely challenging path; he is re-locating decks, guns and wales. Much of that effort is in anticipation of creating the particular head structure of these First Marine ships, which is quite different from that of the late 1680’s The head will be quite difficult to construct, given the existing Heller architecture, but not impossible. The other significant decision is whether to scrap the kit upper bulwarks, and simply construct everything above the main deck from scratch. It can be done either way, I think, but it may actually be easier to go the full-scratch route. It would be great to see where Cedric is at with all of this, but I know he is quite busy with professional and family life.
Your Katherine is the Vale portrait come to life. She is truly a remarkable achievement. Nobody “has it” quite like you, Doris. Thank you for sharing your talents, here, on MSW! I extend my sympathies to you in this sad and trying time.
- 1,035 replies
- royal katherine
- ship of the line
I understand the confusion because the presentation of the stern and quarters is so similar, among these ships, but the ship you are picturing in the post above is the 102 gun La Reyne. So, just to be clear: Almost certainly Le Terrible of 1670: Probably also Le Terrible of 1670: Possibly Le Terrible of 1670????: Definitely La Royal Therese: Definitely La Reyne: As a side note: La Reyne is the closest known corollary to Soleil Royal. Same yard, same designer, built a year apart, and only slightly shorter in length and breadth. The sheer presence of SR would have been very similar to this vessel. Perhaps, she was a little bit taller at the stern in 1670, if she carried a poop royal deck.
I realize, now, that I did not answer your question, Chris. I am not fluent in metric, so I will explain my thinking in imperial measure. At 1/96, 1/8=1’. On the lower gun deck level, the exterior planking, framing and interior planking would amount to something like 14-16” thick. When I was doing this, I used 1/8” square styrene for the lower deck ports. Strictly speaking, if the hull plastic is about a 1/16” thick (6” at scale), I ended up with 18” hull thickness, at scale. This is maybe a little heavy, but that is not so critically important at 1/96. Then, when I did the middle deck ports, I used .100 square stock. What matters is the sense of depth and the apparent graduation, in frame thickness, from the lower deck to the middle deck. Often, when I think about these issues of scale, I have Dan Pariser’s voice in my head: “if it looks right, it is right!” So, an 1/8=1’, a 1/16”=6”, a 1/32”=3”, a 1/64” is completely and utterly irrelevant! Nobody is splitting hairs beyond a 1/16”. If you want to scale interior planking, .030 would be just fine. When in doubt, go a little lighter. As for port framing... Sometime in the past year, I noticed on Andre Kudin’s magnificent Fleuron that the port sills were visible through the exterior planking. I had never seen this detail before, and so, it looked egregiously wrong to me. I also know, though, that Andre is not someone who would arbitrarily do something that wasn’t grounded in actual practice. Subsequently, I have come to understand that this is, indeed, an element of French practice; with the port sill extending over the top edge of the exterior planking, it creates a better gasket for keeping water out of the framing. It makes good sense! For all practical purposes, this would be the only visible port framing convention that anyone might represent on a model. At 1/48, and maybe 1/72, it makes sense to show this on a wooden model. However, I don’t think that engraving this into textured plastic, at 1/96 makes any practical sense; it would be a significant labor, and it would be very difficult to make it look good. As for aligning port openings with the SP plans, this is another monumental labor. I think it is useful to keep in mind that the height between decks, on the Heller kit, is pretty exaggerated; a 7’ tall person would be quite comfortable manning the guns. So, if you truly feel compelled to move port openings, then that will necessitate re-locating decks, and completely relocating the run of the wales; you will, invariably run into problems where the pre-existing kit architecture is not amenable to this kind of reverse-engineering; so, for example, your port alignment and broadside deck heights may look right, but the stern chase ports have been re-located too far up the transom and your hawse hole entries are now on the middle deck level. Maybe not exactly these problems, but something significant like that, for sure. If you choose to accept it, the beauty of the Heller kit architecture is that it is consistently wrong, in this regard, across all of the decks, and the spacing between the ports is sufficient that this doesn’t look so wrong, in isolation. It is only when you place the Heller kit right next to something credible, like the SP monograph, that these exaggerations jump out at you. Consider, also, that legions of serious model people adore the Tanneron model, as they should. Yet, many of those same are quick to point out the flaws in the Heller kit, which are real. They are not making it up. However, very few of those critics acknowledge how closely the Heller kit mirrors the Tanneron model, structurally. It is a very close copy. In my opinion, Heller did an admirable, if seriously flawed, job of reconciling all of the fragmentary primary sources for SR and filling in the blanks. The Heller Victory is still the gold standard for an accurate plastic sailing ship model, but the Heller SR is not such a poor consolation prize. SIDE NOTE: If anyone has an unbuilt Heller Victory laying around (mine is in PA, at the moment), it would be interesting to measure the distance from moulded decking ledge top to the underside of the next moulded decking ledge. There are approximately 70 years between these two first-rates, and it seems reasonable that the height between decks - even among separate nations - would not have changed much, if at all. Because the Heller Victory is based on something concretely measurable, it would be interesting to note the difference. So, I guess what I am trying to say is that struggling so hard to try and make the Heller kit conform to reality will ultimately be a frustrating experience. I think you will have more fun with this, if you embrace certain realities of the existing kit architecture. If you have simply increased hull depth, through the ports, you have done more than enough to improve the scale realism of the model, IMO.
- 244 replies
- heller
- soleil royal
that sounds like an organized way of working through the port lids.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
So, am I correct that you will give the interior the full Dafi treatment?
- 244 replies
- heller
- soleil royal
Hello, Chris! As Berain originally drew the QG, the five windows of the lower tier appear to be a kind of artifact of the First Marine design conventions. Following the early freedom and exuberance of Puget’s early work on the Monarque, the Paris, the Scepter, and other early ships, Colbert and the crown decide that they must reign all of this in, so as not to literally embarrass themselves on the world stage. Louis and Colbert are particularly concerned with how the new French fleet will be perceived by the English. By the time, the Van de Veldes are making the following portraits in English waters, in 1672, many of these ships had been cut down, their ornament reduced and their names changed. The Paris becomes the Royal Therese: Le Royal Duc becomes La Reyne: Who knows what Le Royal Duc looked like in 1668, but by 1672 La Reyne is a fairly sober looking vessel that is mainly notable for her impressive size and armament. Here, the lower quarter of a large second rate: By 1672, the open walkable quarters, on this lower tier of the QGs are now closed in. Gone, are the massive split-tail tritons supporting the open walk, above. By 1672, most French ships display this multiplicity of “windows” on the lower level. Their number varies from ship to ship, but it hardly matters from an architectural standpoint, because it is all a facade. On the other hand, as French design approaches the dawn of the second marine, there is a shift toward a more orderly and balanced presentation of the QGs. This is what we see, manifest in the QGs of the St. Philippe of 1693, for example. That Berain, apparently, chose to draw this earlier structure, in 1688/89, muddles their credibility for this later time period. This is but one example of why scholars of the period do not believe that these QGs belong to this period. It is hard not to sympathize with that point of view, however, I see too much corollary - even where others do not - with the stern ornamentation to conclude that these quarters are anything but the rightful companion to Berain’s stern. That being said, the original drawing - even if it is a facade - is cluttered and problematic. I chose to de-clutter and reinforce harmonies with the stern ornament. As for the guns, I designed this build to make it easy to install the guns after the model is complete. On the lower decks, I have installed dummy carriages that are pre-drilled and positioned to point the guns in the desired attitude: I found with my Airfix Vasa that I was constantly breaking off the gun barrels as the build progressed, which really annoyed me. Unfortunately, I will have no choice but to mount the upper deck(s) guns, as the build progresses, but there will be less to break away. For the same reason, I won’t put the port lids on until the end of the build. The model will be displayed with all guns out, and ready for action. My nod to historic reality will be that there are no bow or stern chase guns mounted.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Excellent! I just love the wood effects.
- 222 replies
- reale de france
- heller
Thank you for these highly detailed descriptions, Michael. Is the tissue you used the same as Modelspan?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
WOW, Michael - that was absolutely worth the visit! Your 1765 Victory is a remarkable achievement! Everything from the quarters to the figurehead to the masting and rigging is just extremely well done. I love your natural wood tones. This is just an excellent example of how much more dynamic and interesting the hobby becomes, when you incorporate some scratch-work into the build. I am curious to know what material you used for your sails, and what technique you employed for such realistic furls. Please feel free to post within this log. This was your first foray into that kind of build, and it came out so well because you took your time. I think, sometimes builders become intimidated by the scratch work, but there are a handful of easy to acquire skills, like scribing for example, that make anything possible. I heartily encourage everyone here to check out Michael’s Victory (see the links at the bottom of the prior page), and don’t miss out on his Heller Reale: Of course, there is immense talent, technique and skill involved, but mostly - this kind of work is the product of patience and time. Thanks for sharing, Michael!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Thanks, Michael! I am likewise enjoying your Reale; your paint effects and build-quality are outstanding. I am in the intensive phase of it, right now. Total commitment is the truth! Did you do a build log for that 1765 Victory? I have that kit in my stash and had the same idea - that it would not be crazy difficult to convert her to this earlier appearance. If no build log, can you PM me some pics, please? I would love to see that.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
