Jim Rogers
Posts posted by Jim Rogers
https://www.micromark.com/MicroLux-Micro-Sander
I use this all the time. Great little sander.
Only the parts that would get chafed, basically if a sail would rub against it, it was served.
I photocopied Chuck’s plan, cut out a strip with butts and one without butts, taped them to the planking and then used my Dremel with a # 79 bit to drill the holes . I then slipped in a piece of 10lb test monofilament coated in PVA. Took a LOT of hours.
- Edwardkenway and FrankWouts
2
When you open the dialog box there is a paper clip symbol on the left side bottom that states “Drag files here to attach, or Choose file.” The “ Choose File” option let’s you find your photos .Just click on them and they will download. When the reach 100% they show up at the bottom. Hit Submit Reply. I have a Mac and a PC should be the same process.
Look at it as a Spanish Galleon captured by the Brits and re-named. Something that happened throughout British Naval History.
If I may, no punches pulled. The Bounty is a blunt bow which would be near impossible for a newbie to build in two months and have a decent looking model that of which your gf would approve. A Vangard kit will give the results you want BUT you really need to increase your time line by 6 to 8 months MINIMUM. Good luck in which ever you choose.
- MEDDO, Ryland Craze, Jorge Diaz O and 10 others
13
Chuck that is some beautiful work. What size are the decking planks going to be? I want to mill them now.
That will be the perfect companion piece for the Winnie.
- FrankWouts and Rustyj
2
Are the panels going to be painted or stained?
Looks very time and labor consuming.
What I do is pay myself my hourly rate and determine how much I really want to do this. Break out the calculator determine I am nuts. If it is still something I just want to do I just do it.If not I buy the excellent ones Chuck offers at Syren. Just sayin’
HMS Winchelsea - FINISHED - 1764 - by Chuck (1/4" scale)
in Member Build logs for the HMS Winchelsea
How is Chapter 4 coming along?
