Jim Rogers
Posts posted by Jim Rogers
  1. 5 hours ago, James H said:
    Can you explain what you mean?
    Yes, I wrote Technical Documentation for Torpedo Maintenance. The Technical Manual would have in depth procedures whilst the checklist would be abbreviated. Example the technical manual would explain that part 15a should be installed in bulkhead 15 after removing char and test fitting. It would explain any placement processes. The checklist would say: Install 15a (para 3.1) . Using a checklist means steps don’t get missed in the verbiage.
  2. Go easy on the drill holes. The Trenails are for show and not structural. I attached a plank on each side let it dry then drilled it. This way I was looking directly at the frame and the plank. Put on a dab of diluted PVA and inserted. I used a chisel head razor knife blade to cut off the tail. Try to maintain a straight line when drilling.
