Moab
Everything posted by Moab
  1. Google Vanda-lay industry. They make a range of accessories that are used with Dremel tools...Moab
  2. If you have the space it would be great to have one sander using a rough grit for hogging material and fit the Byrnes with a fine finishing grit. I know “nothing” about motors so can someone explain why the Byrnes sander can’t be made with a different motor that will allow variable speeds?...Moab
  3. Has anyone used Vanda-lay tools and if so what were the results? Any other info is appreciated...Moab
  4. That it was a labor of love shows! Congrats...Moab
  5. Getting closer to launching in the lake. Wonderful planking. I hope those tax returns don’t get in the way of the really important things...Moab
  6. Danny; I haven’t had the pleasure of following you for too long. Is this among the most complex model you’ve built...Moab
  7. If I’m using acrylic paint are there any recipes for thinning (eg. paint, water, retarder) or is it basically trying various options...Moab
  8. I’m not an expert painter. I use thinned acrylics and brushes. The info from Vaddoc has been VERY HELPFUL. I think I may over thin the paint but I’m finally getting very good results. It takes several extra coats (5-6) but the results are great...Moab
  9. Just beautiful. I can’t quite tell if u carried the same board down on each door...Moab
  10. I'D BE TOO EMBARASSED TO DO A BLOG ON MY BUILD....BUT, I AM ENJOYING IT...MOAB
  11. Patton would be proud of your work. As usual.... the craft was obvious back then...Moab
  12. Wow! This was a long, long time ago in a place far, far away. Thanx for everyones service...Moab
  13. I'm concerned that "those moments" are happening more often. I'm starting the Planking kit in about a month or two. I hope I remember to start...Moab
  14. As usual great craftsmanship and photos...Moab
  15. Thanx for the heads-up. I’ll start mine in the next month or two and get my sanding blocks ready if I need them...Moab
  16. I guess in addition to your other specialties we should call you “hinge man.” Does your honey do list get longer because your wonderful work gives your wife ideas?...Moab
  17. I think by glueing the stanchions when did was the best way to do it. It would have saved me some time and aggrevation. Your build is looking excellent. The photos are very helpful.... I wish I had seen them before I started. Thank you for the build...Moab
  18. Looks great. Love the “Wood” story...Moab
  19. I just started building this kit. The plans appear to be excellent however the instruction booklet leaves a bit to be desired when compared to instructions from other manufactures kits. I also emailed them to clarify some details but never received a reply. You're way ahead of me so I look forward to your posts...Moab
  20. Michael; it’s an absolute joy to follow your builds. Your explanations are so easy to understand and the photos display the work perfectly. Thank you for sharing your craft with us...Moab
