src
Members-
Everything posted by src
Rich, About five minutes - depends on temperature though. Inside with the AC on you should be good. I have had it go off real fast though but that was in a very hot shop, 100 degrees+. I just do a drop or two of each bottle on some wax paper and mix well with a tooth pick. smaller batches like that will not generate as much heat so they cure a bit slower. If your asking about shelf life after opening, the kit I have here is about a year old and still good. Extreme temperatures seem to shorten the shelf life. Its not uncommon for our shop to go from the mid 30s in the winter to well over 100 in the summer and that seems to ruin the hardener, the cold especially. Again I am assuming your in A/C so that shouldnt really be an issue for you. Sam
- 1,756 replies
- constitution
- constructo
Rich, the rudder looks good. I will have to remember the scoring trick. As far as epoxy, I use something called Devcon 5 minute epoxy. It works well for me, I got it at an R/C store. I would think any good hardware store will have something also, I know the Big Orange Box store has it - Home Depot. its a 3m product at the HD. It appears Constructo uses stock hinges for their kits; yours look suspiciously similar to the hinges in my kit. I forget which book I read it in but I recall the leading edge of the rudder wasnt square - more pointed and then tapered slightly towards the stern so I would think your good with your rounding over. For the nails (actually bolts) I used some brass wire heated and peened over - very time consuming but it worked. There is a forum topic here that describes making nails that is much more efficient. I wish I read it before I made mine! http://modelshipworld.com/index.php?/topic/3315-making-small-nails-with-round-head/ Sam
- 1,756 replies
- constitution
- constructo
Yes, epoxy. Make sure the back side of your metal is nice and shiny clean also. Some alcohol to take any oils off wouldn't hurt either. The alcohol is for the oils on the metal not your skin BTW; although I firmly believe if you aren't hurting anybody, do as you will! Sam
- 1,756 replies
- constitution
- constructo
Rich She is starting to come to life. When I mounted my rudder I first mounted everything to rudder itself. Ten then I slid the rudder in place and clamped it off. Once I was satisfied with where it sat I transferred some lines to the hull and drilled a couple of starter holes for the nails. I used those predeilled holes with unglued nails to hole HOLD everything in place while the epoxy set up. Then I drilled and epoxied in the remaining nails. After all that I pulled out the unglued temp nails and glued those in. Hope this all makes sense. Sam
- 1,756 replies
- constitution
- constructo
We will all be waiting. Now, I have a whole 2 hours to play maybe i can actually get something done on my build, see ya soon! Sam
- 1,873 replies
- occre
- san ildefonso
The natives are getting restless Sjors. Wow, I carry my shield err Sherry's chair all the way over here and all I see is a messy work area! PffFF-FFt! Sorry my American accent mangled your Dutch words. I'll be patient and help (Picks up a dustpan and starts sweeping) Sam
- 1,873 replies
- occre
- san ildefonso
Great start Rich. Wow, she IS a big girl isnt she!? Sam
- 414 replies
- caldercraft
- victory
Sjors, very nice! I see you still have your IPOD on the wall...... (Gallantly takes Sherry's chair and carries it to the 'Fonz log for her while using it as a shield) Sam
- 1,616 replies
- caldercraft
- agamemnon
Rich, if the bleach doesnt work try oxalic acid - Rockler carries it I think. So should Ace Hardware or any good paint store. Sam
- 1,756 replies
- constitution
- constructo
Steve, That hull looks great! You really gonna cover it up with paint? Your build if course but it seems a shame to cover it up. Sam
- 569 replies
- shenandoah
- corel
Al, you beat me to it!! Johnny, if not Radio Shack, Freys or any decent electronic store will have them. You can even get 'em with insulation so you dont burn your fingers. Oh, umm..... wrong 'hobby" sam
Ahhh my mistake, they looked suspiciously like the parts from the enterprise, I assumed they used a similar approach by giving you precut parts that you then bend to shape. Looks like you have a plan worked out for your balancing act. Sam
- 1,756 replies
- constitution
- constructo
Rich The curve and fit looks good. Those small pre shaped parts are tough to bend I have found. I had similar issues myself. For me, in the future I think it will be easier to buy lumber and bend out of a larger piece then shape.
- 1,756 replies
- constitution
- constructo
a bigger hammer never hurts either. Looks good Rich. Sam
- 1,756 replies
- constitution
- constructo
Wow, that's a tough bend. Do you have any wider planks you can use? Then you can cut out smaller sections and scarf joint them together. Looks good when it's finished also. I ended up doing that on my enterprise when constructo wanted me to make my cap rails out of 3 pieces of 2x2 mm mis matched parts. I had to order material from hobby mill to do it though. The trim work looks good. Sam
- 1,756 replies
- constitution
- constructo
Rich, Those small boats look GOOD. great t see you building again. Sam
- 414 replies
- caldercraft
- victory
Sjors, others explained the spiling far better than I could. So I take your comment to mean Chuck recommends against spiling? And since you have narrow planks I guess you wouldnt be anyway. And now thanks to Nick I have doubled my Dutch! Pictures soon? Sam
- 1,616 replies
- caldercraft
- agamemnon
Mark, I am thinking .308 at about 250 yards. I'll bring my Proxon and we can have a "blast" I gotta agree with you on blade guards, crutches in my opinion, they make you safety lazy. OSHA disagrees unfortunately, as we just found out at work. Sam
JVO, After buying the Proxon FET I would go with the Byrnes saw if I had to do it again. The Proxon will get the job done but the setup is is pain IMHO and its not repeatable - too much slop in the "micro adjustment" knob. Others here are using a basic Proxon and seem to like it. I tried to "save" money going with the Proxon, now Jim Byrnes saw is going to cost me $300.00 more that it would have if I had just bought it first. Live and learn. Sam
Sjors THanks for teaching Bindy that word now I learn also. So if you mean it twice is it pfffffffffffs? Or Spffffffff? I had no idea that was a Dutch word. I am Multi Lingual! Really looking forward to your next layer of planking, I cant recall will they be spiled? Sam
- 1,616 replies
- caldercraft
- agamemnon
Rich pinning is the way to go I would think. When constructo mislead me on the knight heads (?) on my enterprise and I had pinned them in place. They came out but it took some work. The dollhouse supply place I mentioned is rosesdollhouse.com Sam
- 1,756 replies
- constitution
- constructo
