src
Members-
Everything posted by src
Sjors, Deck and planking look great! I think your playing games with us; the clock in one picture says its 2008! Or has Anja not showed you how to program your clock radio?? Sam
- 1,616 replies
- caldercraft
- agamemnon
You sure that's not the fabled Kraken? Sam
- 188 replies
- latin caravel
- artesania latina
Steve, Those are pretty nice little chisels. Thats how it starts, first one, then a bit more, pretty soon your on a corner with a sign saying will work for tools! The scuppers look pretty consistent in the pictures. Sam
- 569 replies
- shenandoah
- corel
Steve, Thanks for the kind words, a furniture/cabinetry back ground helps a bit I suppose. I am still stumbling through though. Would love to see more so cal builders here. Sam
- 569 replies
- shenandoah
- corel
Mark, At work we have a saying - "We do it nice 'cause we do it twice!" When it comes out better the second time it all worth it. Hhhmmmm maybe that should be my signature.... what rhymes with quintuple? Sam
Sjors, I too am a bit jealous, those look like some nice tools. And chisels! There is something about the schunk! sound of a nice sharp chisel cutting through wood that helps make this hobby what it is for me. Your work bench is just WAY too clean, I think your being too hard on the gnomes. Enjoy!! Sam
- 1,616 replies
- caldercraft
- agamemnon
Steve, Hello from a fellow So. Cal builder! I just discovered your build last night. Your walnut looks planking great. I too have a love affair with older tools. The furniture shop I worked at in the 90's (right down the road from you in Irwindale) had some great stuff including a tenoner from the 20's and an old cast iron foot operated 10hp mortiser. I will be watching and following along. You and Bindy both stay away from the fires! I was in Tujunga during the Station fore of 2008 (9?) Fascinatingly Frightening! Sam
- 569 replies
- shenandoah
- corel
Mark, you ca buy them through the link (I have never bought from that company, just the first thing that came up on Google) I have always found them in the paint dept. but sometimes they can be hard to find. OSH may still carry them. The build is under way, Woo Hoo! grabs an adult beverage and sits back to watch. Sam
Mark, Have you seen "Tints-All" in your local Home Depot or Lowes? They are small tubes of UTC. The HD here in Los Angeles carries it as well as The Do It Center. Dont know if Do It is in OR though. I have used these for stains, tinting clears for toning and color correction as well as tinting small amounts of paint. Would be an easy way for you to try umber if you wanted. http://www.highlandwoodworking.com/tints-all-universal-tinting-colorant-1-1-2-oz-tube.aspx Sam
Vivian, You dont play around, that is some fast building, and nice work-womanship also! In addition to what Popeye said about clear lacquer you should also be able to rub a too shiny finish down with 0000 steel wool, that will knock the shine back. You can also create that "You gotta touch it" glow with a bit of wax afterwards. Sam
Muzzlehead, I seem to recall that 20' is about the longest plank for this period. At 1:51 scale thats 119.5mm. There is an article in the Database about Excel for modelers that will teach you haw to build a scaling spreadsheet. On MSW1.0 there was also something called the scalinator. It may still be here somewhere, it only worked on a Windows machine and since I am on a MAC I really never had a chance to play with it. Sam
Very Impressive "Your Majesty" Its good t have the house to yourself for a few hours,I am jealous though, my stereo only goes to "11" Sam
- 1,873 replies
- occre
- san ildefonso
Rich, thank you. I noodled around with how to drill the Bowsprit also. As a rule I dont let power tools anywhere near my build; I prefer to screw things up slowly. If I recall correctly it was a couple of drill bits as well as rattail files and sand paper. I believe I used a1/8' or so drill bit, the largest that would fit in my pin vice and drilled through at the correct angle then enlarged with 3/16-7/32"(?) I think I used 3-4 bits and stopped when I was 1/32-1/16 shy of what I wanted then used a rattail file and sandpaper around a dowel to finish. I still ended up slightly off center and not 100% round. One thing I wasnt sure about was how much clearance around the Bowsprit was correct. I guessed at least a couple of scale inches as i am sure a real part would move about when under sail. Hope this helps. Sam
Rich, Thats frustrating! I have run into the same issues with Constructo on my Enterprise build. Constructo, if you guys are listening, take notes! Sam
- 1,756 replies
- constitution
- constructo
VERY impressive Sjors! I agree with Sherry, the shrouds really changes the look and character, very majestic. Sam
- 1,873 replies
- occre
- san ildefonso
Looks like they have completely redone the plans. I am off to work at the moment, if I get a few minutes before the better half and I go out for the annual "Look how much I love you cause I am taking you out on the night society says I should" date, I will look for some pictures that might help. Sam
Muzzlehead, I do not know what plans came with your kit, but in the newer kit there are two sets, #1 and #2. #2 is mostly rigging, #1 has the hull and deck information on it. At the bottom approximately in the right-middle is a section view of the upper hull, If you look carefully you will see that your first plank extends slightly above the deck; about 3mm. Then inboard of that is a second plank sitting directly on the waterway. That 6mm tall plank will end 3 mm above the first. You will alternately plank inboard then outboard till you reach the proper height. The last plank, inboard will be trimmed to the correct height, in your case it appears to be 3 mm. On the new kit the difference was 2mm. Let me know if this helps, if not I will tr to dig up some pictures of my build at that stage. I wont be till saturday at the earliest, i have a busy couple of days coming up. Sam
Vivian, Yes they can be tricky. When I made the door for my enterprise I half lapped and treenailed and the frame still moved a bit, once it was glued to the hull though it appeared to stabilize. Yours looks good though, maybe just a reinforcement on the back side? And yes, no finger dance or what I call the owie-dance. Sam
