Everything posted by Edwardkenway
I feel I'm on the homeward stretch with the hull planking now, just two bands each on port and starboard sides. I've redone the lining out to reduce the risk of ending up with a narrow plank. it all looks pretty even and symmetrical to my eyes! just a bit untidy, but I'm hoping a good dose of sanding will go some way to rectifying that. especially at the bow! Anyway, the last batch of planking is imminent, then it's onto the stern and QG's, which I must admit I feel a bit of trepidation at. That's it for now, thank you to everyone for the interest and continued support. Cheers
Best wishes for your op Mark and a good calm recovery! Sphinx is coming on despite the small setback😉
- 505 replies
- vanguard models
- Sphinx
Since building the Triton cross section, it would be something I would definitely be interested in!
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Well, with work and other pressing matters, planking is progressing very very slowly 🐌 I have two bands completed on the port side and I'm halfway through the second band on the starboard. The transition from Hull to counter has been a trial, with several planks being removed, replaced and removed again. As it stands it's not the prettiest but it is smooth. It's going to be a fair while before I can flip her right side up😊 as I've reverted to using titebond glue because I got in a proper mess using CA. Thanks for watching and the likes! Until next time, cheers.
Coming along nicely Mark! Prayers for plain sailing with your heart surgery and a speedy recovery .
- 505 replies
- vanguard models
- Sphinx
A small update, not a lot of progress. Painted the engine, the instructions say to use steel colour, I've not got steel so l used flat aluminium, with a citadel armour wash the other parts are dark iron. also made a mask for the canopy and painted the framework cockpit green first followed by sea blue I'm happy how it's turned out 😉 thanks for watching and the likes. Cheers
Thank you Denis antenna duly cut off while filler applied, dried and sanded, some minor rivet detail lost, I will try to replicate them with tiny dots of CA. The antenna was glued back. As I was sanding the filler, the wing hinges snapped, (the kit plastic is quite soft) and the outer wing sections fell off.🤨🥺 the uppermost part was carefully removed and the hinge stub drilled and a brass pin inserted and glued, a corresponding hole was done in the other part the pin pushed through and bent over and again glued. Hopefully this will give it a bit of sturdiness. Thanks all for looking in etc... Cheers
Although I have not got anywhere near doing these details yet, I have to agree with the previous comments and say go for the 10 and not going simple. For myself I'm thoroughly enjoying the challenge of Winnie and trying to create a model to be proud of!
- 1,784 replies
- winchelsea
Is this the bench? Veritas Woodworking Project Plans Veritas Workbench System Plan £9.90 (£11.88 incl VAT) These are available from Canadian Tools, Chronos Ltd uk Veritas Woodworking Project Plans Veritas Traditional Bench Plan £8.80 (£10.56 incl VAT) although there may be a delay in getting them due to supply issues because of COVID19
