Edwardkenway
Everything posted by Edwardkenway
  1. Thanks Chad, Phil,LS, Craig for the encouragement and kind words. I can't give Chucks plank bending method enough praise for making planking the bow easier!!😆👏 I'm hoping to get back into the shipyard over the weekend. I greatly appreciate the likes from everyone 👍 Cheers.
  2. Hi Gabe, my advice for what it's worth would be to construct the deck frame on the model, because I did mine on the plan and had to make alterations to get it to fit into the hull. Only minor changes but still changes. Just my opinion!😉 Cheers
  3. Welcome to MSW, being a comparative newbie myself also wrong side of 50, I don't have the masses of knowledge of the hobby that some on here have but would say go for a larger scale. Whatever you do have fun and don't be afraid to ask questions you will get plenty of help and advice from the members. Cheers
  4. Thank you I've enjoyed it immensely, it's quite a step up from a kit but gives a great sense of achievement knowing you made the components but with the added bonus of the plans already provided for you . Cheers
  5. Hello everyone, another hour or two working on the Xsection has seen the last line coiled, the gangway and ladder fitted and glued and the skid beams fitted, not glued as I don't know wether to paint them or leave them natural, but apart from that I'm going to call this finished. Once I've decided on the skid beams I will put a final coat of matt varnish on where it needs it and that's it. Thanks to all of you who followed this project which was a big learning experience for me, I must say that I enjoyed it and it has given me a taste for an attempt at a fully framed build but not yet as I have the Triton full hull and I have the Winchelsea project to do first, but I hope to do one in the future. Cheers and thank you 👍😁😃
  6. I've been following this build quietly, and now seeing this rope ladder I've got to say amazing!! Your attention to detail is incredible, you have a very fine vessel. Thankyou for sharing 😊
  7. Thanks for the likes and comments I managed an hour today and got number 2 gun rigged and fitted, next time it's flake the out haul line down and fit the gangway and ladder. Cheers 👍😁
  8. Fantastic work Craig as always, I look forward to seeing your next project 😁
  9. A fantastic job on those beam arms at that scale, I'm going to hang around for the rest of this project if you don't mind!!??👏😃
  10. Hi, decided to do a bit more work on the full build, so I've started to plank below the wales. It's working out at 18 planks so will divide it into 3 belts. I'm using this as practice for Winchelsea so there may be planks on that may be redone if I'm not satisfied with them, please bear with me. Tried Chucks method of edge bending with the two bow planks, I think by the end of Triton I will be getting it right more often.
  11. Great work on the gun barrel Phil, power to you for the others. 😅
  12. Hello, Enjoy and have fun
  13. Welcome to MSW👍😁
  14. and welcome
  15. Hello, happy new year to everyone. My first time back in the workroom since before the holidays and I had to buy some blocks from Chris Wattons Vanguard Models as my attempts were absolutely atrocious, so I took the easy route. Have finally rigged one cannon still have the other to do. The one I have done has been fitted as "run in" mainly because I found it easier to fit the tackles but also I've not seen any portrayed this way. I may be wrong and someone else has done it. I kind of like it. The second cannon will be fitted "run out " as the norm. Thanks for all the likes, comments and input from you all, it is much appreciated. Cheers 👍😁
  16. @mtaylor brilliant piece of music!!! I'd forgotten how good it was, really does compliment the build. @yvesvidal I look forward to seeing more of this!!
  17. and welcome
  18. Hi Jo, following this one as I did IL Leudo and I'm sure you'll do yourself proud again. 😁👍 Happy new year.
  19. This kit has always looked very good and it will be interesting to follow along from the start, I'm booking my place early. Looks like you've made a good start.
