Posts posted by Mahuna
Hi John. I'm going to try the rope and rings, since that's what I see in any photos I have.
- Canute, thibaultron, John Allen and 4 others
- 7
Thanks Tom and Gary. The dredges are proving to be an interesting project by themselves.
22 hours ago, druxey said:
Congratulations on that finishing touch and completion of your model, Frank. An outstanding piece of work!
Thanks Druxey. I'm very pleased with how it came out.
15 hours ago, Jim Lad said:Congratulations on the completion of your beautiful model, Frank. I, too, am looking forward to the addition of the dredges.
John
Thanks John. I've started working on the dredges and hope to have some progress to show soon.
4 hours ago, Omega1234 said:Hi Frank!
Amazing as usual!
Congratulations on finishing your model. You must be justifiably proud.
Well done.
Cheers
Patrick
Thanks Patrick. It's great to hear from you again.
- Canute, mtaylor, thibaultron and 5 others
- 8
Welcome back Patrick. I'm constantly amazed by the detail you can get into tiny spaces. Awesome!
- mtaylor, cog, popeye the sailor and 2 others
- 5
2 minutes ago, Kurt Johnson said:
You’re amazing.
Kurt
Thanks Kurt
12 hours ago, GuntherMT said:
Beautiful model Frank. Thanks for sharing your journey with all of us, and I'm sure you'll nail the dredges to finish her off!
Thanks Brian. The dredges are a little tricky - we'll see how they come out.
57 minutes ago, cog said:
Wouldn't a cloth pin with a ball head been easier?
Thanks Carl. Would have been a little easier, but I didn't have any pins with the right sized ball head. Making the balls out of Sculpy took less than 30 minutes.
37 minutes ago, HIPEXEC said:Amazing work! Your attention to detail is the best I've ever seen.
Thanks Rich .... but I told you a million times not to exaggerate!
- 5
Part 95 –Misc Small Items
Just a short post describing some of the last minor details that were added to the model:
First, Skipjacks that are fully owned – no debt on the boat – wear a gold ball at the top of their mast. I tried a few alternatives for making the ball: small beads, but these were not fully round; small wooden beads, but I couldn’t find any small enough. I finally settled for making a small round ball using Sculpy.
I rolled several balls and baked them. After they were hard and had cooled off, I drilled them to take a 1/32” rod.
I chose the one that looked most round to the naked eye, painted it gold, and mounted it in a hole that had been pre-drilled in the mast top.
The photos of Kathryn show some iron or steel rods inserted in the body of the shroud’s turnbuckles, and through the clevises at the top of those turnbuckles. These rods serve two purposes: they keep the turnbuckles from loosening, and they provide the necessary leverage when adjusting the turnbuckles.
Finally, I made some loose coils of rope to hang off the pinrails where the various lines were secured.
So Kathryn is now finished, but I still need to make the dredges. Here are a few photos of the model. I’ll need to take some “studio” shots once I’m finished with the dredges.
Thanks Popeye. Kathryn is getting pretty close to completion and I'm very pleased with her. The only complex work left is making the dredges - work (experimenting) has begun, but they will take a while.
Thanks John. Actually, the rigging is finished - only need to tighten up some of the lines. It's a pretty simple rig apart from the Lazy Jacks.
Thanks Druxey! Yeah, if I made her look like she does today, I'd have to not only include the electrical tape, but I'd need to strew lines and electrical cables around the deck. The small crew works really hard and doesn't have time (or skills, I think) to keep her ship-shape. I don't recall if I ever showed photos of what her cabin looks like today, but if not here's a few.
Part 94 –Mainsail Lazy Jacks
The Lazy Jacks for the Mainsail are hung from steel wire pendants attached at the hounds. The Lazy Jacks are interconnected via hoops spliced into the ends of the individual lines, forming what I would describe as a ‘web’ of lines, as in the following drawing from the HAER documentation and a photo of Kathryn taken in 2017.
The pendant for the model was made from 20 LB uncoated steel fishing leader, run through an eyebolt and then crimped into small loops on each end.
The eyebolt on the pendant was CA’d into a small hole bored just above the hounds on the forward side of the mast.
The installation of the Lazy Jack lines started with the aftmost line, running it through the loop on one end of the pendant, through a fairlead under the boom, and then through the loop at the other end of the pendant.
The following photo shows one of the fairleads for the Lazy Jacks on Kathryn.
Each end of the Lazy Jack line has a loop spliced into the end of the line. One loop could be spliced on the end of a line before the line was threaded through the pendant loop, through the fairlead, and then through the second pendant loop. The loop at the other end of the line could only be spliced after the line had been run through all of these points. Splicing the line when it had already been run onto the model was a little delicate. The following sequence of photos shows how this was done for the second Lazy Jack line.
First, a loop was spliced onto one end of the line. Then the other end of the line was run through the existing loop on the port side of the rear Lazy Jack.
The loops on Kathryn’s Lazy Jack lines contain small thimbles, but these would have been approximately 1/64” on the model so were omitted. (note the ‘splice’ on the loop in the following photo)
The line was fed through the fairlead on the bottom side of the boom.
and then through the loop at the other end of the aft Lazy Jack.
The end of the line was then threaded though the eye of a medium sized needle (the needle was large enough to accommodate the .016” line used for the Lazy Jacks)
The splice was made by passing the line through itself twice
and was finished off by applying a small drop of white glue and rolling the splice through the fingers for final shaping.
The use of the sewing needle made the splice strong enough to resist any pressure that would result from tightening the lines through the loops.
The forward-most of the three Lazy Jack lines was started by seizing it to the forward cleat on the starboard side of the boom, then running it through the starboard loop on the second Lazy Jack line.
The line was then fed through the forward fairlead under the boom
and through the loop on the port side of the second Lazy Jack line, and finally was tied off at the boom’s forward port cleat.
The end of this line has not yet been fully secured, since some adjustments will need to be made to get the Lazy Jacks symmetrical. The Lazy Jacks on the real Kathryn are not lined up very well, but the model’s appearance does require the lines to be pleasing to the eye.
So this where the Kathryn model now stands, with the rigging complete.
There is still some cleanup and rigging adjustment required, and some small items that need to be installed. I’m going to focus on getting all of that completed before work begins on the (dreaded) dredges.
- JerryTodd, mtaylor, paulsutcliffe and 15 others
- 18
Good point, Mark. I would think that if the lazyjacks were taut it would inhibit the natural shape of the sail when under way. The spectacle iron can be lowered to loosen the jib lazyjacks, but since the lazyjacks for the main sail don't have a mechanism to allow them to be lowered I would assume that raising the boom would allow them to loosen.
Hi Rob and Mark. Here's a description of Lazy Jacks from Wikipedia that may help:
"Lazy jacks (or lazyjacks) are a type of rigging which can be applied to a fore-and-aft rigged sail to assist in sail handling during reefing and furling.[1] They consist of a network of cordage which is rigged to a point on the mast and to a series of points on either side of the boom; these lines form a cradle which helps to guide the sail onto the boom when it is lowered, reducing the crew needed to secure the sail. Lazy jacks are most commonly associated with Bermuda rigged sails, although they can be used with gaff rigged sails and with club-footed jibs. Blocks and rings may be part of some lazyjacks.[2]
The oyster dredging sailboats of the Chesapeake Bay, bugeyes and skipjacks, were inevitably equipped with lazy jacks, as their huge sail plans, combined with the changeable conditions on the bay, made it necessary to be able to reef quickly and with a small crew. "
The Lazy Jacks on the Kathryn are rigged a little differently from the description above - instead of being "rigged to a series of points on either side of the boom" they actually loop under the boom at several points. You'll see what I mean when I rig the Lazy Jacks for the Main Sail - hopefully soon.
The Lazy Jacks for the Main Sail are left in place even when the sails are removed, whereas the Lazy Jacks for the jib are removed when the jib is removed. This is actually the main reason I put furled sails on the model - it allowed me to add the Lazy Jacks for the Jib. I felt that the front of the boat would look a little empty without them. Attached is a photo of the Kathryn with her sails removed which should illustrate my point.
- GuntherMT, mtaylor, FriedClams and 9 others
- 12
Part 93 –Jib Lazy Jacks
Before the Jib’s Lazy Jacks could be installed, the Jib Club needed to be stabilized. The Jib Club Lift was seized to the middle ring of the Spectacle Iron. The hooked Jib Sheet block was attached to the bail on the Jib Club’s band, then the sheet was run between the two blocks, up to the single block at the hounds, and then down to the starboard pin rail. The sheet was temporarily secured in place, and the combination of the club lift and the sheet stabilized the Jib Club.
The lines for the four Lazy Jacks were laid out. The aft two lines were run through holes in the Jib Club, and the forward two lines were run under the Jib and were tucked between the Jib’s wrapping line and the Jib itself – this will keep the two Lazy Jacks from moving from their locations on the jib.
Working from aft forward, each Lazy Jack was seized to the outer rings of the Spectacle Iron, and after adjusting the two sides of the line for position and tension a small drop of white glue was used on each seizing to make it permanent. (I had tried installing all Lazy Jacks at once and then tensioning them, but this was problematic – two many lines in one place).
The following photo shows the current status of the model – all Jib Lazy Jacks installed.
The next task is to install the Main Lazy Jacks – a very different arrangement of lines.
Hi Kurt. I don't keep track of hours, but I'd estimate somewhere between 1,500 and 2,000, based on a little math. Good thing I enjoy doing the work!
2 hours ago, EdT said:
Really beautiful work, Frank.
Thanks Ed.
Part 92 –Head Stay
The following is the Haer drawing of Kathryn’s rigging, cropped to show the Head Stay and the Lazy Jacks supporting the Jib. Because the Lazy Jacks are so closely associated with the Head Stay, both need to be installed while mindful of the relationship.
The first task was to develop the Spectacle Iron, which rides on the Head Stay and supports the Jib Club Lift and the Jib Lazy Jacks. This iron is fairly complex, yet is also fairly small. A jig was developed to form this iron.
The jig consists of three 3/64” brass rods set into a block of wood, along with a cap that is drilled out to fit over these rods.
The purpose of the cap is to provide a mechanism to lift the Spectacle Iron off the jig once it is formed.
The iron was formed from 26 gauge copper wire, and was then blackened using JAX Pewter Black.
The line for the Jack Lift was run through the two outer rings of the Spectacle Iron, and was then spliced to form a triangle. (The splicing method was the same used for the Reefing Tackles discussed in Part 83)
The Head Stay is attached to the upper lug of the Bowsprit Band by a turnbuckle. This turnbuckle was installed and then the steel cable (30 pound fishing leader) for the Head Stay was secured to the turnbuckle.
The Spectacle Iron was slid onto the Head Stay
and the upper end of the Head Stay was then attached to the forward shackle on the band at the mast top.
The next post will address the installation of the Jib Lazy Jacks.
Part 91 –Pin Rails
While prepping for the next rigging steps, I needed to install Kathryn’s pin rails. These are very simple – short lengths of wood attached above the shroud turnbuckles, with three iron rods in each.
The wood used is a length of 1/8” x 1/16” boxwood. The first step was to make notches the appropriate distance apart, using a small round file. Since the file is tapered, the yellow tape on the file is to keep me from making the slot too large.
The pin rail was then cut to size (4” outside each notch) and the corners rounded off.
The holes for the three rods (1/32” brass rod) were drilled slightly tight, and then were enlarged as necessary using a very small reamer held in a pin vise.
The pin rail was test fit before the rods were glued and before painting.
After the rods were CA’d to the pin rail, the pin rails were painted by holding them in a jig made from wire. The following photo shows the pin rails after they were primed.
The pin rails were painted using the Bare Metal paint previously used on the shroud metalwork.
After painting, the pin rails were epoxied to the shroud turnbuckles.
Another detail out of the way, and I’m just starting to see the light at the end of the tunnel (if I don’t think about the dredge baskets!).
- JOUFF, GrandpaPhil, druxey and 14 others
- 17
Part 90 –Jib
Kathryn’s jib has a Jib Club on the aft part of the Jib, with a Club Lift tied to the aft part of the Club. There are 4 Lazy Jacks for the Jib, and the aftmost two of the Lazy Jacks run through holes in the Jib Club.
The Jib Downhaul is run through a Cheek Block at the port side of the forward end of the Bowsprit. The downhaul is run from the block to the cleat on top of the bowsprit.
The Jib Club was made from a piece of 1/8” square stock that was first drilled for the required holes and was then rounded and slightly tapered at each end.
The bailed band for the club was made from brass stock similar to the fashioning of the bailed band for the boom.
The Jib Club is laced to the Jib via a number of grommets in the aft end of the Jib. For the model, this area was reinforced with a strip of silk span to strengthen that area of the jib, and drops of white glue were placed in each spot that the holes would be made with a small awl.
The lacing for the Jib Club is a little complicated, but the finished product is fairly attractive, in my view.
All of the lines that would be used for the Jib and its Lazy Jacks were identified and prepared.
The upper coil is the ½” Jib Halyard. Next to it is the 3/8” Jib Downhaul. At the lower end all of the lines are 3/8”, starting from the left of the photo is the Jib Club Haul; the next two coils are for the aftmost Lazy Jack which had already been run through its hole in the Jib Club; the next two coils are for the next Lazy Jack, also run through its hole in the Jib Club; the next two coils are for the remaining Lazy Jacks; and finally the last coil on the right is for wrapping the furled Jib.
The Jib was furled while still off the model, and then the Fore Stay (or Jib Stay) was run through the individual rings in the Jib after it was moved to the model.
The Fore Stay was temporarily secured atop the shrouds at the hounds.
Since the wrapping needed to be run over and under the furled Jib, two blunt needles were used to steer the line.
When the wrapping was completed it was tied off at the aft end (clew) of the Jib.
The Jib Halyard was seized to the becket on top of the single block that was seized to the head of the Jib,
and was run through the double block mounted just below the hounds,
and finally was tied off to the port mast cleat.
The Jib Downhaul was seized to the same grommet as the Jib Halyard single block, and was run through the cheek block on the port side of the Bowsprit.
From the cheek block the downhaul was run to the cleat on top of the Bowsprit.
I’m glad to finally put the Jib installation behind me. I’ll now review the remaining rigging items to determine what comes next.
- JerryTodd, Jack12477, thibaultron and 19 others
- 22
Kathryn by Mahuna - FINISHED - 1:32 - Skipjack Based on HAER Drawings
Part 96 –Oyster Dredge
Kathryn’s dredges are very similar to the dredges found on all skipjacks. They consist of a dredge body of welded steel rods, with a basket consisting of linked rings for the bottom part of the basket, and a rope net for the upper part of the basket. The basket is attached to the body via rings. The following photo is one of the better dredge photos I was able to find online.
The plans for the Willie Bennett have a very good pictorial description, including measurements, for the dredges.
My intent is to make the dredges as close to reality as possible. My first task was to determine how to make the network of rings for the basket.
The rings were made by wrapping 34 gauge black wire around a #53 drill bit – this gave coils of rings that are the correct scale dimensions.
The individual rings were cut off the coils
The rings needed to be pressed closed and straightened. This was accomplished using a pair of Xuron needle-nose pliers. In the following photo the ring on the left is as cut from the coil, while the one on the right has been straightened.
Given the number of rings involved (plus plenty of spares) this was a fairly boring but necessary task
When manufacturing the ring groups, the individual small rings were held in the miniature copper alligator clips from Radio Shack. These clips were in turn held by third-hand tweezers held in a weighted base.
I decided to use thread as the figure-eight small rings that are used to join the round rings of the net. I tried .007” thread, but this proved to be much too thick. I have some 16/0 fly tying thread (about the diameter of a thick human hair) which proved to be satisfactory.
The only problem in using this thread is that it’s so thin that it easily slips through the opening or split left in the rings. To correct this, each ring had a small drop of medium (gap-filling) CA glue applied to the split in the ring.
Each end of the thread was fed up through the pair of rings to be joined
and then down through the opposite rings.
The ends of the threads were brought up each side of the thread weave created above and tied in a simple knot.
The ends were brought down around the thread weave, and double knotted.
Finally the thread ends were brought up again and a final knot was made on top of the ‘figure eight’ configuration.
A drop of CA glue was applied to the knot to secure it, using a small pin held in a pin vise as the applicator.
After the CA dried the ends were trimmed using a sharp scalpel.
The result was a passable pair of rings joined by a “figure eight”.
I proceeded to tie a few rings together, and found that holding a string of rings required an adjustment to the placement of the holding devices.
(As can be seen in the above photo, Optivisors were a necessity for this process)
Overall, the experiment was a success.
I found that I’ll need to use something to keep the intervals between the rings consistent, and I also need to follow a better method of tying and gluing the threads to allow the joints to remain loose and flexible.
I’m fairly confident that I’ll be able to make a net of rings for the dredge basket. The net of rope or twine will also take some experimenting, but I have a few ideas of how to get it done. This will have to wait until the dredge frames and the ring nets are completed.
So, the next priority is to make the dredge frames.
Thanks everyone.
