realworkingsailor
Everything posted by realworkingsailor
  1. Thanks David I've just finished serving a replacement shroud, and I'm waiting for the acrylic to dry. That stuff is great to use on rigging.... I highly recommend it for anyone. Not only good for dealing with fuzzies, it has provided extra reinforcement for my knots and servings, and when I pulled the shrouds off, all the loops at the top have held their shapes... (But nothing is too stiff or brittle either!) Andy
  2. Yup... Seems the consensus agrees with me..... In another manner of speaking....I'm not crazy Thanks for the input, and Sjors, thanks for that quantifiable answer... Andy
  3. Ok... back to the task at hand.. or rather.... what I intended to do yesterday... I had started work on the mizzen shrouds and I got about this far. Things were going well, but I had to pause for a moment. I'm wondering if the deadeye lanyards are a bit too long. I'm not adverse to redoing the shroud if the expert opinions deem it so (it is only one pair so far). I've only secured the forward lanyard with a single half hitch so undoing it won't be much of a challenge, and neither will be remaking the shroud again... Let me know what you all think.. Andy
  4. Sherry, Mobbsie and Eric, a copy will be forwarded to you shortly Andy
  5. I have actually sounded with a leadline... It's not easy from a moving ship. You have to hurl the lead far enough ahead that by the time it reaches the bottom it will be abeam of you... Not an easy thing to judge... A wonderful little (sort of) project Andy
  6. I'd stay away from number 4.... That cross grain could be nothing but trouble. Number 2 doesn't look too bad, but as far as colour goes, I would have to agree with the crowd on number 3. Andy
  7. What a monster ship... but she looks really nice. Can't wait to see her all finished. I can understand the delay in the update... you had to entertain a pair of lost Netherlanders... Andy
  8. Eric, the spacing was needed because of the size of the gears. they where the only ones the hobby shop had on hand, so to avoid rapping my knuckles on the spindle I needed to add a bit of spacing. Larger gears would eliminate the need for the idler gear. Kevin, according to TFFM 4: The middle quarter of a pair of shrouds is to be served. (for example, my mizzen shrouds are approximately 15 cm, x2 means 30cm total length, so a quarter of that is 7.5 cm). Also on the fore and main masts, the leading shroud is supposed to be served its entire length, but whether I do that or not is still up for debate. Robbyn... ok... I wasn't sure, have a nice trip and good luck at the hobby shop. Patrick, thank you very much for the compliment, let me know if you want my more complete instructions Anyway.. I hoped to have more done today, but a phone call first thing this morning (not work BTW) had me dashing up north... seems our lake rose 2 feet overnight and a few things where in great peril of drifting away, namely the dock boards, and needed to be rescued. We got off pretty lucky... a few people at the south end of the lake are going to have problems.. they left their boats on mooring lines a bit too short... and as the water rose... well... the lines got tight and well... they're now the proud owners of outboard submarines.... Andy
  9. Not my original intention... And I firmly believe that when it comes to these sorts of things, I usually only get lucky once... So mass production is out of the question... Although I did PM Robbyn something that might pass for instructions, I may have her scared off making her own as I haven't heard back as yet... Andy
  10. Ben... Haven't tried that.... Yet... Hmmm...... Popeye.... Hobby shop... If you don't have a model train store, try someone who deals with RC stuff... Andy
  11. I heard about this yesterday at the hobby shop. Needless to say, the model railroad community will be up in arms over this, since the majority of Floquil and Polyscale products are geared to railway colours. Andy
  12. Thanks guys! And what's more, I've wasted little time in using it. And it's more than up to the task. Just to prove it, the mizzen shrouds
  13. Herding spiders? You got some sort of 1:64th Rawhide thing goin' on down home? Looks great Andy
  14. Yeah, nice job so far.... A couple odds and ends to adjust on my build and I'll be following along with my shrouds too.... Andy
  15. Well... I'm feeling pretty proud of myself right now... my machine works like a charm! The basic structure is made out of 0.080" Styrene sheet. It is 3" wide and 7 1/2" Long. This allows about 6" of line to be served at one time, and is within the structural limits of styrene. It's probably at the small end of things, but it's big enough for me. I managed to get the gears at no cost (one of the benifits of being friends with the hobby shop manager ), and the total cost is well below the $20 limit. There's not much point in going into gear spacing, because it will all depend on what size gears you get. Mine are all drive gears from model locomotives, around 3/4" nominal diameter. To space them out, I added two middle idler gears. The shaft size of the end gears was 5/32" and the idler was somewhere around 2.5mm, which I drilled out to 1/8". This allowed me to use standard styrene stock rod and tubing for the gear axles. The end plates are 3" square, and the gears are lined up 3/4" below the top edge. I made a gearcase cover over the idler and spindle gears, both to keep them in place and keep the rope from getting caught. The structure is all glued together with Tenax plastic glue, and the gears are held in place with a bit of CA. If anyone wants further instructions, just PM me.. Andy
  16. I think I was browsing around there at some point in time... Not sure if it really registered or not... Anyway... I'm going to test my machine soon so sometime in the next couple of hours look for an update.... Andy
  17. Hate to say it, but Chester looks a little clubfooted for those waterskis... You might need someone with more... dainty feet.. Andy
  18. Wow... That is really nice. I love how you've managed to make her so colourful without being overwhelming... And the bolt detail on the hull is incredible. Andy
  19. Well... I've completed a prototype...I'll test it in the morning and if all goes well, I'll share the results of my efforts. Andy
  20. Hah! Tell you what... If this works... I'll post the parts list and instructions for free... Andy
  21. Well, a model train store (especially one that does repairs in-house) is usually well stocked with gears and brass tubing and a few other odds and ends. I don't expect to spend much more than $20 on parts.... I'll let everyone know how it goes... Andy
