Everything posted by Kevin-the-lubber
I am now more or less back to where I was before the mini-catastrophe, which led to me remaking virtually everything apart from the winches and pump. Along the way I managed to get hospitalised with pneumonia and pleurisy, which I'd mistaken for COVID, and then get COVID itself just when I thought I had pretty much recovered! Fortunately work has been very good, giving me plenty of time off to recover. Anyway - I learned that, if I printed the deck much thicker i.e. about 5mm, I could make the joints all but invisible, plus the deck itself became pretty rigid, with just enough fore to aft flex for the job at hand. So, that's what I've done and this is still a 6 or 7 piece deck (I forget which now) with negative plank lines, printed on a filament printer, then glued and sanded to the desired finish before painting. Not dead smooth, the very slight roughness from sanding gives an impression of grain. Glue-ing the main deck into the hull, and pulling the hull tight. I used slow-setting epoxy for the deck to hull as I couldn't afford any errors here. As the new deck is 5mm thick it is quite robust and better allows cinching the hull up tight. For newbies like me, note the anchor chain in situ, needs to be done before glue-ing the deck. Here, you can see the 3D printed pin rails with lozenges, and the bulwark stanchions, which are just some 0.8mm evergreen. I've also gone for a much more grey deck colour scheme this time and used that throughout the quarterdeck and cabin roofs. I have to be honest, there's a good side to the model and a not so good side, where some of the lozenges are slightly warped. That will get completely hidden by draped ropes etc down the line! Another major milestone (for me) - glue-ing on Radek's (HisModel) very beautiful PE nameplate. I had no dramas with this, used thick CA as the tube of CA gel I'd bought especially two or three weeks back had set solid in the tube! As the weather here has been boiling hot for weeks, all glue seems to set in a nano-second, consequently the nameplate is ever so slightly off centre but not enough to matter. Although affixing the nameplate went fine, it took me forever to finish painting the hull, especially the white rail. Along the way I re-made the stern railing, added a pair of fairleads into the stern bulwark and the same into the railing. Difficult to see in these pictures is that I reduced the height of all three cabins by about 2 or 3mm. This goes some way to countering that the deck is about 4 or 5mm too high. I also did away with the open doors in the main cabins. I felt they didn't really add much and made things more complicated. Part of the reason for the major remake was that I wasn't happy with my colour scheme. This is a reminder of what it basically looked like; more oak than teak. I found a very good tutorial for painting a teak effect on a model railway site https://www.lner.info/forums/viewtopic.php?t=13594. This method uses a scarily orangey-brown base, as shown in the first two pictures below, then a burnt umber oil-paint wash to get the tint, with gloss varnish in between and on top. Base coat: a mixture of Vallejo Bright Orange 70.851 and Orange Brown 70.981, with a very light wash/highlighting using Golden Brown 71.032. I learned to go very easy on applying all of these, less is more. And also to go super easy on the varnishing, I just gave the objects a single light coat of no-brand gloss enamel spray. Topped off with burnt umber oil paint, mixed with Liquin Original. It took me two attempts to get the effect I wanted. I was too heavy handed first time round, especially with the in-between varnishing and objects had a dark, clumpy look that lost too much detail. I liked this method, you have all the time in the world to play with the oil coat but I'll want to practice more with the base coat tint in future. The trouble with glossy teak is that it can look pretty orange and garish in certain lights. And the trouble with going to all this trouble in the first place is that it can all still just look like a streaky brown paint job and not hugely different to the effect I used to get with enamel paints when I was 13 or 14 yrs old 😞 Beauty is in the eye of the beholder, and all that ..... Along the way I finished off a few other significant 'design' changes. I re-modelled the foredeck on Campbell, means it comes down the main deck a bit more and, to my eye, accentuates the sharpness of the fore section. I beefed up the winch, as the kit part was underwhelming and, once I've put the hatch covers back, this is probably how I'll have the chains i.e. suspended above the hatch. What I've ended up with is not particularly true to the ship, it's more of an impression of things. I still have a bit of work to do in this area, need to make the rails, stanchions, pin rail etc. Another area of change was the quarterdeck. There didn't seem to be enough room between the wheel and cabin so I made the cabin a bit smaller. I also tilted and re-profiled the wheelhouse, and made the skylight much lower, with the louvres rather than glazing. Another view of the quarterdeck cabin roof area. I should probably colour the louvres brass or gold, will leave that for a day when I'm feeling brave. This time round I've made the binnacle even smaller as it previously still looked disproportionately large. I'm not going to include the storage barrels, I didn't like these and, as they were not part of the 'built-in' hardware I feel it's fine to leave them off. I have other ideas for this space if the mizzen doesn't fill it up. I still need to make brass portholes for the cabins and railings etc. One of the plank ends 'lines' here is a joint between two deck sections, the other line is false, just printed into the section. The central hold will be partially open like this, showing wool bales. The loose plan is to have another bale being lowered into the hold via the rigging, or something like that. This is a complete fiction and a nonsensical one, as I doubt they would have ever only partially opened the hold nor stacked the covers like so, but for me it adds interest and, as I've said before, I'm not at all pursuing verisimilitude. Last but not least, a random photo which might be of benefit to others; my bowsprit was slightly warped and I found a bit of 3.2mm square evergreen fit perfectly in the hollow, allowing me to clamp the two halves true when glue-ing.
- 444 replies
- Cutty Sark
- Revell
Thanks Steve. I may pick up on the Victory again in a few months time, once I've reached a natural break point on the Cutty Sark. I just hope I haven't forgotten too much!
You’re very welcome, they don’t look too bad either. I wondered afterwards if it might have been better to just have small pilot holes in the drum, and drill them out later.
- 460 replies
- Finished
- Flower-class
Yep, slippery slope. It's worth the first month of pain if you foresee yourself using it a lot, otherwise stick with TinkerCAD, which is quite under-rated in my view.
- 536 replies
- Quadrireme
- radio
Ian, have you thought about sticking a notice up in your local hobby shops, for someone willing to resin print bits for you? There must be plenty of people with printers who’d be happy to do it for a nominal charge. I don’t know how big those bits are, they look quite small, and the cost to make 100 should be little different to making one. Most of the ‘cost’ in 3D printing is in developing the object and setting it up to print correctly. While resin is not cheap, if these are as small as I think, it’s only a few dollars worth. Looks like you’re using my old friend Tinkercad? That’s what got me going, 2 or 3 years back…….😀
- 536 replies
- Quadrireme
- radio
After the earlier discussion about the anchors I was wondering how they got brought inboard; there’s the answer.
- 481 replies
- Cutty Sark
- Revell
You guys are creating the must read, fully illustrated guide to building this kit to a high standard. I know that when I go back to it, this will be the key reference. In fact I’ll most likely be using this for rigging the Cutty too, at least as a sense check.
Pausing on one model was one thing (Victory), if I paused on this one I doubt I'd ever finish either. As I'm doing a fairly major remake I'll save posting until I'm back where I'd got to.
- 444 replies
- Cutty Sark
- Revell
3d printing process
Kevin-the-lubber replied to henrythestaffy's topic in 3D-Printing and Laser-Cutting.
I think you can attach any kind of file you want. After months of failing to achieve dead straight edges on, for instance, large box-like shapes, I think I’ve finally worked out the (obvious) solution. I tilt the object on two axes, Z And X or Y. This means there is never a straight edge parallel to the build plane. It means more waste as the supports are longer, but it works. -
Wefalck, I think you've highlighted some of the small errors I'm making that gradually add up to an almost but not quite right end result. Because I used maybe 5 or 6 colours, ranging from light sand to very brown, the differentiation is a bit too much. I'm glad you've pointed towards using lighter shades, that confirms that I'm starting to logic it out as that's what I'd decided for the next try. One thing I hadn't yet worked out was blackening the lines, but you may have handed me a solution via the gloss varnish. That wouldn't have occurred to me, I've just used matt all the way. Mine is a 3D printed deck and the lines are 1mm deep x 0.2mm wide grooves. I'm thinking a black-grey straight-from-the-tube acrylic or oil paint might fill them nicely and allow me to wipe off the excess to get crisp lines. I experimented with brushing graphite powder into them but that didn't work that well. I'll experiment some more. The Cutty's deck is/was teak, but very bleached and silvered. While I very much like the teak colour that I've been getting on the cabins with inking, I might skip this on the deck now as it does darken everything. I don't mind spending time on painting - for me it's the most enjoyable part of modelling, so long as it goes well.
DocRob, Wefalck, you've both given me something to chew on. Here's the paradox - as this is 1:96 I don't really want grain texture, only the effect. Wefalck, I'd looked at yours previously and did something very similar on mine. The result was quite good but quite a bit too dark. I've realised that was me using too many different colours from the vallejo old/new wood kit and when I re-do this, I'll just use 2 or 3 of the lighter colours, mixing to get slight variations in shade. I also finished mine off with some brown ink, partly to accentuate the plank lines but also because it does weird and wonderful things on the surface that hint at grain. Subsequently, this week in fact, I played around with washes to lighten and weather the result. This is where I'm still lacking confidence (aka don't really know what I'm doing). The wash itself 'flattens' the surface and negates the inking. I think it's probably the case that I just need to keep experimenting, including applying different wash shades selectively rather than across the whole deck.
I sometimes get the email notification but can’t find the post itself, and just assume the poster deleted it. Regarding the natural light photos, it makes it look even more like timber, though I still love the riot of colour in the lit shots.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
That makes a lot more sense. The chain in question is a skinny little thing and I couldn’t see that lasting long in a rough sea. Nor the ship for that matter, with the anchors able to move. I hear you Rob and know that’s good advice. For me, it’s finding the balance between, at the end, feeling this was a decent effort or feeling a bit disappointed and not even worth putting it on the windowsill in my workshop. In a perverse way, finding this site is the worst of blessings: once you see what people achieve here it’s all but impossible to just build from the box.
- 481 replies
- Cutty Sark
- Revell
I have thought about it, quite a lot lately to be honest, but haven't really got the hang of it. If you're reflecting on my build log and the lack of texture on the deck, this is because I start with a dead smooth surface, and that's a problem. If I had a little texture the variations in tone would be working better, especially washes. At the very least the light would pick out highlights and shadows. My washes tend to come out flat i.e. I can get the silvered wood colouring, but once you stop believing your own projection, it really just looks like a flat, thin coat of greyish paint. What would be a good way to add texture right at the start, that will then be used to bring out highlights etc? I almost bought some oils today as I know these sit on the surface more, but I've never used them. I should have mentioned, I currently only use acrylics and some inks, though I did find some watercolour pencils in a drawer today, which might come in handy. But I only want the tiniest bit of texture in terms of thickness. Any suggestions? I was also going to try the opposite, roughing up the surface with some coarse emery cloth or suchlike. Re' stripping, I thought as much.
That's true enough. For that matter, you'll find thousands of back street blacksmiths dotted all over Asia & Africa. And the skill level and ingenuity can be mind-blowing. I once had a labourer (we were constructing a training centre) present me with the most beautiful pair of handmade shoes.... not for wearing as they were wireframes, without a sketch or last in sight... and they fitted extremely well.
- 481 replies
- Cutty Sark
- Revell
Apologies if this has been covered ad nauseum elsewhere but can I ask a newbie question - is there a way for me to remove just the wash layer on a large, flat painted plastic object (cutty sark deck), all of which has been painted using vallejo acrylics? Or is it all or nothing? The wash is on top of humbrol matt acrylic varnish.
I feel another trip to Greenwich coming up. Despite taking a lot of photos, few of them cover the parts that currently puzzle me, including that chain. I've added rear bulwark fairleads on mine, just underneath the rail fairleads.
- 481 replies
- Cutty Sark
- Revell
Going back to that chain for the anchor, Bruma did a short thread a while back that has an excellent real life photo, search for ‘Cutty sark anchor” or something like that. To my great surprise the chain does go over the rail. I’d have thought this would see it saw through the woodwork in no time at all as, no matter how tight it’s rigged there’s bound to be some movement while out at sea. At the very least I was expecting to see it run through a fairlead in the bulwark and one on the rail. The jib boom guys look excellent to me. I have no idea if they are rigged correctly but it looks convincing!
- 481 replies
- Cutty Sark
- Revell
I’m kind of in the process of re-grouping, figuring out how far back I ought to go. One of the fundamental mistakes I made was making and painting the decks and cabin roofs at different times, so there is a little bit of variation in colouring, especially as I did a bit of diy colour-mixing along the way. I’d have lived with it but as I do have to remake the quarterdeck assembly, I’m looking at achieving a more uniform colouring. Also the greying of the decks - experimenting with additional washes at the moment.
- 444 replies
- Cutty Sark
- Revell
June is not going very well on a few logs! I hope that's repairable, there's a lot of rigging there.
My mother was sent across to England from Ireland at 13 to work as a domestic. I doubt my grandfather even went through school - on my mum's birth certificate, his occupation was given as 'peasant'. Me, I started work at 16; looking at my 17 yr old daughter, I think the world will be lucky to see her start before about 30 🙄. There's progress for you. (I'm being a bit unfair, she's the apple of my eye).
- 481 replies
- Cutty Sark
- Revell
