AnobiumPunctatum
Everything posted by AnobiumPunctatum
  1. Thank you, Druxey. I will follow your advice and modify my drawing. Your input is the reason, why I post my drawing, because I am sure that there are things which can be done better. And so I am very happy that you show me possible improvements,
  2. Thanks for the hints, Druxey. I found this solution for the stem joints at a contemporary drawings of HMS Cheerful, 1806. Do you think that the drawing has there a mistake? I will change the numbers of joints at the keel.
  3. My new keel drawing is finished. Next I will draw the frames and build the new bigger version of my keel
  4. Daniel asked me to show how I get the different center points and radii for the construction of an frame. Please be in mind that there are a lot of other steps necessary before you can start with the frame construction. First let me refer to two articles which I think that they are very helpful in understanding the lines of an original drawing 1. David Antscherl: Understanding Eighteenth-Century Admirality Drafts, Nautical Research Journal Vol. 52, No. 2 Summer 2008 2. David White: Understandig Ships' Draughts, Model Shipwright No. 48 ff. I made some screen shots during the construction of the main frame of the cutter. After creating the "Breath Extreme" line in the Body-Plan, I define the Center Points for the Lower Height of Breath. Next I determine the radii of the arcs, which don't have the center points in the original drawing (most of this arcs were drawn with French Curves). The list gives the different values: Lower height of breath: 72.53 first: 260.35 second: straight third: -319.9 Next I calculate the center point of the first curve: I draw an arc with the radius 260.35 from the endpoint of my help line and a radius from the center point of the lower height of breath withe the radius 260.35 - 72.53 = 187.82. Then I draw a line from this center point to the center point of the Lower height of breath and stretchit to the circle of the Lower height of breath. Now you can draw a circle with the first radius. Now I repeat these steps for creating the center point of the third curve. I draw to circles with the determined radius, one from the keel and one from en point of the help line. Next I draw a straight line to both circles. There exist an Autocad function to do this, so nothing to construct for me . At last I draw the frame. I start at the Lower height of breath. Then I draw the upper height of breath and complete the frame with the other arcs and straights. I hope that this small description is helpful for someone.
  5. Really wonderful. Can you give some descriptions, how do you paint the frescos?
  6. Antony, I found your log today. Your section looks really wonderful. I love these big scales
  7. @Antony Thanks for the info. @Daniel I've scanned the NMM-drawing and work with the digital copy in Autocad. There I can take the measurements of all lines much easier than by hand. Also it's possible to get the information of the radii of the different curves. Be aware that the original drawing has some distortion which you have to calculate out. The diagonal and horizontal lines in the half breath except the breath extreme line are the result of the construction work in the body plan. There I use splines. All curves in the body plan are arcs with tagential transition. I will try to describe what I did, but it's not so easy to do in English. So please give me bit of time.
  8. As written in my last post I bought last month the design drawing for Alert/Rattlesnake at the NMM. With my new knowledge about reconstruction of a line drawing I started to redesign the ship on basis of the NMM drawing. For this I did not use any information of Goodwin, because it's not a primary source. I don't have access to the archieves so I will only use the NMM drawing and later the vademecum for the scantlings. I am not sure if I like to show my model as designed and shown on the drawing or as shown on the Marshal painting. Both presentations have the same origin: they should show the design for a ship to the people who allocate the funds. The drawing isn't finished but I like to hear your meaning about the the reconstructed lines: It#s my first reconstructed ship, so I am not sure if everything is right.
  9. Congrats for reaching this milestone. Your model is looking really nice.
  10. There are some very interesting items on the agenda.Damned that Germany is to far away from St. Louis
  11. Christian, as Mark has written, you can follow Goodwin in this detail for your model
  12. Really wonderful windlass. This is one very tricky part and you make to look it so easy.
  13. Andy, the kit and most models of this beautyful ship are based on drawings from Höckel or Quinger. Quinger published a book in the 70th of the last century. I don't know if there exist an English translation of the book.
  14. Jack, I found your log today and will follow your build with great interest.
  15. Dan, really nice progress on your masts. It's allways a pleasure to follow your fantastic log.
  16. @Rich, I fixed the broken picture links. Hopefully all pictures are now visible again. @all Sorry that I didn't make an update for a long time. Sometimes real life lets not really time for modelbuilding. In the moment I am waiting for the original plan of the Rattlesnake which I ordered at the NMM. There are a lot of details where I am not happy with my design which I made on basis of the AotS book. Last year I traced the lines as described in an article of the MSW database. But meanwhile I learned a lot about doing an new reconstruction on basis of an original drawing. This I will try to do for the cutter after the original drawing arrived. Perhaps one of our admins can change scale in the title, because I like to build the model in 1/32. The bigger scale gives me a lot more possibilities for makeing the klinker planking. At last I have a question: Roger Cole refers in his article about his model on an article which was published in Nautical Research Journal Vol 29, Number 4 December 1983: Kingman, Irving H: Modeling HMB Cutter Alert - 1777. Perhaps someone can help me with a copy. Thanks.
