Posts posted by vladislemm
- BobG, Roger Pellett, bruce d and 8 others
- 11
- Ryland Craze, yvesvidal, BobG and 8 others
- 11
18 hours ago, BobG said:
Beautiful planking job! What are the dimensions of this model?
Cutter dimension: length - 359 mm, width - 92 mm, нeight - 141 mm (with flagstaff)
- Keithbrad80, BobG and JpR62
- 3
- Keithbrad80, BobG, JpR62 and 6 others
- 9
On 12/25/2020 at 10:26 PM, Keithbrad80 said:
Do you know the reason behind diagonal planking? Was it stronger somehow? Horizontal planks give the ship strength and rigidity, I’ll assume diagonal planks do the same, but what was the specific reasoning behind diagonal planks?
It is designed for covering the hulls of boats, which should have the greatest transverse and longitudinal strength.
55 minutes ago, BobG said:
The planking is very beautiful and very unusual. Was this method of planking actually used on the original boats?
Yes! Laying the planks on the model completely repeats the real prototype - two layers, the first diagonal, the second longitudinal.
Below is a drawing from a similar steam cutter.
- Ryland Craze, G.L., Ron Burns and 1 other
- 4
- bruce d, G.L., Ryland Craze and 7 others
- 10
- JpR62, Ryland Craze, pwog and 4 others
- 7
On 12/9/2020 at 4:20 PM, shipman said:
Then there's these.
'LS MODELS'
'MASTER KIROBEL'
All three do a good range of small boats.
1: 72 and 1: 100 scales are very small for such boats.
On 12/7/2020 at 5:35 PM, shipman said:
Welcome from Yorkshire, Vladislav.
Your cutter looks like an interesting and unusual subject.
I'm fond of the small boats, from any era,
I really like steam and rowing cutter and longboats, and it is a pity that there are not enough wooden kit models in this direction.
15 minutes ago, Roger Pellett said:
I assume that the “James White System” refers to the diagonal planking. It will be interesting to see how how this works out at scale. On the real thing, diagonal planking was used to allow wooden boats normally kept out of the water to be launched as necessary without first having to have the planking swelled up. To help this, white lead or a waterproofed fabric membrane could be applied between the two layers.
Yes, this steam cutter has 2 layers of planks: diagonal and longitudinal. Both layers will be present in the model.
- Ron Burns, KentM, Organ tech and 8 others
- 11
28-foot Steam cutter on the James White System (1876) by vladislemm - Piroscaf & Co Scale Models - 1:24 - by Vladislav Lemm
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by vladislemm
Continue planking the hull inner space.
