Posts posted by Glen McGuire
@Chief Mark Thank you so much, Chief.
- mtaylor, Canute and FriedClams
3
Do you have a picture of the effect you are trying to get? In the first pic below, you get the overall impression of parallel lines from a gentle breeze, but the lines themselves are not so uniform.
Personally, I really like what you did in the bottom right corner. I think that looks quite realistic so close to shore in a somewhat confined area like a shipyard. Just my 2 cents though.
- Canute, gjdale, Keith Black and 9 others
12
Welcome to the best site on the whole interweb!!
- mtaylor, Knocklouder and Keith Black
3
Work on the hull continues at a snail's pace. Shaping the hull is the part of the build I struggle with the most. I have a hard time getting the contours right and then getting them symmetrical on both halves. I know when the ship is in the bottle, you can only see 1 half at a time, but I still want to get it right, or as close as I can within reason.
The first couple of pics are what I'm trying to mirror. I'm using @Ian_Grant's plan for the Trireme Olympias as my guide for the ship's basic outline and profile. I know Ian said it was a Greek trireme and not a Roman one, but at my SIB scale, I don't think there's a material difference in the outline and profile. The 2nd pic shows the 7 "layers" of the hull that I will construct.
Layer 1 - bottom part of hull that sits mostly below waterline
Layer 2 - lowest oar deck (flush with bottom part of hull)
Layer 3 - spacer (I think it's more of a decorative line than actually part of the hull structure)
Layer 4 - middle oar deck (protrudes out from main hull profile)
Layer 5 - upper oar deck (protrudes out like middle oar deck)
Layer 6 - slanted roof (extends back to main hull profile)
Layer 7 - deck
Using my usual laminated hull construction process, here are my corresponding layers 1 thru 7 from bottom to top. Respective thicknesses from layers 1 - 7 in mm are: 2.5, 1.5, 0.5, 1.5, 1.5, 1.5, 0.5. Add a 1.5mm bulwark for a total of 11.5mm and I should have plenty of room to add the bow and stern decorative upsweeps and still easily fit inside the bottle opening.
One thing's for certain though. I will have to split the hull and rejoin inside the bottle to accommodate for the outstretched oars. All 180 of them!
Still got a way's to go on the hull construction, but slowly getting there.
This is a very unique and interesting project. I had not heard of the term "Trajinera" but I believe we have very similar vessels on the Riverwalk in San Antonio, Texas just a little ways down the road from where I live in Austin. I've only heard them called riverwalk barges and they are used for sightseeing and dinner/drink cruises through the middle of downtown (1st pic below). The also have riverwalk parades (like for Día de Muertos) with elaborately decorated barges (2nd pic). Next time I'm down there I'm going to ask if they are modeled after Trajineras.
The craftsmanship on your Tranjinera is superb. And the lively colors you've chosen really bring it to life. Well done (so far)!
- yvesvidal, mtaylor and JacquesCousteau
3
I totally agree with wefalk on adding some texture to the water. You've got so much incredible and realistic detail throughout the diorama, to me it just would not look right with glass smooth water.
I have done the same thing that wefalk describes with acrylic gloss medium and a brush. I use the gloss gel because it adds a shine like sun hitting the water. It's transparent so I have applied it directly over my blue epoxy resin water. Here's the product I use.
Another option (I have not tried it yet) was covered by @hollowneck on his NRG workshop presentation a couple of weekends ago about adding water to dioramas. For calmer water, he has a technique using diluted white glue and single-ply tissue paper to add some slight ripples. I will likely try this on my current project. Ron's Camilla build log also gives a detailed description of the process here:
Thank you, Gary! Glad to have you on board.
In the meantime, I did a search of the entire website to see if "iguana snot" had ever came up as a topic for discussion in the history of MSW. Thanks to @Ian_Grant, I can proudly say my build log has the distinction of being the first one!
Now, back to a far less interesting topic - the build. When @Javelin asked earlier about the orientation of the water in the bottle, it made me realize I needed to make a jig to figure out what my maximum ship dimensions could be. Normally, it's easy and I do it with an empty bottle. However, with the water in the bottle at an angle, the available space is different and I need to make sure I know how much room I've got to work with from back to front and top to bottom. The "test water" in the bottle below is a special flavor of Mountain Dew called "Liberty Brew" made for our upcoming 4th of July Independence Day.
Originally, I was estimating a ship length of 3.75" which is how I came up with the approximate scale of 1/450 given the reported 45 meter length of a real quinquereme. However, with the orientation below, the length of my ship needs to be 3.5", giving me a new scale of 1/500. From the quinquereme illustrations I've found, I estimate the mast height at about 40% of the ship's length, so that would be only 1.4". I've got 2.25 inches of room inside the bottle at the point where the mast will be, so I've got plenty of room there.
- GrandpaPhil, mtaylor, Bryan Woods and 9 others
12
8 hours ago, Ian_Grant said:
By the way these iguanas get rid of excess salt intake by sneezing it out when lying in the sun on black volcanic rock on land to warm up again.
Those are amazing pictures, Ian! Sounds like an incredible trip. Thanks for sharing.
However, I guess now you are telling me that in addition to seagull poop, I need to add some iguana snot to my seawall for added realism???
- Canute, Ian_Grant, FriedClams and 5 others
8
23 minutes ago, BANYAN said:
Mark, best ask the 'war' dolphins
sorry Glen high-jacking your great build yet again.
I've heard of War Pigs (Ozzy Osborne - 1970), but not War Dogs or War Dolphins. So Mark and Pat, please take the hijack further and explain!
- mtaylor, GrandpaPhil, FriedClams and 3 others
6
The biblical fishing boat came out fantastic! Congratulations to your younger daughter on her work of art!
And the birthday cake is just epic!! I would've had a hard time cutting that up to eat.
- O.B.one, mtaylor, GrandpaPhil and 1 other
4
14 hours ago, Javelin said:
Penguins are seabirds...
Might as well add some too, for realism
After @Knocklouder & @BANYAN's seagull poop suggestions, I knew it wouldn't be long till we got to penguins! 🤣🤣
So I did a little more research and found out that Archimedes' first line of defense was actually an army of penguins protecting the wall!! Who woulda guessed??
- Keith Black, mtaylor, FriedClams and 8 others
1
10
Thanks to all for the likes and comments.
6 hours ago, Louie da fly said:Black stones are ok for Armenia, but for Syracuse, limestone is right.
Thank you, Steven. I was hoping I had guessed right!
4 hours ago, Javelin said:Or perhaps a greenish sheen near the bottom?
I like that idea. I'm thinking something along the lines of the "rising damp" that @gjdale did for bottom of his fence on his Shipyard diorama.
4 hours ago, Javelin said:The stones really look like they are made of limestone rather than "painted" in lime....👍
Thank you, Javelin. That is exactly what I was hoping to accomplish. If I was in a hurry, I would not have used this process as it was very time consuming. But the extra time was worth it to get the right look.
- Keith Black, Knocklouder, mtaylor and 2 others
5
Welcome, Igor!!
- mtaylor, Ryland Craze and Keith Black
3
On 6/22/2023 at 7:45 AM, Canute said:
Hope the recovery of your S.O. is progressing well.
Thank you, Ken.
Now it's time for the real work on the seawall - turning it into a limestone fortress! Limestone is very prevalent around here and is used in a variety of ways on many houses and buildings. I found a house down the road that had a look I wanted to mimic. The blocks are primarily white but there are random orangish blocks scattered lightly about (the orange coloring is caused by an impurity, iron oxide, present in some limestone).
Borrowing again from @gjdale's “chalk method” of adding color and texture to objects, I ground out 3 piles of limestone dust of different shades. Next, I mixed the limestone dust with Gesso into gritty pastes (thank you to @Landlubber Mike for introducing me to Gesso during my Oseberg/Kraken build). Then I spread it on the surface of my clay bricks, working my way from bottom to top, adding slight variations in the whitish color to most of the blocks and random orangy to a scattered few.
After completing the limestone "veneer", I had to figure out what I wanted the top of the wall to look like. I decided a castle-like top similar to my siege picture would look good and be simple enough for me to handle. I did add a thin overhanging layer and then large blocks on top.
And here's the completed seawall below. @Knocklouder said if I wanted to make it more realistic, I needed to have bird poop splatter on top. But as the new emperor of Syracuse, I designated the airspace above my wall a no-fly zone and instructed Archimedes to aim his death ray at any birds that get too close. There will be no bird poop on my seawall!!
1 hour ago, Javelin said:
Would also hardly be visible inside the bottle I guess.
Half the stuff I make for my ships is hardly visible inside the bottle as well. But we know they are in there and that's what counts!!
So is the Stevshark anchor the giant rusty thing hanging from the boom (circled in red below) and the nautical anchor the one I've circled in yellow?
- mtaylor, Keith Black and Canute
3
4 hours ago, gjdale said:
rising damp
I had to google that one. Such a subtle effect, and very nicely done, Grant.
There is so much going on in the overall diorama. I think I could stare at it for an hour and not catch all the detail. Incredible!
7 hours ago, Ian_Grant said:
I think standard tile grout may be better as your wall mortar than caulk.
Well, Ian, you may be right. But as the Toby Keith song says, "It's a little too late..." Plus, I wouldn't know what to do if there wasn't a bunch of muss and fuss! 😃
Next is adding the top and then the limestone dust to make the all of them look like limestone blocks.
22 minutes ago, Ian_Grant said:
There are a few drawings of Roman types at the following:
Ah ha! If you look at the the quinquereme in my powerpoint concept drawing at the start of this log, you will see that I grabbed the quinquereme pictured on the website you reference!! Very helpful site indeed!
- Canute, GrandpaPhil, mtaylor and 2 others
5
Congratulations on a superb build, Mark! So well done.
I greatly admire your perseverance and I join you in your toast with a Texas margarita (or 3)! 🍹🍹🍹
1 hour ago, Ian_Grant said:
I have many more detailed drawings of her if you are interested, but for SIB this might suffice.
Thanks, Ian! The sails and rigging shown will be particularly useful. You are correct about that being sufficient for SIB. That's about as much detail as I would ever need.
- Canute, mtaylor, Keith Black and 1 other
4
1 hour ago, GrandpaPhil said:
I have a plan from the French Ministry of Defense for a Roman Trireme, drawn in 1861, in .tif format if you would like it.
Hey Phil, I would love to see the plan! Especially since all I've got to work with is a few google images.
- Canute, Keith Black, mtaylor and 1 other
4
HMS Revenge 1577 by GrandpaPhil - 1/64 - CARD - from Victory Models Plans
in - Build logs for subjects built 1501 - 1750
Hope you don't have allergies, Phil. I hate to think what a hard sneeze might do to your pile 'o parts!! 😃
