Posts posted by Glen McGuire
Welcome aboard! Your username reminds me of a really poor joke I heard the other day: Two robbers were robbing a liquor store when one robber grabs a bottle and asks the other robber "is this whiskey?" The other says "yeah but not as whiskey as wobbing a bank". Sorry! 😁
- ccoyle, mtaylor, Keith Black and 1 other
- 4
The axles have a collar and linch pin on each side that keeps the wheels (trucks) in place. For the collars, I took some brass brads, folded them around the axle, then drilled holes for the linch pins. For the linch pins, I’m using finishing nails since their head is similar in shape to what I see in the real pictures.
For the trunions, my toolbox sacrificed a 6” long 3/8” socket extension. Unfortunately for it, it was the perfect diameter that I needed. The grommets on the end (which will rest against the bottle) are hard rubber dampeners from my dirt bike handlebars. Nothing is off limits when you’re scrounging pieces and parts!
Next up, figuring out how to make the capsquares.
- BANYAN, GrandpaPhil, Ian_Grant and 3 others
- 6
I am making slow progress on the carriage hardware – slow because it takes me forever to figure out what to use and what to do. I spend a ridiculous amount of time fiddling around with a whole bunch of different things trying to find something that works.
The carriage has 2 tie-bolts with square heads that run the width of the carriage and protrude through countersunk holes in the side brackets. The front tie-bolt goes thru the transom and the rear supports the stool bed. To make the tie-bolts, I took a 1mm thick metal strip, cut it into 4mm x 4mm squares and soldered them onto the head of a common nail.
There are 6 joint bolts that go thru the steps on top of the side brackets and 2 joint bolts that go thru the front bumper. I’m using some small nails with rounded heads for those. Mine are just for appearance as I am not pushing them all the way through.
- GrandpaPhil, Ian_Grant, mtaylor and 3 others
- 6
Thank you, Pat! They help distract from all the flaws in my ship build! 😃
- Keith Black and mtaylor
- 2
21 minutes ago, Landlubber Mike said:
Hey Glen, I'm in for another great ride if you'll have me.
Hey Mike, I'm thankful to have you checking in on me. You always offer great ideas and insight which help make my builds better. For instance, I remember in your Charles Morgan log that you were using different woods for their natural color rather than staining or painting. I really liked that idea and it's one reason I wanted to go natural with the wood for this carriage.
8 minutes ago, Keith Black said:Glen, super carriage, it looks really nice.
Thank you, Keith!
I finished all the woodworking for the carriage. This was definitely harder than I originally thought it would be! Just looking at carriage pictures, it seemed like a simple build. But when I got into the details, there was quite a bit more to it. I could probably say the same thing about my ship modeling in general!
One thing I learned for sure is that if I’m going to do much more of this type of wood work, I’ve got to invest in some better tools. It took a looooong time to file, sand, file, sand, file, sand all these pieces to size. Regardless, this was fun!
The last couple of pics are a dry fit just to get an idea if this thing is going to have a good look or not. There’s still some hardware to build/add (trunions, linch pins, cap squares, breach rings, etc), which is my next step. I’ll wait till the very end to add the rigging.
- AJohnson, Landlubber Mike, Keith Black and 5 others
- 5
- 3
22 hours ago, Joe100 said:
Glen is back at it again!
It was either house chores or another ship project. No brainer!!
Below are the side brackets, the fore and hind axletrees, and axles. The axles will be cut to their final length later. For the side brackets, I made them with 4 “steps” instead of 5 like the plans show (and pretty much every other carriage I’ve seen). I need a lower profile for the brackets. The normal profile would hide too much of the bottle and potentially obscure the front half of the ship. The fore axletree will sit vertically in the final assembly and the hind will lay flat.
Rum buttered popcorn??? Dang you, Keith. Now I've got to go shopping tonight.
- 2
For the “lug nuts” on the wheels, I used brass nails that are 3/8” long with a 3/32” diameter head, which I ground down to a flatter surface. They are supposed to sit flush in the wheel, but I do not have a flat base counter-sinker. So I used an end mill router bit to countersink each of the 80 holes.
- Keith Black, archjofo, IgorSky and 5 others
- 8
The wheels were a particular challenge for me. I do not have any hole saws that were the sizes I needed, so I cut the wood into rough circles and hand sanded them into a final rounded shape. Then I used a flap sanding bit with my drill lathe to give them their final finish. I just love the end grain of the wood, which shows really well when looking up close at the wheels.
The only thing more meager than my woodworking skills is my array of woodworking tools which consist of a 10” table saw, a bench sander, and a band saw. When I was following @gjdale's capstan project, I almost quit looking at his posts because I was so jealous of all the tools in his workshop (as well as his high level of skill). But I’ll do the best I can here with this carriage.
The wood I’m using is the heartwood from a large english elm tree that came from the south lawn of the Texas capital. It is really hard, dense wood and has a beautiful natural color and grain. Unfortunately, it tends to scorch if the cutting or sanding is not done carefully.
I started with a couple of slats that are about 14” long, 2 ½” wide, and 5/8” deep and cut them into the basic shapes for the sides and axletrees.
- Keith Black, CiscoH, gjdale and 2 others
- 5
In the meantime, I’m going to start by trying to build the cannon carriage for the display first. With so little info available on the 1814 Independence, I’m going to assume that it had cannons and carriages similar to the USS Constitution since both were launched in sort of the same time period. I found carriage plans on the USS Constitution Museum website for a 24 lb “American-Type” cannon so I’ll try to make my display carriage similar to it.
There will certainly be some deviations required to accommodate the rum bottle vs a cannon barrel. Plus, one thing I know I’ll change for sure is the color. Pictures from the website show the restored Constitution carriages painted a reddish color. However, old black and white pictures make the carriage appear unpainted. I like the look of natural wood much better than painted wood so I’m going au naturale. Here we go!
According to Chapelle, no plans exist for the original Independence. I could not find any model kits nor could I find any builds on MSW. And the only picture of the 1814 version I could find was a sketch of the sail plan (see below). I’ll continue to research the ship and if anyone out there knows where I can find more info please comment.
Since finishing the Aurora a few weeks ago, I found myself stressing out about all the yardwork and home fix-up things needing attention. I figured the only way out of that trap was to get started on another ship project.
So I took a trip to Total Wine looking for cheap alcohol in unique bottles. You get some interesting reactions from store clerks when they see you grabbing bottles off the shelf, turning them sideways, and just staring at them.
After an hour of perusing the aisles, a bottle of Cruzan rum with a longer neck caught my eye (1st pic below). When I turned it sideways, it sort of looked like a cannon barrel to me. Or maybe I had too many of the numerous free samples they were giving out around the store.
Regardless, I got this idea about a display with a warship in the bottle and the bottle sitting in a cannon carriage. Hmmmmm. So I bought the $20 bottle of Cruzan. That’s over my usual budget for this stuff, but I do like rum drinks so it won’t go to waste like the rotgut I bought for the Aurora.I did some searching to see if I could find where someone else had done a similar SIB. I found several cannon carriage wine bottle holders for sale but nothing with a ship in the bottle. So maybe I’ve got something that’s a bit unique here, which would be pretty cool.
Next was deciding what warship to build. I went thru Chapelle’s book on US naval history as well as the Naval History and Heritage Command website and decided on the USS Independence - the 1814 version and not the later Razee (new term I learned in my research). I liked the name of the ship, its history, and the fact that it was the first US Navy ship-of-the-line. Plus, a ship armed with 90 cannons would be a new challenge for me compared to my previous builds of commercial ships (Morgan and Aurora). The 2nd pic shows the basic concept I’ve got in mind.
- GrandpaPhil, John Ruy and mbp521
- 1
- 2
Keith - gluing is also how I attach ratlines to my shrouds for SIBs. No way for me to tie a knot that small and I had not thought of threading through the shrouds like you describe (interesting idea). Aleen's fabric glue has worked well for me. It's clear and has good strength and a bit of flexibility after drying, which is crucial for me since my shrouds and ratlines get folded over and twisted numerous times before reaching their final resting spot.
Rob - that was an eye-opener to see that you glue ratlines at the larger scale (larger meaning compared to SIBs). I thought that everyone always tied them. Assuming that's what you did on your Glory of the Seas, they look really good. Thanks for giving away one of your trade secrets!
- FriedClams, mtaylor and Keith Black
- 3
1 hour ago, Keith Black said:
Glen, can you use this somehow in your SIBs? I'm seriously thinking using it for Zip Seizing.
That is interesting, Keith. I had no idea they made it so thin. I will definitely keep that in mind when I kick off the next project. Thanks for the heads-up.
- Keith Black, FriedClams and mtaylor
- 3
Whatever the repairs were, looks like you did a great job fixing them! Your excellent work continues.
- Keith Black, mtaylor, Edwardkenway and 2 others
- 5
Olha, beautiful work with your first ship-in-bottle build!
@Joe100 Thank you, Joe. Please let me know if you decide to do another version of the Endurance. I'd love to see what you would do differently from the first go (which I think is amazing).
- 2
@curtbroo Thank you for checking in and commenting. As with Malas above, I apologize for the late response to your post. Congratulations on trying this kit for your first wooden model ship. I hope you enjoy the effort as much as I did.
If you have not done so already, I would highly recommend posting a build log for your work in progress. The support of this community is absolutely fantastic. There are so many incredible people with amazing modeling talents that are willing to offer comments, advice, guidance, tips, trick, etc. I wish I'd discovered this forum before I finished (or started) my Alabama.
On the other hand, if you have started a build log, please let me know. I'd love to follow along.
- mtaylor, woodartist and Keith Black
- 3
Glory of the Seas 1869 by rwiederrich - FINISHED - 1/96 - medium clipper
It's making my neck sore turning my head to study those pictures, but it's well worth it! Really beautiful work on that whole bowsprit assembly, Rob.
