Theodosius
Posts posted by Theodosius
Then there's the life, is'nt it?
But that's not the point of this log, so, after a long needet brake, work has started again.
I'm mostly finished with sanding. With the bulk of the hull, I'm quite pleased:
Front and back there are places where the planks opened a bit. That is, when I sanded them down and thinner, when they had not a good contact over the complete depth. Especialy at the stem. Perhaps of inpatience or just lack of skill. When I glued the planks at first, there were no gaps to see. Seems I have a lot to learn.
I used the provided deck and started the inner planking of the bulwarks with leftover strips from the second planking
104616
- BobG, mgatrost, Jack-in-the-Blue and 9 others
- 12
The colours add a lot of 'life' to this model. I like that! 🙂
@chris watton, @CiscoH, @Delf, @drjeckl, @SpyGlass, @VTHokiEE: thank you all very much for lookin, leaving a thumb's up and accompany my journey into wooden boat bilding! 🙂
Finished two sanding-sessions. At minimum a third is required, I think, but how smoth does it realy needs to bee for coppering?
In the macros you can see, that the two damaged strips I nevertheless build in, need more sanding.
Than, I'm afraid, it is not as good as I has wished it would be, because there are same small gaps to see. On the otherhand perhpas it is not so bad for a first attempt. At least a motivation to improve skills 🙂
Sure, most of the hull will be hidden under the copper, but if the copper also deos'nt turn out so well, well than I don't know what to do, but time will tell :).
@Ryland Craze, @bruce d, @Sea Hoss, @CiscoH, @DelF: thank you all very much for your thumbs up! Allways a good motivationer 🙂
@SpayGlass: I think I will build the inner bulwarks from the not needet 3mm pear, and the rest strips. I have enough of the 4mm for the wales and the upper rest of the outside planking. If this will not work, I go and contact Chris :-). And thank's a lot for your generous offer. I live in Germany, and if nothing helps, I will come back to this :-).
So I finished the second planking. Not as good as intended, because I was impatient, and because of lack of experience. But of course, mostly becaus of my impatience. Things that were not as good as wished, I could always have done again, but I did not.But then I was also a little bit short of strips, but that's just a poor excuse for my own shortcommings :-).
An overview:
Because I ran out of strips, I build the garboard plank out of two pices per side, as I also did with the first planking.
I have spared full planks for the rest of the outside of the hull upward of the main wales, and two strips for the main wales. For the inner side of the bulwarks I will uses the narrower 3mm planks, because ther are plenty of them in the kit. And then I have a lot of cut overs from the planking itself, so I think I will be fine.
The two-part garborads:
I know that garboard should ran parallel to the keel, but I struggeld a little bit with triangular stealers, and then there is the copper to come, so I went the easy way and bent it away from the keel and just filled the gabs with additional planks:
The contact of the planks with the stem is on this side:
not as good as on this side:
But at least the planks are quite parallel structure wise, even if not colour wise:
I think I have already talked about the colour of the strips, I'm fine with it this way, because there is the coppering that will cover the 'wild' part of it. Above the wale, I have sortet the strips per colour 🙂
Well, what it is worth at all, will show the sanding, which is still to do :-).
Beautiful modell with a nice colour selection 🙂
You're painting skills are remarkebly 🙂
- Keith Black, FriedClams, Tony Hunt and 2 others
- 5
On 5/18/2021 at 10:09 PM, DelF said:
Don't worry, you did nothing wrong. The moderators removed a string of posts after someone started a topic that was felt inappropriate, and I think your post must have been in the middle and removed accidently. Anyway, thank you for your kind comments, I really appreciate them. I should point out that the kit comes with very good instructions and plans, it's just that I like adding my own embellishments.
Don't get me wrong, I also think that the kit instructions are top notch! Perhaps the misunderstanding is just because of my poor english. But I wanted to say, that you add so much, I mean, you show what is possible, if one will do some (ok, a LOT) more work, and for that you're bild log is like some improved instructions :-). Perhaps I can use some of that great add ons, but I'm not sure jet if I'm able to do so. At least, the mind is willing to do so, but the flesh is weak, or something in that way :-).
I enjoiy reading you're log very much :-).
Realy nice work ont the guns!
I also like your white painting of the underwater part of the ship. And I would also prefer a not so perfect job on this. I mean, this is not a piano :-).
And, but I'm not 100% sure about that, I think that the white for the underwatership was a mix with different chemicals for fouling protection, and in the end, it was not a straight white, so any imperfection on this, is realy perfect :-).
And I'm a little bit jealous about your white. I mean, it was the the admiral who decided for Speedy and not for Flirt, because of the coppering. Bling bling, you know, lol :-). Hope it was not a mistake...
@Sea Hoss, @SpyGlass: thank you both for your thumbs up! Much appreciated 🙂
@SpyGlass: yes, until now, I have only used the wood suplied by the kit :). Perhaps I was just a little bit unlucky :).
I will wait and see how far I can go with the strips, perhaps it is still enough, but I don't know jet :).But, I don't cut the strips in two halves! They are all one piece from front to stern. Ok, one broke during gluing just very far at the back, and I still use this one, but that was unintendet and I hope, it will not be to prominent in the end :).
Perhaps all my pencil-marks look like as they were cut's through the strips, but they ar'nt.
Normaly, there are two marks for the tapering, and the others are for gluing.
The first planking, the first strips I used a combination of wood and superglue to speed things up. But for healthy reasons that did not work for me.
So I only glue with wood glue. And I make mostly three, sometimes four gluing-sessions/sections for one strip. That's where the marks are for, so I can see at what point I need to add the next glue.
Hope that clears it up a little bit :-).
Thanks again for your interest! 🙂
@VTHokiEE: thank you very much for your thumbs up! 🙂
@SpyGlass: I break the hull in half in terms of coulking, lol, don't know jet, how this will turn out :-). Like you, I also try for a nice close edge fit, but, I struggle a little bit with it. The sanding will show how it went in the end 🙂
Thought I could give water-level report :-).In general, I'm working slowly through the second planking.
But I have some issues.
Some with my work: I could not see my marks on a watered strip, because it changes colour that much, so I worked most of the time with heat-bending.
Second with the wood itself. Perhaps I have gotten quite a vew ones, done with the thickness planer just short of a blade replacement:
I break a few with imperfections like this:
Then I started to look more carefully at the strips before I started to use them. But my eyes ar'nt the best any more, so I also build in such strips:
But they are hopefully thick enough for a good sanding.
Will see if there is enough stock left, because then I started to sort some of them out, and some I have broken into two or more pices :-).
Nevertheless, I finished 15/16 strips, and the area left to do is less then the finished one :-).
Because of inperfection of my work there are gaps, a good example is also the picture above. I hope that they will be not to prominent when sanded, I don't want to paint the whole model, and then there is also the coppering.
But I don't know if I can copper better than planking lol.
Colour: well, I have sorted enough strips for the area above the whale out, and they match fine in colour. But for the rest, as you can see, I just take them as the came out of the bag:
One last sentence about the coulking question: because I did this on the stern area, I will also do this above the whale, but not below the whale. I have no idear how this will turn out...
Don't know why my post dissapears, perhaps I did something wrong, but no problem, I post it again: your build log with this great photos is like an super extended build-instrucion-book :-). Thank's a lot for your great work! 🙂
A very beautiful model! And the case just fits perfekt! 🙂
- Old Collingwood and VTHokiEE
- 2
I like that model, so I will watch out for what you are doing to her :-). Nice start, as far as I can say 🙂
Nice start on the hull! Nowadays I understand more, what you are doin' here, and this will become a good one! 🙂
This is allmost like an Tamiya-kit! 🙂
Congratulations! A very nice model and an informative log on top of that! 🙂 Thank's a lot for sharing!
Ah, I see, thank you very much for this information! 🙂
@SpyGlass, @CishoH, thank you both very much for your thumbs up! 🙂
@SpyGlass: again, thank you very much! It does'nt feel that great, but maybe the pictures are a bit on the postive 🙂Hope you feel better now, and that you can go on with your own build! :). I have also used a flexible sandig strip, but not a self-made one, just the women-cosmetic ones. They work great, IMO.
Your idear how to check symmetry was great! I did this, and it seems to be ok now, but the real test still to come.
Started the second planking.As usual, the stern-area first (stern-rudder?-post just for the look of it, not glued jet):
I see in the pictures, that there is some more sanding required. Why don't that wonder me? 🙂
And, and that also seems to be very common: the question of the questions:
to caulk or not to caulk... *lol
You can see, that my first try is with a caulking simulation, but realy, I'm undecided yet if I like it or not.
It is more prominent than I thought. But, that is not the final finish. I would like to apply linseed-oil on the pear-wood.
That would change the colour and the coulking a lot, I think. But I'm afraid, if I add the oil now, the glue on the sides will not work properly.
Best way would be to make a small plking example with caulking and oil, but I don't know how many spare-strips of the pear is in the kit, and how many I will kill during the second planking.
Perhaps somebody with a finished Speedy can give me a hint if I can spend one plank for tests!?
Thank's all for your help!
- VTHokiEE, Ondras71 and chris watton
- 3
On 4/17/2021 at 11:34 AM, glennard2523 said:
The photoetched rear hatch skylight part was cleaned in acetone and then given a coat of grey etch primer.
I can't remember if I read this allready somewhere here or in your other blogs, but how do you apply your primer? I ask, because one can see, that the inner strips don't get a lot primer. Sure, not a big deal on this part, but that may change on others :).
The resulted parts look good! 🙂
Hello KirbysLunchBox,
gratz to your finished very first planking! Looks good! I post here, because I like how you bite through the problems that occures and don't give up! And you managed your first plywood-gunport-patterns to bend and fit so much easyier than I did, cool!
As a first time builder, as you, I can't give you much good tips, but just one from my own so far experience: your first planks are so fat, that you could sand some more. A lot more. They you would have much lesser places where you need filler.
But again, the other helping members here give you more substantial hints then I can.
Like to follow your build!
WOW! This will become a very beautiful model!
Recently, I read some of the USF Confederacy blogs, and, while bigger, they're some uqualitys in both are frigate style. But, it's fascinating to see, how much the kit design of the Sphinx has improved! All the measuring to line up the smal parts for the gun ports in the Confy-builds, are so much advanced here in the Sphinx design.
I'm realy impressed! 🙂
HMS Speedy by Theodosius - Vanguard Models - 1:64
Happy new jear!
@CishoH, JeffT, VTHookiEE, David Lester, DelF: thank's for your thumbs upp 🙂
@David Lester: Thank you very much, but the pictures flatter a little bit. In the close ups, one can see all the imperfections 🙂
@SpyGlass: I used this method on the inner bulwarks. On the outer hull, the gaps are very small. They are ok for me, they only show, that there is a lot of room for improvement :-).
Innerbulwarks planking continuess:
Error: I did not sort the left overs by they're width. First, not a problem, but later on, when a longer strip cover multiple smaller pices, there were some major gaps to appear:
I also managed to break out some pices around the port holes:
Planking finished and trimmed down:
Filling and sanding:
More sanding and reopen the port holes:
Before paining:
Painted:
Now, I torn back and forth, if I want to do more filling/sanding-throughs.
I am ok, that there are strips to see. That is one of the reasons I started a wooden boat. I want to see, that it is from wood. On the other hand it still might be a little bit to prominent on the bulwarks. I have not decieded jet.
This is ok for me:
This not, when I see the macro:
I think, I will do more work on this, even if it is mostly for the pictures. For my eyes, only from a very close view, I can see that
Nevertheless, I'm proud, that I started again and did more work on the model. It is also a skill to master, to find out, what is good enough for myself, and what needs to be improoved. I hope I will finish this one, even if it does not match my expectations. Perfection on the very first build is perhaps not what I should go for, because this can be a motivation-killer. But will see...
