Theodosius
Posts posted by Theodosius
This is just *enter superlative of choice, they fit all* 🙂
- mtaylor, Siggi52, FriedClams and 1 other
- 4
Wow, those garborad-planks are beautiful! And I like the colour of your boxwood-deck. Sory, no experience in deck covering 🙂
- Thukydides, Obormotov and Dave_E
- 3
This foot-upgrade was well worth the effort!
- Blue Ensign, Dave_E and mtaylor
- 2
- 1
@Thukydides, @CiscoH: thanky you for your thumbs up! 🙂
@Thukydides: thank you very much for your suggestions, and you are right! I will overdue this, when I'm at the point to make the metal-parts of the guns! I allways fail, when I want to go the 'cheap' way, and in the end this makes more work instead of less. But there a things, one will never learn in his life :-).
Most of the furniture is finished (ladders and gratings left, but they might be done later, don't know at the moment), but I thought, after reading in the other build logs herer, it would be better to install the guns at this point. And when the guns are inside, then glue the rest of the deck fittings.
So this is how it looks at the moment, and the main guns are next:
- BenD, ccoyle, GrandpaPhil and 9 others
- 12
Your first ever second planking is great! It looks very smooth. And when you paint the hull anyway, you can use filler, as you do!
I had exact the same problem as you had: Theory is one side, but I was not ably to cut and form the wood as good as I would have wanted to. More practive will help.
And then I think that the instructions for the planking in the manual were all that I needet. Just let the strips follow they're own way, and when the want to run above another plank, that is the point to start tapering. But then I have an elektrical plank bender, that was a very helpfull tool to bend the planks in both directions.
- Rik Thistle, AJohnson and DB789
- 3
@BobG, @SpyGlass, @CiscoH: thank you for the thumbs up! 🙂
My very first upgrade:
I added some wood to the pump handle to prevent some calluses during working the pumps.
One side with the bare wood, the other side already sandet:
And in place (all the bits are a little bit wonky, because they're all not glued):
I think the edge-highlighting on the pumps is a little bit to prominent and not clean enough, I will overdue this.
- KARAVOKIRIS, Thukydides, BenD and 3 others
- 6
You have made a good way, and the result is something to be proud of! I also need the help of a magnifying glass lamp...
- AlleyCat, Dave_E and Keith Black
- 3
Thanks a lot for your description of the used sewing. Yesterday, I went also to a lokal sewing store, and they sell me Gutermann too, that seems to be the common thing. Perhaps it is the same, don't know jet, but if I am at the point to start the rigging, I will use this brand and will tell how it worked out :-).
Phantastic work!
- FrankWouts, Dave_E and hollowneck
- 3
@PhillH, @Dfell, @Thukydides, @David Lester, @SpyGlass, @Paul Le Wol, @ChiscoH: thank you all very much for your thumbs up! 🙂
I saw in one picture of my last post, that I managed to twist the tiller.
Fixed that one:
Because this is not enough to justify a log entry, here is also the finished, or not (paint?), steps outside the hull:
The work on the deck furniture and the bits has also started (nothing glued to the deck jet):
Again, I'm not sure about the colors to go. At the moment I go into the direction to leave the furniture in wood and paint the bits red-ockre, but this changes a lot during a week, and even more during my reading and looking at the pictures of other build logs... 🙂
- BenD, KARAVOKIRIS, CiscoH and 3 others
- 6
Wow, this is an mostly underrated form of art! When I was younger, I dreamed of and RC-modelship with an steam engine. At least, I'm building historical ships, ok, one, lol, out of wood 🙂
very crisp and clean work, looks very good!
@DelF, @CiscoH, @BobG, @BenD, @David Lester, @ccoyle: thank you all for your tumbs up! Much appreciated! 🙂
I think, now I entered into a great phase of wooden model shipbuilding! 🙂As it seems, to equip the model now, there is allways a relativley small amount of work in comparison to the planking for example, but there is much to see with this little work.
This is a great fun phase for me :-).
So, I cleaned these forward bits, because I wanted the wooden look:
But they looked like an outsider, so in the end, they were also painted black:
Next was the rudder:
And installed:
Ok, the gap between the rudder and the hull is a little bit to large, but the overallook is good I think.
And then I always forgett to clean up the messy gunports in the stern :-).
- Dfell, KARAVOKIRIS, Paul Le Wol and 6 others
- 9
Nisha by Andyrew - FINISHED - Vanguard Models - Scale 1:64 - a Brixham "Mumble Bee"
lovely model, lovely buile!
