Everything posted by AJohnson
That rudder coat looks good and a great tip on using old lens cloths, I have loads of those hanging around.
- 114 replies
- Vanguard Models
- Speedy
Good evening, we are getting close to the finish line! Rope hanks and the crew added! The figures from Vanguard @chris watton are just great, I only wish my shaky hands could do them justice, a miniature figure painter I'm not! But I'm happy with the overall look from normal viewing distance, macro is so cruel! 😬 This was a delicate process (and painful for some of the crew), as I performed surgery on a few of them to re-pose them for my take on "gunnery practice" and drilled out a few hands for the Carronade training tackles. Think they add to the impression of a busy deck, but the real Trial must have been very crowded as this motley bunch are only about a quarter of her complement. Only the port main yard counter brace to add (I dare not add it before I had got the crew on board for fear of snagging it as I reached in to place them.) Then the flag & pennant to make and add with their halyards. Then a final clean up and touch up with matt varnish where recent glue added. Thanks you all for the like and comments.
That does look fantastic Jim, I'm going to have to evict one of the kids to make room for more shelves! 😆
- 76 replies
- Harpy
- Vanguard Models
Welcome to MSW!
Welcome to MSW Vytautas!
Hi Stuka, Craig is right, a simple bit of card is fine for transferring tick marks. I’m not holding my efforts up as “expert” advice, I did describe my planking efforts on my Cutter Trial log from post number #34 using tick marks etc. There are also many more better examples and tutorials on MSW, you don’t need to spend money on fancy tools or books, a flat board, some clamps, a travel iron, rule and good knife is about it. Good luck, keep us posted. 👍
- 129 replies
- vanguard models
- Sherbourne
Thank you all for the likes and @jpalmer1970 @Oboship @Ronald-V @Charter33 @Nipper @Craigie65 @Dave_E @BrochBoating @Danstream for your kind words. More work on the main sail, laced it to the gaff, amazing the number of times the lacing needed tightening before it seemed to grip the sail to the gaff right. Also added inhaul and outhaul tackles on the boom, I had to dip in and out of many reference books to decide on how these were going to be done. Also added brails and tackles for these, again, the variation in the sources for these is amazing, I just went with what was achievable with my skills and what would look okay against the sail. There has also been plenty of shaping of all the sails using the wire in the edges and plenty of time online looking for how gaff sails look for real (one of the best sources I found was Gaff Rig World, a group on Facebook.) I have done my best to make the sail bend naturally, as though filled with wind and allowing some deflection in profile caused by the boom lifts. It is okay, not entirely happy, but there is NO way I am redoing all that lot! 😆 Good lessons learned to be applied to the next build... Finishing touches to be done are the addition of Reef tackle, pendants and such. Then a whole load of rope hanks are required, a tidy / touch-up, varnish session, then all that remains is the motley crew and flags. Thanks again for following along.
Great job Dan! Think the planking looks very good. 👍
- 87 replies
- Lady Nelson
- Amati
Update and a change in plan, I decided after all to complete the main sail. Thinking about it, I thought whilst I was in the mood for sail making and undaunted by making 200 reef points I better get on with it, before I found excuses to avoid making further progress. This is probably the largest tissue sail I will ever make, so overall pleased with how it came out, but learned a lot more in the process of making this monster. Followed the same process as before:- paper template for shape and size, then construct the sail with a one piece core and strips glued front and back, with wire trapped in the edge for shaping later. I found using a rule helpful to fold the tissue in one piece around the wire as I went. The gluing the bolt rope along the edge to hide the wire; forming beckets etc. as I went. Reef points were actually split in two and glued separately to each face, rather than trying to tie knots flush to either face of the reef point hole to minimise handling the tissue paper -that entailed making nearly 400 of them! 😬 - but worth it not to risk trying to pull knots tight through fragile tissue! I did contemplate only adding one per. sail panel, but I knew someone would spot that and so took a deep breath and did two; have also punched in two per. panel for the robands when I get to those. Have now begun the process of adding the sail to the model. Starting with the mast hoops, so it will take it's own weight. the hoops are extras bought from Vanguard. A few shots below show the sail as it looks now, temporarily held in place with various bits of tape and temporary rigging held by clips to provide tension, but it gives an impression of the look I am aiming for eventually. Thanks for keeping me company with this experiment and the likes and kinds words! 😁
Hi folks, another newbie from the UK
AJohnson replied to Graham_T's topic in New member Introductions
Welcome to MSW Graham. As Chris said the logs are a two way thing, so yes there are more Bounty and Victory related (and a few other old chestnuts that always crop up) logs than you can shake a stick at, but you are amongst friends who never bore of looking at the same thing! Not sure what that says about us 🤣 So please do a log if you have time. 👍 -
Understand Jay, we will be here for your updates when you have the time to sit and enjoy your free time again. Take care.
- 63 replies
- Lady Eleanor
- True Vine
Congratulations Chris! Back to 1/33 aircraft territory, or is Phoenix getting dusted off?
- 146 replies
- Speeljacht
- Seahorse
Great job Tom, your sails look great, I can really appreciate the effort you have gone to get such good results on a square rig, adding sails to a Cutter is enough for me at the moment! As for the rat lines, yes I feel your pain and the dilemma, but as everything thing else is so great on your build, it would be a shame not to try and tackle them. 😑
- 144 replies
- HMS Speedy
- Vanguard Models
Good job and advice from Craig. That has saved you a lot of bother later.
- 129 replies
- vanguard models
- Sherbourne
Welcome to MSW Mark!
For rigging of cannons I find this thread very helpful. https://modelshipworld.com/topic/21776-carriage-gun-rigging/ As for rope, one of our Sponsors and member of MSW do excellent rope look for sponsor banner for Ropes of Scale.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
Yes, I added the bulwark patterns on my Trial without water. Just took my time, working from bow to stern. But if you feel there is too much spring and a risk of snapping, pre shaping them with water and leaving to dry is also a route many use.
- 129 replies
- vanguard models
- Sherbourne
Thanks @Ronald-V, @Keith Black, @Craigie65 & @FriedClams for your kind comments, glad you like the sails so far, I'm chickening out 🐔 on the last one (and largest) for now, but my excuse is if I rig the booms for the main sail now they are going to impede access to the deck for adding the crew! So I've been tidying up a few other jobs first, done work on the anchors and mounted these. With reference to Peter Goodwins "Alert" book I added seizing and whipping to the cable and also added a buoy with attached ropes and lanyard. I did contemplate lashing these to the shrouds, as is often seen in build logs, but looking through some contemporary Cutter models the buoys seem to have been stowed just as often with the anchor, either just inboard of the anchor (as I settled on) or used as a fender of sorts between the anchor and the hull. Anyway the advantage of having them on deck is they help make the deck look cluttered which I like and it partially hides my naff buoys from view; there not a patch on @Thukydides miniature masterpieces. 🤭 Not wanting to end on a downer, but had a slight mishap, I somehow - (I say "somehow" because I don't remember doing it!) I have caught a cannon and snapped off the end (pinged off into the ether as per. usual! 🙄) and also damaged the tip of a boom cradle. I really don't recall doing it! - Must be old age creeping on me! 😆 - Clumsy so and so.... Also might be away for a bit; back in hospital again this Friday, but hopefully soon out and back at the workbench. Thanks for looking in! 👋
You probably don't need to wet the bulwark pattern, but if you do allow it to dry in its new shape (there are plenty of build logs where people leave them to dry wrapped around a suitable round tin using rubber bands etc.) before gluing to the hull to allow it to shrink back to its original length. Your build will soon start looking like a ship! 😁
- 129 replies
- vanguard models
- Sherbourne
I just put in the terms “log” and “Venerable” and a date range 1750 a 1800 in the National Archive site and a few crop up. It will be quite the detective story to find out how Venerable looked at Camperdown. Just ask Gary about HMS Victory! One you would think would be well documented. Looking forward to his imminent book on the subject. Artist works though are not always completely inaccurate, so caveats aside, they are often all we have and the artist was sometimes guided by those who served in the battles depicted. An example being Richard Dodd who depicted Trafalgar and painted HMS Pickle under the guidance of Her commanding officer Lapenotiere. (about all we have to guide us on Pickle’s appearance as we have no plans). So another avenue might be to see if the artist of your reference painting had any connection with those who served and might have had some “guidance” on Venerable’s appearance. Good luck!
