Everything posted by AJohnson
Spitfire MK I by Danstream - Tamiya - 1/48 - PLASTIC
AJohnson replied to Danstream's topic in Completed non-ship models
A lovely clean looking build Dan, really shows the Mk.1's beautiful lines. "N3200" (well bits of it) are back in the air, there are a fair few documentaries and videos out there of her: https://www.iwm.org.uk/history/the-spitfire-lost-for-almost-50-years -
Evening all, Starting to fit sails to the model, having finished the Inner Jib Sail I decided that it would be best to fit that one first and work from closest to the mast outwards, as that would hopefully give me most working space. A little bit of a delicate balancing act, using varnish to stiffen the threads in order to "push" the sails into position to simulate them being blown by the wind - hence the various pens and so on propping the sails in position until the thread is stiff. Having felt my way into the process it is time to start on the Main sail! 😨
- 206 replies
- Vanguard Models
- Brixham trawler
Very tidy Glenn, have you settled on a paint scheme, or are you sticking to the Vanguard one?
- 48 replies
- Nisha
- Vanguard Models
(and 3 more)
Congratulations Kevin, a beautiful little build!
- 38 replies
- Lady Eleanor
- Vanguard Models
Yes good save, on the home run and looking good! 👍
- 46 replies
- vanguard models
- Erycina
(and 3 more)
Evening all, thanks to @Old Collingwood @king derelict @Slowhand @DaveBaxt for your kinds words. Work continuing on the sails and finally finished one - the Outer Jib Sail. (pictures below) the inner Jib Sail not far behind. The start of these sails was a while back if your interested in how I made them (posts #113, #118-120ish.) Finishing touches were to glue on the bolt rope and attach the block and lines, then a final flat coat to seal everything together. Overall I'm satisfied with this first foray into sail making, hopefully the wrinkles and "roughness" and colour variations are sufficiently "scale". I'm toying with the idea of having a deliberate repair patch on the main sail, with some areas of stronger looking colours to denotes it is a more recent section of sail. I'll think on that while finish the boltropes/bocks and lines etc.
- 206 replies
- Vanguard Models
- Brixham trawler
Good to have you delurking Paul. Although too late for build logs, do you have pictures of those builds you mentioned, you could add to the gallery?
That looks like a nice wood, are you going to treat it with anything like Danish oil or varnish, or is it painted outside?
- 57 replies
- marisstella
- batelina
Sergal HMS Bounty.
AJohnson replied to mark j's topic in Building, Framing, Planking and plating a ships hull and deck
Another suggestion is to do a “build log”. Or ask a kind Admin to move this thread and make into the build log section. Where you will get more “passers-by” to offer advice. -
Sergal HMS Bounty.
Hi Mark, I have just found this log after seeing your intro, I'm doing the Caldercraft Bounty (1/64) so I will follow along and try and help out where I can, I agree with others that for a first build Bounty is going to be quite the challenge at times, but I understand your reasons for doing so for your Father-in-law's memory. Thing is it's not a race and people; me included, often set a project aside and do something else for a bit and come back to them. As for initial comments the plans and framing look similar to my Bounty, so hopefully any queries you have should be of a nature I have come across. As @vossy has mentioned some balsa fillers for the first few and last few frames are needed for seating the planking on and fairing (sanding) the frames so the planking runs smooth across their edges is a task well worth taking your time over. Also before you get to planking make sure the keel and frames are all straight and true. Ply false keels can twist or bend a little, throwing out the alignment of the frames and deck etc. so making sure the frame underneath is correct is an important foundation, I had that problem with my Bounty. Good luck and enjoy! We'll be there - just shout out if you want, also whilst waiting for glue to dry and so on, searching through this huge site will pass many, many hours.... -
Welcome to MSW Mark I am also doing a Bounty at the moment (Caldercraft) - well I say "doing" but I have successfully avoided doing much at all on it recently, but I am determined to finish it this year! The link to my log below. There are a few other Bounty Builds also going on at the moment and I'm sure the builders would be happy to help, just depends which manufacturer your kit is. there are quiet a few out there.
The hull is about 11 inches / 280mm long.
- 206 replies
- Vanguard Models
- Brixham trawler
Hi Greg, that rigging is really good. Apologies if you have explained on other builds, but what do you use for the rigging threads?
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Thank you very much Will, have you been doing any building on your Syren since your great Erycina build?
- 206 replies
- Vanguard Models
- Brixham trawler
