S.Coleman
Everything posted by S.Coleman
  1. Your doing great there dragzz. Keep up the great work. I have built this kit as well and I'm afraid Adrieke is correct about the window/ vent. If it was a window it would look good though. Nice job
  2. Nice touch with the working lantern. Apparently this ship was originally designed as a coal ship, imagine a big old fancy ship like that just to ship coal? I like the attention to detail with this kit. Looks great.
  3. D or E for me. Maby a little bit more towards the D i think. But that's just my two cents, As Augie wrote F is too gray. Just on the subject of finishes I hope that you can remove that sample paper off the wall without tearing the wallpaper!!!!
  4. Looks good. It's interesting watching you do all this before even starting the hull planking, or the decks. Obviously the deck planks are laid straight onto the bulkheads?
  5. I never bothered with planking the deck that you will never see. Saved a lot of wood in the process and you never know because you can't see it.
  6. Defiantly use a hull marking jig. As mentioned before the string will always be out of whack. You can buy them or simply make your own.
  7. Cheers guys. Now I go go back to the model a little wiser, thanks
  8. Great for measuring the thicknes of dowels for masts etc. Great tool
  9. I had a look through all the posts in this section but could not find anything on how to apply varnish the best way. I know some brush it on and some spray it on. In between coats do you give the hull a light sand with extra fine sandpaper? Then apply another coat? Just want some advice thanks
  10. I have not had this problem on my planks as I always use PVA glue for my planking. However on other parts of the ship where this has happened i have just sanded lightly over the area and restrained as I have done for my decking. Sometimes using a scraper carefully you can scrape that stain off.
  11. I don't know what it is about this ship. My partner thinks im crazy, always watching my Titanic documentaries. I love the ship and the story of it. There is always something new to discover about it. Thanks for the clip.
  12. I understand your point. And I also understand as it is your kit it is completely up to you how you want it displayed. I thought the same, but when my partner said a sailing ship is not a sailing ship without all it's bits and bobs ( as she calls the rigging) I have had to complete all the rigging before I am allowed to display it.. But as I said, it's up to you and I respect that. Happy modeling!!!
  13. Around the bottom where the walls meet the deck I put a small strip to act as skirting, and hide the gap. It worked out well.
  14. Maybe if possible the system could be wired up with an LDR ( light dependent resistor) so the lights come on when it gets dark? Similar to the street lights.
  15. I have not long finished this model too. Looking at you log brings back the memories for sure. Doing great. I like the darker deck planking by the way
  16. Can't say I have. Don't really have the need to be offensive or rude as everyone's so helpful and friendly on this site.
  17. Well, looks great what you've done on the hull. Real nice. The rigging can be a nightmare! I can't help you in regards to sewing sails as I never instal them on any of my ships. But as Stockholme Tar had suggested about the pin in the yards is a winner. Saves a lot of hassle. I don't tie my blocks to the yards, just wrap the line around once and cross it over it self. Then use a small drop of CA to hold it. Other than that your doing great
  18. Yor right there are a handful of different blades for different jobs. The big wide chisel like blade # 11 is mainly used for heavy duty cutting work. It has a lesser angle of the blade. The smaller, skinnier blades #1 are used for the more smaller pieces they have a greater angle of the blade. The rounded blades #11 are good to rock back and forth to get that cutting motion. To prevent splintering of the wood use lite strokes of the blade, each time cutting a little deeper as you go without putting too much pressure on the knife. I must add try to avoid the scalpels with a blue plastic chuck that holds the blade as these can break and be dangerous. I use a brand called Excel, they are stainless and very durable. Your local hobby shop will have a selection hopefully. As for the scroll saw I'm afraid I will have to leave that for someone else to answer. Hope this has helped you.
  19. Realworkingsailor - I have not purchased the kit yet as I was wanting feed back prior to doing so. Lots of good help guys, that ship the 1:80th slave schooner came up real nice. I did go down to Fremantle harbor the other day as 3 Dutch tall ships have moored there for the last couple of weeks so I had a good browse around them and took some pics for detail reference. Thanks guys
  20. It's ok to use. But beware it stains if you have dirty fingers. And I guess with a stain over the top of it will finish it nicely.
  21. I want to know everyones ideas about weathering their models. Why or why not ? Do some people like the look of a fresh clean looking ship or the look of one been at sea for years. I found in the local hobby store a weathering kit, but this was advertised for plastic railroad models. Would it still have a nice look on a wooden sailing ship? Has anyone used these weathering kits on wooden ships?
  22. Done a great job! It's really looking great. This ship is one of my favorites, always wanted to purchase this one but will have to wait until funds are available. So instead I follow your log and dream. Keep up the good work.
  23. I have had he same splintering happen to me the other day. But yeah, if you soak the strips properly before hand its not really a problem. Just be careful as this wood is brittle.
  24. Ah yes, the BOUNTY, I'm not going to ask about the sails but.... What's happened to the copper plates!
