Posts posted by Tobias
Hello Siggi, your craftsmanship is exceptionally great, very impressive. Greetings from Bavaria, Tobias.
- Keith Black, mtaylor, Siggi52 and 1 other
- 4
Good morning Gary,
it is a wonderful and absolutely clean work, much to be admired. It took some time to scroll through your log. Sorry if I've just come across this and have to get back to the beginning of your project, did I understand correctly that you drew the plans by hand, i.e. old school with a pencil? That's really impressive, your bookshelf and all the plans in the roles also fascinate me. Absolutely great performance.
Greetings Tobias -
Hi Greg, this all looks fantastic, really great work.
- Keith Black and mtaylor
- 2
4 hours ago, Nersch said:Hello Mark,
You are doing a really great job. Very neat work!
You are the second modeler I know who uses Castello to build a ship model. I think Castello is much harder than pear wood. What are your experiences? Is Castello easy to work with or would pear wood be a better choice?
Cheers Nersch
Hello Dieter @Nersch , Mark has done a fantastic job so far and serves as a role model for me too.
3 hours ago, a.sorolla said:Hi , No Idea
Congratulations on the work, clean and well done.
Le Rochefort is a ship destined to the supply of powder the fleet therefore the barrels, that samples in the interior of the cargo hold, do not carry metal rings, go recercados with ropes.
You can see it on the cover photo of the monograph book.
as I do not know if the translation was understood well, I put a photo of the barrelsI hope you understand that this is just a comment
Adrián Sorolla
Adrian @a.sorolla your book is worth its weight in gold and is always in use. Thanks for the hint.
- Nersch, mtaylor and Keith Black
- 3
4 hours ago, G. Delacroix said:
Hallo,
Auf Englisch kann "canal des anguillers" übersetzt werden mit: Limber-Holes.
GD
Thank you GD,
from the German forum I was told Nüsterlöcher - (also: "Nüstergat") holes in the lower frames through which the water can flow to the bilge- mtaylor, Keith Black and Dave_E
- 3
7 hours ago, mtaylor said:
Pardon my ignorance but what's a "water groove"? I've not seen nor heard of that nor find a reference.
Hi Mark I mean the recess at the bottom of the frames, unfortunately I do not know the correct name. In this recess is also often a chain installed to loosen larger debris and to ensure that the brackish water can run to the pumps.
- Dave_E, mtaylor, Keith Black and 1 other
- 4
13 hours ago, archjofo said:
Hello Tobias,
by happenstance I found your report here at MSW today.
I know your fantastic work. But it's nice that you also present your work here in this very well known forum.
Hello John, thank you. I came to MSW through Ed Tosti and his amazing Naiad protocol. It's the research that keeps you from just being in one forum. @albert, @No Ideaor you Johann and many others are inspirational for me. I'm also on the road in the French forum to get as much information as possible. Of course you also want to show your model and it's a great feeling when you like it and it's well received.
- Seventynet, marsalv, Dave_E and 15 others
- 18
Hi Mark it is once again a fantastic work. Almost a little too perfect, please excuse me I do not want to complain and hope you do not get it wrong. Your precision is so fine that you can't see the individual boards of the pump well and it looks like it is one big area. I know this too well, if I may suggest the following what I have already done in such a case is that I have slightly touched the individual boards to visually highlight the individual boards. Something like this:
- GrandpaPhil, mtaylor, Mike Y and 4 others
- 7
Hello Matiz it is always fantastic to see your progress and with what accuracy you work. I have a question, in one of your pictures I saw a milling machine in the background. I can't make out the cross table unfortunately, what brand do you have there and are you happy with it. I also have the Proxxon stand and also use the cutter from AMB.
At the moment I come a little less often to La Palme because I have started with Le Rochefort on the side. The first tree nails have found their place. First I wanted to make the nail picture with brass pins, however, I was not sure and have asked precaution at GD. Now it will be tree nails. The first attempt was it with walnut wood this seemed to me but too dark, now I make them in pear and maple.
I treated a small area with sanding primer to see how it worked.
Sanding primer what is it, It is now used by some Europeans and is nothing more than a colorless primer for wood which gives a very nice Finnish. Apply 1 time and work with steel wool and then apply again and polish with 400 sandpaper. Unfortunately, I have learned from colleagues in America that there is no such thing there. Attached are pictures of the product and the Finnish of a colleague.
Image source R. Eschker
Hi Mark fantastic work as always.
- mtaylor, Ryland Craze and No Idea
- 2
- 1
Le Rochefort by No Idea - 1/24th Scale - First POF Build
It's always a feast for the eyes to see new updates from you. For me it is very helpful to see how you show and describe the individual steps, I can only learn for my construction of Le Rochefort.
