allanyed
Everything posted by allanyed
  1. Hi Eric If the hull is going to be painted over or otherwise covered, it does not really matter. But if the planking is going to be uncovered look at the planking tutorials in the article database here at MSW and you will see instructions on starting with lining off the hull and then planking starting with the wales then working down to the garboard and up to the highest strakes. https://thenrg.org/resources/Documents/articles/APrimerOnPlanking.pdf There are differences in some kits' planking, including OcCre where they have planks that are not properly tapered so some of them do not end at the rabbet as they would in real practice (with the exception of a drop strake or stealer if needed.) If you have not already seen them, these four videos are well worth watching as they give an alternative to spiling that works well Part 1 --- https://www.youtube.com/watch?v=KCWooJ1o3cM Allan
  2. When you print the barrels from the 3D drawing you posted they will look MUCH better than the barrel in the second photo. Congrats on going the extra mile, even at this small scale. Allan
  3. The inboard profile confirms these are gratings and a ladder way as there is nothing above the deck indicating a skylight which could be instead of, or in addition to, gratings and ladderway. Pegasus was launched in 1776 and fitted out in January 1777 and the RGM plans were drawn between late 1776 and early 1777 so might be as-built plans. If you look at the Pegasus drawings from 1775 (https://www.rmg.co.uk/collections/objects/rmgc-object-84572) there are differences between this design drawing and the drawing made at about the time of her launch. (https://www.rmg.co.uk/collections/objects/rmgc-object-84573) Greg makes a good point that the clerestory-style companionway may be appropriate, but I just wondered why the kit plans do not match the originals as there is nothing to indicate there was such a companion way. In TFFM David does state that the inclusion of a companion top is a thorny subject, He goes on to say ships-of-the-line had clerestory style lights from about 1750 that could be removed and replaced by gratings. And, as Greg points out TFFM makes note there was a reference from 1779 that allowed sloops of 300 tons to have one companion. As Pegasus sunk two years before that, I am not totally convinced she ever had one, but as with so many things in our hobby, who knows? No matter, I agree with Greg that they add character to the deck layout and you should go with what makes you happy. Allan
  4. Hi Richard This is really interesting. Neither of the QD or inboard profile contemporary plans of Pegasus 1776 show a skylight, just gratings and ladderways. Perhaps the skylight was added later but she sunk 10 months after being launched. I thought maybe the draftsman just left it off the drawing but, while it is a larger ship of which there was a Pegasus (28) 1779 in the group it is very clearly shown on the Enterprize (28) 1774 drawings (second set below). I would think that if there was supposed to be a skylight when launched, it would be on the original plans. If you just leave it off the model, it can be argued, based on contemporary evidence, it never existed. Allan https://www.rmg.co.uk/collections/objects/rmgc-object-84573 https://www.rmg.co.uk/collections/objects/rmgc-object-84575 https://www.rmg.co.uk/collections/objects/rmgc-object-83179 also available in high resolution on the Wiki Commons site https://www.rmg.co.uk/collections/objects/rmgc-object-83181 also available in high resolution on the Wiki Commons site
  5. If the piece is already glued on the model I tape a soaking wet paper towel to the part and rehydrate it every few hours. Takes overnight and then some at times. Another example, but purposely gluing parts together that will need to be separated....... when I have to make very small strips of wood such as window frame pieces that are about 0.025" square at 1:64 I thickness sand a board to that thickness then cut strips with a rule and scalpel. These are never exactly at the same thickness as the original board, but too small to take through the thickness sander one at a time. I glue 5 or 6 pieces side by side with the hand cut edge being the wider face of the glued up strip. I then can run through the sander without worries. Once done I soak the assembly for an hour or so and the glue melts and the pieces come apart very easily. Takes a little scraping of the glue afterwards but otherwise a relatively easy task. Thicker pieces take longer but can be done. The hard part for me is having patience. Allan
  6. David Antscherl goes into great detail on how to make realistic binding, middle link, toe link and preventer plate in The Fully Framed Model Volume II pages 262-265. Way to much to post here, but as he is a member, hopefully he will see this and post some information from his book. Allan
  7. Clamps are great tools when needed, but that should not be very often IF the parts are pre-fitted before gluing them together. This includes planks if they have been tapered and pre-shaped properly. A tapered and spiled (or pre-bent) plank will hold after about 30 seconds of finger pressure with PVA, same as with CA and will not lift from edge bending. If it lifts and/or does not hold and springs loose it is not yet properly shaped and needs to be re-worked or replaced. Allan
  8. Welcome aboard the good ship MSW Kai! Allan
  9. Hi Chris Happy retirement to you!!! It can be an adjustment, and not only for the retiree😁 Not to stir up a hornet's nest (yabuhebi?) but maybe consider studying the four part video on planking done by MSW's own Chuck Passaro. It will make things much easier for you in the future as well as yield realistic planking. Part One can be found at https://www.youtube.com/watch?v=KCWooJ1o3cM This will help you eliminate all the lifting you are getting from cold edge bending. Is there a reason your log is in the 1801-1850 section rather than the 1750-1800? Many folks enjoy following the various Victory builds so might be missing yours as it was launched in 1765. Allan
  10. Well said B.E. I did a 1:64 drawing to see if they show up and they are quite clear when printed. I am guessing that it would not be difficult to include a sketch or verbal instruction about these hoops even if supplying material is impractical. Allan
  11. Hi Chris I looked at a number of contemporary drawings of masts and as you say, the wooden hoops on either side of the wooldings are not shown on any that I have seen. Looking at photos of contemporary models they all have the wooden hoops above and below the wooldings but these are all 1:48 scale so a good bit more noticeable than they would be at 1:64. Allan
  12. Hi Glenn, Sorry if this was raised before. There are no wooden hoops shown above and below the rope wooldings on the masts which I thought was always done so they did not get chafed or move on the mast. Was it not as common as I thought or could this have been an anomaly on Indefatigable? Regardless, she continues to be a superb build. Allan
  13. There have been several threads on this here at MSW, but I do not recall ever seeing any information based on contemporary sources regarding the finish appearance which could be interesting. Glossy finishes on modern fiberglass and steel hull yachts is common, but for warships I was taught that a matte finish is more realistic. This may not be correct, but wouldn't it make sense that the last thing a warship needs is a glossy finish so it stands out? I am pretty sure high gloss finishes were not done, but in the end, go with what makes you happy. Allan
  14. ......if you are referring to the main stay and main preventer stay. If you are referring to the forestay and fore preventer stay, the collar was put on double from about 1733, not single like in the photos above. In addition, after 1773, the collar closest to the sprit was an open heart, not a closed heart. The drawing below for the forestay and fore preventer stay collars is from page 41 in James Lees' The Masting and Rigging of English Ships of War. Putting a double collar may not be practical or easy at 1:100 scale. Allan
  15. Hi William Your work at this scale is quite impressive. Regarding the collars, am I correct in thinking that they are main stay and main preventer stay collars, not forestay and fore preventer stay collars? Thanks Allan
  16. Hi JJ Looking REALLY good! Your attention to details is great and if you do go forward with offering a kit it will be a worthwhile investment for any kit builder. The knee of the head is spectacular, especially the tapering which is not commonly seen on the majority of modern models. Allan
  17. I would like to add my own welcome back Mark. Missed your posts! Allan
  18. Tiziano, This continues to be an unbelievably beautiful build. I truly hope we can meet again soon as we are planning to be in Toscana in September. Ciao Allan
  19. What actual diameter do you need? One idea that comes to mind if I am picturing this correctly, you can run bamboo through a draw plate to the largest diameter you need for the mast then taper as needed with sandpaper. My preference is to start with bamboo skewers or chopsticks and split them to a workable size, then run them through the draw plate holes until I reach the diameter I need. Allan
  20. I am not sure this is what you are looking for, but check out the information on the clipper Young America in Ed Tosti's build. If not, the build log may still be somewhat useful for you. Topping lifts are explained and described in post #2683. https://modelshipworld.com/topic/3453-young-america-by-edt-finished-extreme-clipper-1853/page/90/#comment-535631 I believe he derived the information from Bill Crothers drawings. While this is centered on American clippers, there may be some application for your English vessel. Allan
  21. Welcome to MSW Peterairfix! Allan
  22. Well said Chris!
  23. The price seems favorable and I really hope it turns out to sell well for them, but there looks to be a number of other inaccurate things including the size and number of rudder hinges, the gun patterns, belaying pins, which were not used in that time period, missing wooden bands above and below the rope wooldings, gratings with huge openings that would break an ankle in a heart beat and more. I wonder why they chose to add another version of San Felipe rather than something different that has not be put out in kit form up to now. Allan
