allanyed
Everything posted by allanyed
  1. Jay, The third nail (pin) is so simple and effective. Thanks for sharing. Allan
  2. Cabra Very nice working hinges on the doors. What is the second photo of the last group about? Sorry to ask if you described it previously, but I did not see it. Thanks, Allan
  3. Very nice write up Nigel. The explanation of slicing away the planks from the tissue sheet while the glue is semi cured should be heeded. Too soon will see some tearing but too late is as described previously, possible but difficult. For those in the states, I bought a pack of black tissue at Michael's some years ago and I think they sill carry it. Allan
  4. Andy You may find it beneficial to join the Wasa group, of which Fred Hocker is an active member and Clayton Johnson is the administrator. The deck planking thickness is different on each deck. Not only does the length of each plank vary, the widths vary as well. There are plans of the deck planking that may help. Fred's book on the Wasa may be of interest as well. http://warshipvasa.freeforums.net Allan
  5. Mike, In my opinion, the time to add sails is never. Unless they are furled, and/or your model is at least 1:48 or larger they are very difficult to make to scale and rig so they hang naturally. I have done sails on a number of schooner models that are 1/4" scale only because the client always requires it but I use at least 800 thread count linen or better, 1200 TC if I can find it at a discount price. I will probably try silk span on the next one. If you feel you must include sails, the thinnest you can probably readily find is silkspan. It comes in three grades, starting from the lightest, 00, 000, and SGM. I believe all the new stuff is polyspan. I also suggest you get a copy of David Antscherl's TFFM Volume 4 to get a great source of information on rigging. If you want to go with silkspan Google K&S White Aero Silk Covering for information and sources. Good luck Allan
  6. Frank, Never too old to learn I say. I had never heard of the ballentine before, but once I saw it, I thought, ah, yes, just like the beer symbol! Allan
  7. Hornet, I have been using lengths of PVC pipe for years, but your idea is much better. I just cap the ends, then there is the pain of getting the wood out, and water, no sink near by, etc. Your way has easy access to a visible area to pick out what you need while leaving the rest in place. Cudos. Allan
  8. Daniel, You can get a copy of Darcy Lever's The Young Sea Officer's Sheet Anchor on Amazon for about $10-$15 and it explains a lot. The following is from Lees book on rigging that had this picture from TYSOSA. Allan
  9. Thank you Pat, your comment is very much appreciated. One more BIG thank you is to Bob Friedman of Seawatch Books. Getting this book in print was loaded with visits from Murphy, but he made sure it got done when others would have said stop, it is not worth the grief or costs. Allan
  10. Magnificent Ed, Getting the planking to fit so tightly takes well cut planks to start and some pretty ingenious clamping and wedging methods. As great as it she is, you are making it look too easy! Any fine tuning you have encountered and care to share as you are progressing would be welcome. Allan
  11. I received an email that made some very nice comments and noted that I gave credit in the book to several people whose help was critical in getting the book as close to right as possible. I would like to give them the credit due them here as well. They all provided information that was of immense help. David Antscherl, Gary Bishop, Richard Endsor, and Wayne Kempson all had a strong hand in helping me get it done for which I am immensely grateful. Allan
  12. Monello, I assume you know of all the plans available at NMM, many of which can be found on their web site. Details abound! http://collections.rmg.co.uk/collections/objects/79916.html is but one example from 1765. Now, start making some saw dust! Allan
  13. Monello, One does not have to start small, nor with a kit. I believe you can do it. About 1976-1982 I built Victory and actually sold it, then built it again. Both were scratch and my first completed models so I know you can do it. (They were NOT as big your model will be) I look forward to following your build log. Allan
  14. Michael, Assuming the keel is horizontal and not a tail dragger, if you put a square on the "ground" and the blade vertical and against the fore or aft side of the cant frame, or any frame for that matter, it should be flat against the blade, that is, 90 degrees to the ground. If this is not clear, let me know and I will post a photo this evening. The cant frames are canted fore or aft, but are still vertical. The following sketch may help. Allan
  15. Bravo on what is the best cross section build I have seen in a long long time. Allan
  16. Newton, No worries, we are all here to help one another in any small way that we can. Allan
  17. Clearways The stations are round so I don't think etching would work. Some brass rod of various diameters and a bit of silver soldering is all that is needed to make them. They are painted white based on the photo posted by Nenad so no blackening of the brass is required. Just a bit of cleaning before painting. If you are not experienced in silver soldering, fear not ! The thought of silver soldering was rather intimidating to me before I gave it a try. Once I made a few soldered joints I was hooked and never again used CA, soft solder or epoxy for joining brass. Allan
  18. Danny While the very very high quality of your work is obvious, your step by step series of photos is terrific and a great help to anyone that has not yet put together a bow from scratch. Making and fitting these parts is truly a challenge, but you have shown in a very clear way that it is a matter of patience more than anything else. Allan
  19. Yam(?) My first visit to your build. Lovely. In reading the posts, I did not see the scale for this model. Is it 1/4? Thanx for sharing. Allan
  20. Rob, The Janka Scale hardness for Tulep is 540 where as the poplar that we commonly see in the US is 500 and bass is 380 for a comparison. English box is 2840 and Holly is 1080. Best way to find out if it can be used is to try a few pieces and see how you like working with it. Allan
  21. Ben, A glossary is a good idea. I should have thought about this a bit more and maybe could have squeezed one in, but we were right on the edge for the number of pages to get a low cost book. I hope the drawings will answer a lot of the questions though. Worse comes to worst, if there is a term that needs an explanation, please post it and I am sure it will be answered quickly by some member if I don't respond. Great find Don, thanks for posting it. Allan
  22. Hamilton, What scale is your Fair Rosamund? Trennals (trunnels, treenails, trenails, tomato, tomahto) for the deck planks were relatively small. In addition, they were often seated below the surface of the deck planks then capped with a wooden cover piece so the end grain of the trennal was not exposed. If you are at 1/4 scale and you want to use and show treenails, go for it. They were probably no more than an inch diameter or less. The smallest hole on my Byrnes draw plate is needed to get this small. Not an easy task, even using bamboo. If I was building at 1/8 scale, I would not show them as I have no way of making them small enough. 3/16 is a close call but doable (look at Ed Tosti's Naiad build log for evidence.) IMHO, out of scale trunnels and hatch gratings are the easiest way to ruin the look of an otherwise fine model. Allan
  23. For small boats at 1/4 scale I plank with holly and work from the keel up. On the hull of the ships themselves I start with the wales then add the thick stuff strakes above and below the wales. I then add the garboard as it can be tricky then do the planking in between the lower thickstuff and garboard strakes. Last, I do the planking above the thickstuff which lies above the main wales. Just the way I have gotten used to, not necessarily THE way to do it. Allan
  24. Thanks Jay and Pat. I am sorry I was not the only one having trouble with the font size in Steel. I am glad to know that increasing the size is a help to at least one more set of eyes out there. I agree that a flat surface like a desk or bench is easier for using the book. Hard cover costs would have doubled the cost of the book and we really wanted this to be affordable. The binding used though does make the left and right page of each folio align better than Steel or the Repository. Allan
  25. VERY VERY Nice work. Love the blocks and also the use of the milling set up. Allan
