Everything posted by yvesvidal
What a fantastic build and what a beautiful model. Like many others following this Build-Log, I have a few questions: - Scale? From the size of your tree nails (0.5 mm -> 24 mm) I assume this is 1/48th scale. - Plans? I assume these are from the French Publications ANCRE. I could be wrong. - Wood(s) used ? - Are you using glue? I see nails all over the place and practically no evidence of glue, anywhere. You are an artist and it shows. If you use a little bit of glue, what is it? Thank you for taking the time to answer these questions and all my gratitude for showing us such a masterpiece. Yves
You are not sparing your energy and creativity to represent Sultana as it is today. Fantastic work. Yves
- 222 replies
- sultana
- model shipways
Does anybody have some experience with CAF Models ?
yvesvidal replied to yvesvidal's topic in Wood ship model kits
Tom, Chuck, Thanks a lot for the detailed explanations. Being French, let me know if there is anything I can do to help you with your negotiations between CAF and ANCRE. ANCRE's researches are exceptional and their work on various subjects deserved to be acknowledged. I certainly hope you will quickly obtain an agreement with them, as it would be a pity that their work do not get translated into kits. Both parties would benefit from it, in the sales of kits and of books. Please, let me know when you are in a position to resume the manufacturing of that beautiful kit. Thanks Yves -
yvesvidal posted a topic in Wood ship model kits
I was wondering if anybody on this forum has had some experience with CAF Models? I see that they are advertising on the side Bar of the FOrum, but tried to contact the owner of the company at the suggested E-Mail with no success. The E-Mail address is invalid. Specifically, I wanted to know more about their Chebec (Le Requin) in the 1/48 scale. From the pictures, it looks like a fabulous vessel and I have always loved the shape of that boat. Yves -
HMS FLY by cafmodel - 1/48
yvesvidal replied to cafmodel's topic in - Build logs for subjects built 1751 - 1800
Your kits seems to bring the hobby to a whole new level. Yves- 59 replies
Beautiful diorama that you are preparing. Yves
- 69 replies
- diorama
- Glad Tidings
Well, this is what I have been working on, for the past few days. The cold weather has been slowing me as I can only paint outside (cans). The effort has been concentrated on the display for the Discovery vessel. I want to represent it orbiting around Jupiter as it completed its mission, after getting rid of the crew. The frame is 48 inches by 18 inches (diorama) and is made of premium pine of 1.5 X 0.75 inch. I have used that kind of wood and know that it will hold very well in time, without any warping. The frame is glued and re-enforced by metal corners. The "T" shaped pieces will be used to hold the vessel. Two 3 mm rods are taking care of holding the long Discovery in its cradle. In retrospect, 4 mm would have been better but I did not have the special nuts that went into the model. I will compensate the lack of rigidity with some brass tubing. The rods are also electrical conductor for the lights. The concept seems to work.... It is now time to paint... Primer first... and then final paint: two coats of gloss black. Now, the holders can be permanently mounted with 4 mm screws: In the meantime and while the weather was preventing me from painting the frame, I tried to approach Jupiter in two ways: Artistic painting and Pictures from NASA: The picture is of course more accurate but presents the drawback to show the seams of the paper sheets, when you place your nose on it. I could have asked FedEx to print it for me on glossy paper but that would cost more than $90 without any warranty that I would be happy with the result. I can always go back and do that later.... The painting is more beautiful with vibrant colors and is for the time being unfinished. I have used Liquitex Soft Body artistic acrylic paints diluted with a tiny amount of water and airbrushed on a foam board. The tormented Jupiter atmosphere is done with a regular brush. People who have seen both, told me they like the painting better..... So, this is what I will be using until I refine the painting with more details and a fine mist of white on top. After mounting the vessel, this is what we are getting: Of course, that sky will require a few stars and a couple of moons to be more realistic. It is relatively easy to swap the background, so I may try the picture solution, even though I like my painting a lot :-) - Crazy project, don't you think? Yves
Yes, Isopropyl alcohol will remove acrylic paints. It can be a good thing (when you goof off) or a bad thing (as you know....). Yves
- 120 replies
- crabbing skiff
- Chesapeake Bay crabbing skiff
- (and 3 more)
And so, did this kit was ever made available in the USA? Sincerely, I doubt it will be and the Trumpeter kit (although plastic) will fill the niche of that incredible vessel in 1/200 scale. The Revenge designed by Chris Watton took quite a few years to be proposed by Amati. The Victory (1/64) also designed by Chris Watton is still not available, years after the kit has been delivered to their office in Italy. I am not holding my breath on this one, even though the Parts were distributed in Europe a few years back. Yves
Beautiful colors selection. You are turning this little kit into a masterpiece. Yves
- 22 replies
- Grand Banks Dory
- Midwest Products
Delf, You are starting a fantastic kit here. Chris Watton's realizations are top notch and I have been following his work for many years. The structure of the hull seems to be the MDF parts that Chris started using for the Victory that he designed for Amati. I will be following with a lot of interest. Yves
- 725 replies
- vanguard models
- speedy
In parallel to the building of the frame to display the model, I am starting the antennae module, containing the infamous AE-35 device that is the reason HAL 9000 invokes to terminate the astronauts aboard the Discovery: The parts are very delicate and the main cross was broken in my box. A coat of German Grey before applying the white color on top. Below is a picture of Stanley Kubrick, inspecting the original antennae prop built for the 2001 Movie: Yves
All these round shapes do not make the planking easier.... You are doing a good job on that delicate part of the construction. Yves
So, you are testing the water with a scratch build, before going for the big challenge? Very good idea. Yves
