yvesvidal
Everything posted by yvesvidal
  1. I will be following this Build with interest. I love Calder Craft kits: they are incredibly well put together, have all the details you need to finish the model and always depicts unusual and endearing vessels. My brother built a few of their kits and they are just fabulous. Yves
  2. Haze, Superb work on that hull. Could you describe in more details, the type of coating you are using to fill up the gap lines of the printing? I have used some generous coats of primer on my 3D printed Corvette and it turned out okay. However, for smaller scales such as 1/72, one need a smoother surface to make it look more realistic. Yves
  3. Oh my God !!! Dumping all this acrylic resin around you beautiful model..... That must be a tough decision. It is looking very good. Yves
  4. Beautiful model Craig. It is really hard to believe this is 1/700 scale..... Very realistic and exquisitely painted. Yves
  5. This is promising. I came to build models, after watching my father for hours and hours, as a kid. What a wonderful teaching ! Yves
  6. Very elegant ship and beautiful kit. I will be following that unusual model. Planking? I agree with you and would do it over. Yves
  7. Beautifully done Ras. I like the white board in the background.....it really helps when you install riggings and tie knots. Yves
  8. Alan, Where is the spool holder installed on your printer? Did you place it as much as possible to the left top? Do you have the small brass eyelet guiding the filament into the feeder? I just cannot explain why the filament would snap like this, coming out of a fresh and new spool. Unfortunately, this printer does not detect the lack of filament, as other and more sophisticated printers do. I wish they could retrofit this nice and important feature in the Ender-3. Yves
  9. Veszett, I do not believe you can easily print stanchions for multiple reasons: 1-You have to design them as they are not provided in the kit. So, you need to go in Sketchup or Blender and create a stanchion model 2-Printing a small cylindrical shape is delicate and does not work very well, if you do not use support. 3-The resiliency and solidity of the printed PLA is way too fragile and brittle for such small stanchions. That is why I ordered some brass stanchions and I am waiting for them. I am not planning to weather the Corvette. I really suck at weathering. Instead, I will be presenting a freshly painted and renovated ship. Thank you for the compliments about the wooden deck. I like it a lot, too. It brings a nice contrast to this mountain of plastic/PLA. Yves
  10. Beautiful barrels !! Will you fill them up with some red wine? Yves
  11. Alan, I am so happy you are making good progress with the hull. All the other parts, with perhaps an exception with the stack, are easier to print. Especially the decks and cabins. That little cat is cute...is that the one provided with the printer? Yves
  12. The texture is perfect for people who like to build "distressed" models, as most Corvettes are usually represented. The material is perfect and very conducive to rusty streaks and other imperfections. Yves
  13. Craig, No, only the major components are provided to give an overall appearance of Modified Flower Class Corvette. There is plenty of room for Photo Etched sets and finely detailed resin sets, especially at this large scale. The kit provides a foundation to build a decent model, but details are coming short, unfortunately. One of the things I do to add a few more details, is to resize certain "provided" components. Before slicing, you can increase or decrease the size and shape by playing on the 3 axis independently. I am also adding some details with styrene strips and tubes. When I see what is available for the Matchbox/Revell Corvette, it makes me drool with envy..... However, in that scale, you have to shop in different directions. For instance, I am desperate about finding 20 mm high stanchions with two holes. If I was in Europe, Amati and Billing Boats offer these at a reasonable cost. In the US, I do not know where to go.....and I need a lot of them. HELP !!!!! Yves
  14. Quick update: the Hull is now finished !!! Portholes have been filed and markings added. I am just missing the measuring ladders and will probably go with the decals recommended by an earlier post. I need to work on a display board, to present the model and protect it, at the same time. Yves
  15. A quick update on the portholes and hull. As mentioned before, when the hull is printed, the portholes are solid since the kit is created for RC usage and navigation. In my case, I drilled all the ports with a 4.5 mm bit. Now has come the time to fill them up. I am using an almost magical chemical, that has the capability to fill up a hole up to 6 mm diameter with a white goo that turns crystal clear after a few hours. You also need a tooth pick and with a rotation of the hands, you create a ring of the goo, inside the portholes. Below you can see one that has dried and one porthole that was just filled up: Because the hull is very thick, I used a second application of that magic goo, after the first application dried. It filled up quite well the holes and looks a lot like the heavy glass used on the real ship. Finally, for the decals, I went with one of the suggestions and printed the decals on thin paper sheets, carefully cut them, soaked them in PVA diluted with water and applied them carefully to the hull. A little sponging on top and voila.... It is not too bad overall. Yves
  16. Beautiful job on the barrels. Yes, that is a lot of work but these details are important. By the way, I am glad to see that you are back working on The Coureur !! Yves
  17. Also, the designer of the kit had a mistake in the stack files. I noticed him and he quickly sent an update that you should be able to download (or he may have already embedded it into the complete list of software). If you do not see it, just request it from Benjamin. On the right side is the corrected stack. Yves
  18. Alan, I wonder if your bed is getting to the right temperature (60 degrees). If you have access to one of these remote thermometer (they use them to "welcome" you at the doctor office), you may want to check the temperature of the bed in various locations. A drop in temperature will cause the print to unstick. Did you get another glass bed? Yves
  19. Funny you did this... I was doing the exact same thing on my Corvette, too. Yves
  20. Allan, make sure that the rollers of the Y axis (Main axis protruding in the front) are tight. There is a way to adjust them. Without the rubber rollers tight the bed can rock and move and will never be flat/horizontal. Yves
  21. For the portholes, I am going to try building the glass using that special chemical (name escapes me for now) from Microsol. As far as the temperature goes, the model is static and will not sit in the back of a car, for hours in the sun.... But yes, you are right, PLA may start loosing its shape at temperatures where we would all be dead anyway (60 degrees is when the cells of your flesh turn like egg whites on a frying pan). So I am not too concerned. Yves
