SJSoane
Everything posted by SJSoane
  1. Siggi, That is a beautiful hooked scarph joint in the last photo! Mark
  2. Hi Siggi, I was away for a few days, and I missed this entire discussion about the mouldings. I enjoyed catching up, very interesting conversation. The drawing from Falconer looks like the best evidence, and it is closer in time to the Tiger. I did notice that the Falconer drawing shows a waterway that is probably not accurate. It looks like a wedge sitting on top of the deck planking, while most other evidence says that it would have been a thickened and shaped plank sitting on the deck beams. Does this call into question how the other details, like the mouldings, are drawn? I would still be inclined to follow the Falconer drawing for the mouldings. Best wishes, Mark
  3. Hi Ed, It is looking quite wonderful. What a great series of lessons on metalwork, clipper rigging. I have a question about the jackstays. Were there any fastening devices to keep these from sliding out of the eyebolts? Or were they ever intentionally slid out? Mark
  4. I have spent a tedious weekend fairing up the lower edge of the upper two strakes of the wales. I had made each plank a bit oversize in width, concerned that the careful fitting of the hooked scarphs could throw off the outer edges slightly, and this proved to be the case. The upper edge is fair because of the batten, but the lower edge wavered a little from plank to plank. A simple matter to draw a line parallel to the top with the compass, and a not so simple matter of then fairing to the line. I had to use a coarse riffler in places, followed by a sanding block cut to the radius of the wale. For some reason, sanding was very slow, perhaps because I was not keen to use a coarser sandpaper and risk marring the lower edge. Oh, well, who is in a hurry? Mark
  5. Siggi, it looks great. I am noticing for the first time, how straight the fore edge of the stem is, in relationship to British ships later in the eighteenth century. Very distinctive! Mark
  6. That step is like finely crafted furniture! What is the wood? Mark
  7. Beautiful work, exquisitely crafted. Mark
  8. Oh, my, those quarter galleries look difficult and complex! You are doing a great job. Mark
  9. Gary, The planking is looking really great. Are you going to leave some of the side un-planked to show the framing? Mark
  10. druxey, I truly married up, but not enough to share sharpened chisels. A ding in an edge could challenge the best marriage...
  11. Thanks, Håkan, we moved to a rural area in Montana with limited resources like shops, but beautiful views. druxey, my wife is not only a retired architect, but also furniture designer (two of her designs are in the Kirkland Museum of decorative arts in Denver). The lightning bolt is a prototype for a candlestick holder she is working on. We share the shop, split right down the middle. We share most tools, but not my carefully honed chisels....🙂 Mark
  12. Finished the last port plank in the upper two strakes. Now I need to trim up the lower edge before beginning the final two strakes. I got this done just in time, because you can see in the third photo a lightning bolt is about to attack the ship from my wife's side of the shop... Mark
  13. Siggi, It is looking great. You are inspiring me to try to move faster! I notice the line you have drawn for the sheer rail, the next line of thicker planking further up the side. It does not match up or align with the "knuckle" or sharp bend in the foremost frame. It may be different in your ship, but in mine the two line up (see photo below). Best wishes, Mark
  14. Thanks, druxey and Ed, you have both caught me from mistakes in the past, and please keep checking up on me! In this case, I followed the advice in the Naiad book and in David Antscherl's Fully Framed Model books, and planked the counter some time ago. Although it hasn't shown in my recent photos, I see. Here are photos from a few years ago when I planked the counter. The photo from the port showing the wales underway does raise an interesting question on this, though. I had started to shape the wale to the counter on the starboard side, as you can see, but I quickly realized that I was likely to damage the counter because I could not see very well upside down. I assume I will have to turn the hull upside down again, and then shape the wales to the counter. And as long as I am at it, I wonder if it would be a good idea to color the wales upside down, where I can really see the critical painting edges between the lower edge of the wale and the hull (which remains unplanked in this model style), and between the wales and the counter. I also need to try a few samples of coloring, which at this point will include Fiebing Leather Dye, Speedball ink, or possibly airbrushing with diluted acrylic paint. I am looking for something revealing the wood grain slightly, but I don't want to mess with a top coat of tung oil which I see has caused some problems for others in the past. As Ed well advises, I will test extensively off the model first! Best wishes, Mark
  15. Hi Gaetan, I have been thinking about your projector experiment. I have attached a diagram showing what the issues might be. In the first diagram, showing the project and ship hull from the side, if the light source is a single point, then the image lines will radiate away from the source. An image at X is projected to a greater Y on the projected surface, but the image will be an even greater Z at the hull. The second diagram shows the setup in plan. If the light source creates parallel rays, the image on the projected surface will be accurate, even around the curve at the bow. But if the light source is a single point, as in the third diagram, the distance on the hull at Z will be greater than the distance at Y on the projected surface. and the curve at the bow will not be accurate. You could avoid this problem if you could take each point on the projected surface, and then project it onto the hull exactly at right angles to the projected surface. Maybe this could be done with your laser beam. Just some thoughts in your very interesting experiment! Mark
  16. Two pieces to go. I discovered, when recutting the upper, sternmost plank of the wale, that leaving it much longer than necessary helped with steaming to the correct shape. Having a little extra length reduced the springback and gave a better purchase when gluing. Sometimes, as in the case of my first failed blank here, cutting rough blanks too close to final size is "penny wise and pound foolish". New lessons learned all the time. Mark
  17. Siggi, Very nice, and also very fast with perfect quality. Did you steam or heat bend the plank in your jig? Mark
  18. Hi Gaetan, I look forward to seeing the results of your experiments. This would indeed be a very useful tool. Mark
  19. Hi Gaetan, So are you projecting the sheer drawing onto the side of the hull, for marking off things like the wales? Mark
  20. Siggi, Your figurehead looks great, so early in the project. It gives a strong indication of the quality yet to come. I imagine it also keeps you thinking, "everything needs to be as good as the figurehead"! Best wishes, Mark
  21. Hi Doris, Nice to see you back, and with this exceptional project. Mark
  22. thanks, Russ and Hubac'sHistorian, a great deal of the fun for me in this hobby is the miniature joinery. Very soothing when one is not in a rush; file and test fit, file and test fit, file and test fit.... Mark
  23. calling all clamps, calling all clamps, report to the port side... After going off in a huff and recovering my composure, I got going again. Just four more planks to install on the port side, upper two strakes (blanks are next to the screwdriver in the photo below). This is a big step, because it locks in the two sides longitudinally at about the same level of humidity. Good days for working in the shop here in Montana. We hit minus 11 degrees fahrenheit last night, the town of Butte about 180 miles away hit minus 24 degrees, the lowest in the lower 48 states, and the wind chill factor on the eastern plains hit minus 36 degrees. Not much point in going outside. I can only begin to appreciate how cold it got on a winter North Atlantic station, or rounding the horn, taking in sail. Best wishes, Mark
  24. Alan, Once I walk away from mistakes and eventually regain my composure, I think of my restarts as just practice. It sounds like you got some exceptionally good advice. My own gunports benefitted greatly from striking a line along the length of the hull, so I could see how each flowed to the next. Without seeing the overall line, it would have been too easy to slightly misalign and you would never know until it was all done and too late. Having said this, I haven't quite regained my composure on my own recent Bellona mistake; I will follow your lead in this! Mark
