captainbob
Gone, but not forgotten
Everything posted by captainbob
  1. Michael, I agree. If you can't find the tool you need, you need to make it, That's what builders used to do. Bob
  2. Martin, thanks for looking in and the comments. Yves, this will be the admiral’s boat. But I like the older wooden workboats and fishing boats. I’ll let the others play with their guns and square sails while sit back and admire their skills. PopJack, I enjoy working with brass. This is .005” thick and the mast where it is fixed is .125” - .156” diameter. I think that is a little small to solder. The solder would fill the .025” holes for the lines, so it is crimped and glued. I recently modified a set of new pliers to help in the brass work. I bought bent long nose pliers because they did not have the box joint and then ground off the ends leaving only about 1/4” of grip. I use these to crimp the brass around the mast with sharp corners and also to flatten the end of a wire as a stop or to drill a hole through it. Bob
  3. Thanks Popeye, it had to be. Jay. Thanks and yes I couldn’t make the turnbuckles that small so I used brass tubing. Thanks John. Bob
  4. Thanks, JMaitri and Lawrence, for stopping by. And now it’s time to start the rigging. I would like to be able to write all kinds of words to describe the rigging but I think the pictures can say it much better than words. So here is a start on the standing rigging of the main mast. More later. Bob
  5. Let's see, the lobster twins, Oh yah, one dressed up for pleasure while the other had to do all the work. Hey, Popeye, Ya think ya can do that? LOL Bob
  6. Beautiful bow, wood, brass, wrapping, All great. Bob
  7. Popeye, Good job on the planking but if you continue with these diversions “I was to do this as sort of a diversion from rigging the Goth...........” , you will have a fleet that all need rigging…… Be carful, be very carful. Bob
  8. Thanks, Piet, I understand the matter of economics. Swiss pear, cherry, maple or boxwood, I’ll have to see about getting some. I also like to make all things on the boat work but it gets more difficult as the scale gets smaller. You’re doing great. Bob
  9. Brian, It should. I usually don't cut planks from walnut or mahogany but I do use a straight edge. With this setup you hold the wood against the stop underneath while you cut against the straight edge on top. Should be the same. Bob
  10. I always cut my planking from 3 or 4 inch wide sheet. If the planks are from a 1/32" thick sheet, I tape a brass bar 1/32" thick by 3/4" or 1" wide to my table, leaving the front edge of the brass without tape. I then use another brass bar on top, overlapping the first by as wide as I want the plank. Now I can slid the wood under the upper piece of brass until it rests against the lower piece of brass and I have an edge to run my blade against. With this setup I can cut as many planks as I need. Bob
  11. Piet, Given a choice, what wood would you have used instead of Poplar? I've always worked in poplar or bass wood but I'm thinking of trying some other woods. Bob
  12. Popeye, It doesn't matter what color sox you wear, you're still doing a fine job. Bob
