Everything posted by wefalck
These boats had indeed a very lofty rig. There is not a loft of wind here in the Paris region and in addition the Bassin d'Argenteuil is surrounded by high trees (e.g. poplars as can be seen on many of the Impressionists' paintings). Plus, the main westerly wind direction is blanketed by the range of wills to the South and West of the river. I gather that these hills also make the winds blowing downwards with eddies forming in the valley. The Northern side is mostly flat, but the Seine has cut into the old flood-plain a few metres. Overall not a good sailing range, but it was easily accessible from Paris. While in later years 'real' yachts with quite deep keel were sailed on the Bassin, a boat with a drop-keel and 'live' ballast is more appropriate for a river, such as the Seine. This limits how high you can make the rig in order to not create a too big fulcrum - although a high rig might catch more wind in the valley. I gather that is is why they extended the length of the rig, in order to be able to set more sail. During races these boats needed quite a bit of live ballast. I seem to remember seeing photographs that showed four people on board, but I don't remember, whether sandbags were still used on the Clippers. Nice 'iron'-work on the bowsprit, btw 👍
- 153 replies
- Ancre
- Bruno Orsel
I have not done any military modelling since my early 20s back in the mid-1970s, but I do recognise and appreciate a good paint-job 👍 Techniques have come a long way since, when 'dry-brushing' was all the rage among modellers. I always wondered, whether all these speciality products are really worth the money ? In many cases they just seem to be diluted paints or specially packaged and labelled pastels. I didn't have the time to sit through the videos - how did you the excellent wood effect, what paints (I don't mean brands) did you use for it ?
Yep, cast-iron is the thing. Makes it difficult to move things around, but that's a good point also. I have seen this brand of tools/files around, but can't really say anything on their quality from personal experience. The manufacturer NIQUA (https://en.niqua-shop.de) caters for the jewellery industry, so for a professional market. One has to pay attention though, as many manufacturers have different tool lines for markets with different purchasing power.
Coming on nicely ! I quite admire the designers of such kits. Doing a one-off and tweaking things to fit is one thing, but here you have to get it completely right so that the customers do not complain about poor fit etc. I remember those folding seats along the corridors from the old days. Today there are mostly open-plan coaches with no corridors.
Depends on what material you want to part and what diameter. BTW, small lathes don't have a lot of torque. A good old-time method for larger diameters (say > 5 mm), albeit today frowned upon by the HSE, is to to make a first cut with a parting tool and then to finish off the parting with a fretsaw at low speed. It also saves you material as otherwise you will have to make stepping cuts to prevent the parting tool from becoming jammed.
It seems that prototype practices varied over time and region (as always). However, if anything was gilded than it may have been only certain details or elements, to provide highlights on otherwise decorations painted in ochre. Conversely, contemporary models often show a more liberal use of gold, being decorative objects already in their time. I gather, the question is, do you want to show the ship as she appeared in real life or do you want to create a decorative object ?
Mini lathe for mast making etc.
wefalck replied to Charlie pal's topic in Masting, rigging and sails
I would strongly advice against using 'highest speed' in an electric drill, when the outboard end is unsupported. A slight bend or imbalance in the material can result in a serious whip-lash effect and inflict injuries in you ... 😲 BTW, once you have a lathe, you will find hundreds of uses besides just turning spars. -
As usual, it would be helpful to state what nation and period the ship is from. Practices have changed over time and were different in different parts of the world. It is generally safe to paint over almost anything with acrylics, as their main solvent is water with some alcohol added in some cases. The solvent in enamels may attack the varnish or whatever has been put onto the cast gun carriages. However, it may be difficult to get acrylics to stick on certain surfaces when painting with a brush due to their hydrophobic properties. When using an airbrush, this tends to be less of a problem.
Good to see that the crew will not slip under the table - at least not from the heeling of the boat ...
It depends on the material used for the foam. There are, for instance, acrylic foams (essentially foamed-up Plexiglas) that are longer stable than styrofoam. The reason is that they do not contain plasticers. On the other hand, a German kit company sold for a while hulls made from styrene foam extruded into a mould. I got one when I was around 6 or 7, built a crude model from it (my first 'semi'-scratch project) and eventually discarded it in my late 20s I think, when I cleared out some storage space in my parents' garage - if I remember correctly, it did not show appreciable signs of degradation, also because it had not been exposed to daylight really (being painted). I would consider the foam not as a structural element per se, but rather something that helps you building up the hull around some structural members. That then you would cover in some sort of skin, that would remain stable, even if the foam degraded.
@Bedford, you are absolutely right, the battens were tightend by shallow wedges driven in from opposite sides under the clamps. Apologies for not having modelled them, but I believe they are stored below deck, when not in use @Pat, thanks for your kind offer, however, it seems that we are able to generate a fairly steady supply to my toolbox 🍷
Can't help you with the Port, could also have been a Sherry though - accumulated many of these corks for painting such small items and figures over the years.
Thanks, gentlemen ! Keith, I need a glass of port afterwards to calm my nerves down, so I accumulated quite a few corks 🥴 *********************** Completing the skylights 3 The skylight above the officers’ mess in the rear of the ship is the only one for which a close-up photograph exists, so the details can be reproduced with reasonable confidence: The skylight above the officers’ mess (Laverrenz) The basic structure, again, had been built a long time ago and now it was painted as per prototype. The top of the skylight was removable and presumably could be replaced with a more solid hatch-cover in bad weather – the main deck is only a couple of feet above the CWL ! The tarpaulin to cover the hatch would be held down with battens for which clamps were provided on all sides. The battens and the clamps are laser-cut from 0.2 mm Canson-paper and were then soaked in zapon-varnish to harden them. The battens were built up from two layers. Battens and clamps were assembled and then the assemblies cemented to the skylight using satin acrylic varnish. Painted skylight, battens and protective grille before assembly As opposed to the others, this skylight has outside protective grilles, that are fastened with hinges. The frame had been etched from 0.1 mm thick nickel-silver (I couldn’t get brass sheet that thin at the time). Etched-in notches on the underside ensured that the bars would be equally spaced. The bars are made from 0.1 mm brass-coloured copper-wire glued in place with varnish. This assembly then was cemented to the skylight using acrylic varnish. The officers’ mess skylight ready to be fitted to the model To be continued ....
Waterways
wefalck replied to Ron B's topic in Building, Framing, Planking and plating a ships hull and deck
John, I had a quick look into my mid-19th to early 20th century textbooks on iron shipbuilding, but didn't find any drawings. However, it is mentioned in the text at several places. -
That's a really clever idea to solder a brass tube into a halfround groove in order to avoid having to shape the somewhat complicated outside profile. In my simple mind I would have attempted to do this with a half-round end-mill ...
Running Rigging Line Color Differences
wefalck replied to Keith Black's topic in Masting, rigging and sails
I think most people would use the same colour for aesthetic reasons on 'presentation' style models. If you dress up your (waterline-)model in workaday conditions, then the rope would/should have different colours as Jaager was already indicating. I have indeed done this on scenic presentations of models. -
Waterways
There are different profiles and the waterways may actually be composed of several pieces of wood in cases. The basic objective is to turn what would be an acute angle between the deck and bulwark into an obtuse angle. Acute angles would collect water, which then can lead to rot. The same logic applies to iron- or steel-ships. Here the gutter is formed often by two angle-irons running along the edge of the deck at some distance apart. One angle buts against the bulwark, the other forms a frame for the wooden deck (as noted above). The space between the angle irons typically is filled with cement to form a rounded gutter. This also prevent water from collecting in the corners of the angle-irons. -
The invention of wind-powered sawmills (waterwheel-driven sawmills predates this, but there was not waterpower in Holland) is attributed to Cornelis Corneliszoon through a set of patents: BONKE, H. et al. (2004): Cornelis Corneliszoon van Uitgeest. Uitvinder aan de basis van de Gouden Eeuw.- 209 S., Uitgeest/Zutphen (Stichting Industrieel Erfgoedpark 'De Hoop'/Walburg Pers). The above book also unravels, in a 'popular' way, the supply chains of woods for shipbuilding and other construction. I don't know, whether there is an English version of the book. It also puts the shipbuilding into its wider economic and social context at an European level. Essential the invention is one of the foundations of the Dutch Golden Age.
Thank you very much, gentlemen, for your kind wishes and the praise ! ************************************************************ Completing the skylights 2 Work on the skylights continued with the one over the pantry. The basic structure had been completed quite a while ago, including the protective grilles. Now, the upper part was painted in Vallejo ‘wood’ and then with a couple of coats of Vallejo ‘transparent mahogany’. Several thin coats of Vallejo ‘satin varnish’ gave the ‘wood’ some depth. The lower part was just painted white. A chimney was turned from a piece of 2 mm brass rod and slotted at the top to simulate the vents. It was chemically blackened to simulate the appearance of heated metal painted black. The completed skylight – rear view I only had side and plan views of the belfry and there is no photograph in which it is really visible. The bell of S.M.S. NATTER survived and is now in a museum-collection, so that we know what is looked like. I invented the shape of the belfry and drew it to be laser-cut. The parts were assembled in the usual manner using zapon-varnish. The bell was rough-turned on the watchmakers lathe and the actual ‘bell-shape’ finished with a hand-graver. I don’t really know, whether this is correct, but the belfry was painted white. Finally some ‘hinges’ to the raising panels of the skylight were added in form of pieces of 0.1 mm wire. The completed skylight – front view To be continued ....
That's a clever idea, this jig for the grabbing-line around the lifebuoys. Have to keep this in mind, as I also have to make a couple of them soon. The lifebuoys I have seen, and the German late 19th regulations stipulate the same, seem to have the line attached with a strip of heavy canvas around the ring, rather than a serving line. I will use some very light silk paper, like cigarette paper, for the purpose. You fire buckets also look good ! I am not a fire-fighting expert (Kurt van Dahm here would be ...), but believe that sand is used only on electrical equipment (would there be electrical lighting on AMAPÁ ?), on material that could with water and thereby releasing heat, or when no water would be available (say in forests). Besides, the sand in open buckets would become wet very quickly from the rain and spray - and there is no shortage of water on a ship You could give the buckets also handles made from wire ...
Most navies in the decades after around 1850 did undertake tests against mock-ups of wooden walls and armour to better understand and select the various types of guns and projectiles. I have copies of French naval artillery handbooks that have dozens of plates that show the results of such tests, for instance.
