guraus
Posts posted by guraus
Thank you very much Sergey.
Stockholm tar, it is possible you are right and I will check in that book. This won't really be an issue as I don't plan to rig the model anyway but even so having the right number won't hurt. Thank you.
Regards,
Alexandru
- Кутузов Сергей, Obormotov, mtaylor and 1 other
- 4
Hello Hobbie,
I visited Victory several years ago and I had less than a day as we left from London in the morning by train and we returned in the evening. I can give you two advices a bit contradictory for your visit:
- do a lot of detailed pictures - you will be glad later. Be prepared for them: I emptied two sets of batteries doing that as I had to use a lot the flash for the interior.
- take the time to "take in" the ship. I regret now as I didn't have much time to do that and I've seen the ship basically through my camera lens.
With that said I wish you a great visit.
Here are some more progress pictures on my model Still working on the forecastle, but closing in fast.
Regards Alexandru
- Stockholm tar, gjdale, mtaylor and 14 others
- 17
Just wondering, "is ebony hard to work with?" I believe that, it's a very brittle wood.
I don't think the ebony is difficult to work with. Except for the black dust it makes (my power tools are always connected to the shopvac when I work with) I kind of like working with. Once you understand you can't really bend it and stop trying to do that, it works fine. Cuts well, file or sand very well, very nice to turn or to mill. It is forgiving some times as say you did a small hole through it in the wrong place - you just put a drop of white glue in it and file/sand the top a bit: the black dust will fill the hole and it becomes quasi invisible black on black. Is ideal for making moldings.
As is quite expensive - especially the real African deep black ebony - I have a special scrap box only for it in which I keep every small piece I cut off for potential future reuse. At the wood store I bought a while ago pen turning blanks and what they call "cut-offs" sold by weight form their scrap box. I am well stocked for a while.
Hope this helps,
Alexandru
- WackoWolf, michael mott, mtaylor and 2 others
- 5
- paulsutcliffe, gjdale, mtaylor and 21 others
- 24
G'day
I love your details and beautiful stanchions. Do you have a master copy to do the lathe work or are they each crafted to be the same?
Greg
Hi Greg,
There is no master template and copy. I do them one by one using the first one as model on which I take the measurements and try to match the subsequent as much as possible. They are similar enough but not identical.
Alexandru
Hello all,
Quarter deck almost complete - missing last two beams - somehow I counted them wrong. I still have to add several hanging knee and lodging knees too.
Before someone asks, in the before last picture the space for the companionway between the first (lower) two beams is shifted toward left as in the plans.
The upper deck below was oiled as there will be nothing else that needs to be glued to it.
Regards,
Alexandru
- Seventynet, Vivian Galad, albert and 18 others
- 20
- 1
- Model Mariner, mtaylor, Philg88 and 17 others
- 20
Further to the raised beakhead platform issue:
The original beakhead was part of the upper deck. It aligned with the lowest point of the main rail of the head in the ship as originally built. This headwork was rather old fashioned and deep. When the headwork was replaced with a higher 'modern' one, the main rail was also constructed at a higher level and the additional platform added to line things up again.
You can see this on the original draught and compare this to the ship as she now is.
Druxey,
This is the most pertinent explanation of the difference between draughts and existing ship. Thank you for clarifying this to us.
Alexandru
I can't get over the scale of this project. How much does it weigh? Beautiful work, and excellent choice of woods.
E&T,
I didn't precisely weighted it but based on the effort I need to make each time I take it out from my basement for the twice a year exhibitions I participate I would estimate to be about 40kg or about 90pounds. A bit heavier each time.
Alexandru
Mark,
Thank you for contributing to the beakhead deck debate. Your input is appreciated. Unfortunately for my model is now to late to change anything - it will have a raised platform as there is one in the Victory in Portsmouth. Was that there from the beginning or not I don't know. I personally find it suspect to loose all that space (between the two decks) on such a crowded ship.
Greg
Thank you for appreciation of my work.
Alexandru
- Jaekon Lee and Obormotov
- 2
Proxxon Micro MBS 240/E Band Saw Review
in Modeling tools and Workshop Equipment
Posted · Edited by guraus
I have this same saw for several years now and I was very happy with it, but recently no more. Last month alone it broke 5 blades with very light use - and they are 23$ each. I don't know what is wrong with it but I don't think the issue are the blades.
Here is what happens: after installing a fresh new blade and a little usage I start hearing a repetitive noise like the blade is hitting something at each turn and shortly after the blade breaks ALWAYS at the welding point. When the toc-toc-toc noise starts the blade will break even if it turns empty without cutting anything.
I always buy the same Proxxon blades from Amazon and I don't think the problem are the blades. I think that in time the saw parts got worn by extensive usage and miss aligned. I am not an expert by any measure but what I can see is that the plastic on the two wheels is worn and I am guessing the blade does not sit true on them and get a bit twisted which makes it hit the guides and after a while it breaks. The upper guide is three bearings and the blade touches their exterior rounded part but the lower one is just a notch in a piece of steel. My money are on the lower one.
I just got a new batch of 4 blades and I will try one without the lower guide - see what's happening.
If someone has more experience with these tools and can share some light on what could be the cause of this problem, I would greatly appreciate.
Regards,
Alexandru
