Everything posted by Mike Y
Made a very ugly jig made from plexiglass sheets, to get a straight 90 degrees for all dimensions when gluing the frames. Looks working, now I am trying not to rush things and go slowly, one-two frames a day - glue should set, so frame will not get skewed.
- 969 replies
- hahn
- oliver cromwell
Pardon a stupid question, but how the hull will handle the changes in humidity, temperature, etc? If I understood correctly, it is a monolytic hull, all bulkheads and spacers are glued together. The ship is long and narrow. How do you save it from twisting? If humidity changes, how the stress would be reliefed without a hull deformation? P.S.: yes, I am a member of the Overthinkers club for years
- 191 replies
- young america
- clipper
Thanks Albert! Your Naiad is one of my unreachable targets, it is soo beautiful! Patrick, thanks, if only I can have enough time to build it as fast as I want! Life offers so many interesting things, and just a few hours a day when you can enjoy them...
- 969 replies
- hahn
- oliver cromwell
Current state of things: not so much modelling, more of a summer activities, camping, etc. Ordered a set of engineering squares to glue the frames straight. Still waiting for the shipping... Will start cutting remaining frames in a meanwhile
- 969 replies
- hahn
- oliver cromwell
Thank you, Antony! Will try not to dissappoint Omega1234, nope, better focus on getting one model done with a better quality. At least, that is the plan so far
- 969 replies
- hahn
- oliver cromwell
Sanding is finished, dust washed away! Covered all frames with poly, they are drying now. Just realised that I actually have two models now! One made out of "yellow-ish" pear, and the one from the "pink-ish" pear. The yellow one is used as a training model. I am practicing on it to avoid some mistakes on a real model. For example, as you see on a background, I installed 9 frames on a training model - and realised that: a) Not so easy to align frames to 90 degrees in all directions, need to make a jig to set the frames square. Even without gluing frames to the building jig, the construction is rigid enough for fairing, no need to glue in any fillers or spacers. That worried me for a while, because I will have one side fully unplanked, and installing fillers on one side only might cause hull asymmetry.
- 969 replies
- hahn
- oliver cromwell
Jack, Grant - sure, let it be flat! Covered keel and four frames with poly, give it a day to dry
- 969 replies
- hahn
- oliver cromwell
Tested two different types of wipe-on poly. Same producer, one is shiny, one is flat. Test pieces are cut from the same piece of wood, same part of the piece, so without finish they are completely identical. The difference is quite obvious with a real eye, and my camera (and/or photo skills) is not good enough to show it properly Shiny finish is unnaturally shiny, and makes wood look a bit darker. Will go with the flat one, it is barely visible, and preserves the natural color of the wood, while providing some basic protection. Natural light: Flash:
- 969 replies
- hahn
- oliver cromwell
Please do not go away! Your critics is always very welcome! And I have a hard time trying to name different sides of a frame...
- 969 replies
- hahn
- oliver cromwell
Of course, there is a reserve on the outer and inner edges of a frames. I am sanding the other part, "flat" side of a frame, it will not be affected during fairing.
- 969 replies
- hahn
- oliver cromwell
Skeleton finished, will cut the rabbet after covering it with wipe-on poly. In a meanwhile, experimenting with different finishes to find the right one for me. Now sanding the sides of the frames, very stupid process that I was trying to delay as much as possible Aiming to get a consistent 7.4mm thickness to make sure that frames would be properly aligned. Hope to finish it this week, sawdust is covering the table, bleeh! And nobody will see the difference anyway...
- 969 replies
- hahn
- oliver cromwell
Got distracted with other things - summer is coming, and I suddenly ended up buying a real boat.. Of course it needs maintenance, cleaning, parking, blah blah, so not so much time for a modelling. Got guns and carriages from Syren Ship Models: And working on the stem: Here is the previous version for comparison: As usual, joints are blackened with a tissue paper and reinforced with treenails. Stem is not fully accurate, knee is simplified, but decided to keep it simpler on a first fully framed model. Hope to finish the skeleton during May, and start sanding and mounting 20 midship frames.
- 969 replies
- hahn
- oliver cromwell
Stabilizing a bandsaw (edited by moderator)
Mike Y replied to Nirvana's topic in Modeling tools and Workshop Equipment
Rubber mat might not help - the body of the bandsaw acts like a big resonator... Learned it a hard way -
Proxxon Bandsaw - owner feedback
Mike Y replied to rtropp's topic in Modeling tools and Workshop Equipment
I have that saw, it is actually powerful. I use it instead of a scroll saw, works very wekk. Ripping planks - well, it has enough power, but it has no fence, so how are you going to keep a consistent thickness? -
Thinking of getting some source of compressed air to blow away the dust and sawdust from the details before applying the finish, for example. Is there such thing? There are many kinds of compressors in the market, which one would be useful for such usecase? Maybe the airbrush compressor? I also see the cans with compressed air, are they powerful enough to remove the sawdust? Any ideas are welcome, wiping away the sawdust with a soft cloth does not really work in a tight corners. And I need to clean the model from time to time, can't always store in a case..
Got some cool stuff for my build today! Hope it will improve the accuracy. Really love the micro dremel - good balance, easy to align to a 90deg angle (I do not have a drill press unfortunately). And on a low speed it is very quiet comparing to a regular dremel - meaning that I can use it while my daughter is trying to fell asleep. And optivisor is beating the expectations - how I managed to live without it before??? Clean view, light on a head, good lenses.
- 969 replies
- hahn
- oliver cromwell
HMS Naiad 1797 by albert - FINISHED - 1/48
Mike Y replied to albert's topic in - Build logs for subjects built 1751 - 1800
Aah!.... -
Thanks for a nice words! Jack, found the monofilament on amazon: http://www.amazon.com/Skysper-500M-Fishing-Nylon-Black/dp/B00R71DEF8/ It is the largest I found. Actually wanted something like 0.6. The bigger sizes are around 1.5mm, they are made for tennis rackets. I saw your ebony solution, amazing! But I worry that black ebony dust will make pear around it dirty when I sand the frame. Is that a problem?
- 969 replies
- hahn
- oliver cromwell
Slowly progressing with the keel / stem / stern assembly. Finished the deadwood and the slots for the wing transoms. Instead of chiseling, made that slots by gluing a wood strips and sanding it down to a smooth surface. (Tar simulation is done with a black paper again). Simulating the iron bolts with 0.5mm black monofilament: It is a little bit not to the scale, should be 0.52mm instead of 0.50 (assuming that original bolts were 1 inch thick). But that is the biggest monofilament I found. Maybe on a next, true replica model will use the real iron bolts (with the heads). But this time - a small simplification. Only one side of a frame has a bolts, because another side would be fully planked anyway. Lots of sanding ahead - need to go through 240 -> 320 -> 400 -> 600 -> 1200 -> 2000 grits to achieve a consistent thickness of a frame and a smooth finish.
- 969 replies
- hahn
- oliver cromwell
