Everything posted by augie
Where were all you guys when I was there back in '79????? You could have helped out with the language barrier
Can you give us an idea about your block tumbler? Oh, you need another doctor . You need a week at home to verify your 'normal' status !
And shall next year find you both ready to celebrate. For now, duty calls.
- 753 replies
- finished
- caldercraft
The 'roughing up' of the metal surface is the key no matter what kind of adhesive you use Robert. Sarah has the right idea.
Robbyn - I 'pin' all my channels and pinracks with wire. I'm using 28 gauge on Syren. I first stand my piece on edge and drill small holes into it, maybe 1/16" deep +/- and set in the wire with CA so that it sticks out about 1/16" +/-. Then i press that piece very slightly where it's going to go to leave slight marks from the mounted wire. Then I drill those holes out, checking to make sure the piece fits exactly right. Then I glue it with CA. That little bit of wire makes a huge difference. You can also use the technique on fife rails. Darned, Andy beat me
- 773 replies
- san francisco ii
- artesania latina
Great to hear you're up and around and back in the shipyard. No wonder your ship looks so good ----- you don't fool around. NICE!
If you ever need to get rid of the shine from that CA 'superglue' try some Dullcoat flat lacquer. There are several brands out there. I use Model Master by Testors, available in most hobby shops. Comes in handy (trust me).
Floyd didn't want to depress you by telling you that those 'long handles' are really long........like 25-30 feet. Not exactly like rowing your sweetheart around the local pond!
- 127 replies
- model shipways
- syren
Off to a great start Sjors. Those deadeyes can be finicky little bits but they get easier as you go along. Don't be like me and get impatient. You are just at the beginning of making her spectacular.
Hang in there Popeye......you could always hit the high, hard one. Just watch out for slider!
- 377 replies
- america
- billing boats
Nice work on that bowsprit, Ron. Short sleeves only from here on out and resist the urge to catch that pair of forceps you're going to drop. This is the one 'sport' where good reflexes work against you!
- 240 replies
- supply
- caldercraft
Hi Scott...and welcome aboard MSW. You'll get a lot of opinions on adhesives. Many here don't use CA and prefer PVA wood glues. I use both but I'll confine my comments to your CA question. IN GENERAL, the thicker the CA the longer it takes to set. Thin is the fastest but it can really get all over the place (including you). Medium is a little more versatile. Also, the thicker it is, the stronger the bond. The CA's are debonded with acetone ---keep that in mind if you glue your fingers together. None of them sand very well and you always run the risk of sanding away your wooden part and the offending CA is still there. They can also leave a 'shine' so have some 'Dullcoat' flat lacquer handy if you need to cover that. As if it doesn't set fast enough, they sell accelerator. This can actually be useful with the thicker grades. Some folks report they are allergic to the fumes so be careful if your working inside a confined space (like inside the hull) and you have your face right in it. If you try and use it on a painted part, it will grab the paint and not the part. Any force will take the paint and part off. What I do there is roughen the painted surface before I glue it. Or even poke tiny holes in it to allow the CA to penetrate. Hope this gives you some ideas.
With your talent, the rigging will bring her ALIVE!
- 377 replies
- america
- billing boats
