Posts posted by Pete Jaquith
My work shop is located in the garage which I share with the family automobiles. This caused me to design mobile work tables based on industrial shelving components from the Container Store. As illustrated, this provides a solid work surface that will easly handle small shop tools. I currently use four such 2' x 8' mobile tables.
Pete Jaquith
Shipbuilder
Welcome to the Topsail Schooner "Eagle" 1847 build log,
Next step was mast fabrication. Key points include:
>>> Mast and trestle tree construction details based on period practice
>>> Rigging ironwork used Bluejacket castings, Bristol board mast bands, and silver soldered brass fittings
>>> Lower foreyard and fore topsail yard use working yard truss and yard parrel fittings
>>> Mast rigging setup per rigging setup lists
>>> Tackle blocks fitted to fore deck before mast/fife rail installation (below fife rail)
>>> Masts will be further outfitted prior to final installation
Next posts will address sail making/installation
Pete Jaquith
Shipbuilder
- fnkershner, russ, mtaylor and 4 others
- 7
With the deck furniture complete, I moved on to the "sticks and strings" building phase. Key points include:
>>> Rigging setup lists identify fabrication/rigging setup steps
>>> Spar fabrication sketches prepared from working drawings
>>> Spar taper based on parabolic camber rules
>>> Spars were birch dowels turned on a mini-lathe (often using sanding sticks)
>>> Spar construction details typical of mid 1800's practice
>>> Rigging ironwork combination of Bluejacket castings, Bristol board bands, and silver soldered brass fittings
>>> Yard truss, topsail yard parell, and boom sheet assemblies are working fittings
>>> Rigging setup (fitting of blocks and rigging lines) completed prior to installation
Pete Jaquith
Shipbuilder
- Rudolf, fnkershner, hexnut and 3 others
- 6
Latestarter,
Bob has summarized the process I have used. Working from the stern post forward and keel up is based on the copper plate overlap practice utilized in North America during the mid 1800's. I recall seeing material that some naval ships in the late 1700's were coppered from the waterline down, and this would change the plate layout and installation sequence. As Bob has noted, there is no such thing as a stupid question.
Regards,
Pete
John,
I don't have my drawings here, but I seem to recall a sketch in the Instruction Manual that shows the gore line. Also, maybe the museum plans will assist. I have attached pictures of my "Eagle" 1847 coppering plan and the model application as I coppied the "Kate Cory" in my interpertation.
Regards,
Pete
John,
I will be watching your build log as "Kate Cory" is a fine looking vessel and she is definitely on my bucket list.
With respect to coppering:
>>> If you are using copper tape carefully finish your hull 1st as any blemish will show through the finished tape
>>> As you noted, varnish or finish your wooden hull prior to coppering
>>> You might consider completing and painting the upper hull prior to coppering to minimize handling damage
>>> Your "Kate cory" drawings/instructions should show the gore line as I used it as an example for my "Eagle" 1847 build
>>> I have posted my coppering process here on MSW; additionally, my "Newsboy" 1854 and "Eagle" 1847 show coppering pictures
Best of luck on "Kate Cory",
Pete Jaquith
Shipbuilder
Thank you for your interest and comments on "Eagle" 1847,
Before starting masts/rigging, I will cover fabrication and installation of the ship's boat. Key points include:
>>> Ship's boat was fabricated using Bob Hunt's mini-practicum on Ship's Boats
>>> Ship's boat was fabricated from laminated basswood sheet with a CL bulkhead
>>> Boat interior was carved out using rotary tools (picture attached)
>>> Oar locks were silver soldered
>>> After painting, the ship's boat was rigged to the boat davits
>>> Final installation and boat's outfit will follow rigging completion
Following posts will address masting, rigging setup, sail making, and brining it all together.
Pete Jaquith
Shipbuilder
- Tim Curtis, hexnut, Ekis and 3 others
- 6
Finishing up with the deck furniture, key points include:
>>> Main sheet horse fitted
>>> Shinkicker steering gear design/fabricated/painted/installed
>>> Steering gear design based on "Eagle" 1847 and "Kate Cory" 1856 drawings
>>> Belaying pins fitted to poop deck rails
Pete Jaquith
Shipbuilder
- dgbot, fnkershner, Aussie048 and 6 others
- 9
More material on deck furniture. Key points include:
>>> Hatch covers and coamings stained/painted
>>> Ringbolts fitted to hatch covers
>>> Hatch covers and coamings installed
>>> Fore mast tackle blocks fitted prior to fitting fwd fife rails
>>> Companionway, fife rails, and poop ladders painted and installed
>>> Fwd smoke pipe fabricated/painted/fitted
>>> Fore staysail and fore sail horses fitted
>>> Windlass brake handles fitted in stowages inside fwd bulwarks (not shown on plans)
>>> Anchors, chain pipes, and anchor chain fitted
>>> LESSONS LEARNED - WHILE MANY SHIP MODELS SHOW RINGBOLTS FOR HATCH BOARD LIFTING POINTS, RECESSES WITH CROSSING STRAPS WOULD BE MORE APPROPRIATE - I WILL DEVELOP SUCH A DETAIL ON FUTURE MODELS
Pete Jaquith
Shipbuilder
I have not researched pre 1800 practice, but many ship models of that period do not have gore lines. Possible other MSW Members with experience in that time period could assist.
Regards.
Pete Jaquith
Shipbuilder
Welcome to the "Eagle" 1847 build log,
Additional details on deck furniture include:
>>> Coamings, house bulkhead assembly, house top, and companionway top left loose to facilate painting
>>> House top planking run parallel to house sides (vs. parallel CL on original plans)
>>> Stove pipe added (not on original plans)
>>> Two elm tree pumps fitted (one shown on plans but it would not work effectively with CL keel assembly)
>>> Water cask fitted on CL
>>> Water cask planked over solid basswood plug
>>> Mahogany binnacle fitted to aft house bulkhead
Pete Jaquith
Shipbuilder
- LHS, GrandpaPhil, hexnut and 3 others
- 6
Proceeding with the deck furniture. Key Points include:
>>> Fwd companionway dimensions critical as it fitts between the anchor windlass and fore staysail sheet horse
>>> Hatch boards fitted to sub bases set into coamings
>>> Fife rails constructed from laminated stripwood
>>> Fife rail stanctions Bluejacket castings
>>> Aft house bulkheads laminated on sub bases (see separate notes on deckhouse construction, similar to "Newsboy" 1854)
>>> Sub asemblies designed to fit together and left loose to facilate painting
>>> Final assembly / installation after painting
Pete Jaquith
Shipbuilder
- avsjerome2003, Jeronimo, dgbot and 9 others
- 12
Thank you for your interest in the "Eagle" 1847 build log,
With the hull, bulwarks, rails, and hull outfit complete; the following posts will address deck furniture and associated deck outfit. These chapters of the build will work from the bow aft and include the following:
>>> Fwd companionway & smokepipe
>>> Hatch covers & coamings
>>> Fife rails
>>> Fore staysail, fore sail, and main horses
>>> Poop ladders
>>> Anchors, anchor chain & rigging, etc.
>>> Main house
>>> Elm tree pumps
>>> Water cask
>>> Steering gear
Pete Jaquith
Shipbuilder
Kurt,
On the 3/16" model I felt both the fittings and drawing were small (binnacle & anchor windlass). It was my judjment they were just too small. In my modeling, I try to consider each part and assembly in terms of its full size dimension. When in doubt, I compare with other plans/books on period practice (e.g. bulwark timberheads, cap rails, plank width, etc.; also applies to rigging lines & blocks). With this approach, I try to keep all parts/assemblies in proportion.
Regards,
Pete
Kurt,
As best I can recall, I made the following changes to the plans:
>>> Anchor windlas increased in size ~30-50%
>>> Binnacle increased in size ~30-50%
>>> Fitted stowage for windlass brake handles on fore house front
>>> Fitted (2) boats vs. (1) on plans
>>> Boats increased in size ~30%
>>> Fitted (2) water casks (not shown on plans)
>>> Fitted (2) pumps vs. (1) on plans
>>> Fitted smoke pipes to fore/main houses
>>> Fitted ships bells fore/aft
>>> Fitted fore top vs. cross trees shown on plans
>>> Fitted studding booms and irons to fore yard and fore upper topsail yard
Note that the size increases noted above may not apply to 1/8" scale plans as they may have used the same fittings on both the 1/8" and 3/16" scale kits.
Regards,
Pete
In my Topsail Schooner "Eagle" 1847 and Brigantine "Newsboy" 1854 build logs you can observe my interest in mid 1800's merchant sail. I see these as beautiful ships and an excellent focus for my ship modeling. Time permitting, future plans for this series include:
- Topsail Schooner "Eagle" 1847 - scratch build, complete
- Brigantine "Newsboy" 1854 - kit bash, in process, ready to set up rigging
- Merchant Brig "Volante" 1853 - scratch build, future
- Whaling Brig "Kate Cory" 1856 - kit bash, future
- Clipper Ship "Flying Fish" 1851 - kit bash, future
- Pilot Schooner "Mary Taylor" 1851 - kit bash, future
- Pilot Schooner "Phantom" 1868 - scratch build, future
Other competing build candidates include:
- 14 Gun Brig "Fair American" circa 1780 - kit bash, in process, hull planking working
- Steam Salvage Tug "Foundation Franklin" 1918 - scratch build, future
- Steam Tug "Seguin" 1884 - kit bash, future
Pete Jaquith
Shipbuilder
- avsjerome2003, fnkershner and mtaylor
- 3
Gary,
This is how I covered the poop bulkhead location:
>>> Poop bulkhead was moved aft slightly
>>> Poop bulkhead was designed as portable panels assuming they would be removed "when in action" (I believe this was typical practice during this period)
>>> This layout will permit rigging the aft cannons
My 14 Brig "Fair American" build is currently on hold as I complete my full scale shipbuilding project in North Vancouver, BC Canada. As time permits, I will post a "Fair American" build log once "Eagle 1847 is completed.
Pete Jaquith
Shipbuilder
Floyd,
As best I can recall, the poop rails were constructed as follows:
>>> Rail base sits on poop deck planksheer, a continuation of the cap rails
>>> Caprails/planksheers were fabricated from 3/64" x 3/16" stripwood w 3/64" double bead trim (curved counter planksheer fabricated from 3/64" sheet wood)
>>> Rail bases were fabricated from 3/32" x 3/32" stripwood (counter base fabricated from sheet wood)
>>> Rail stanctions were Bluejacket castings
>>> Upper rail were fabricated from 3/64" x 1/18" stripwood (counter rail fabricated from strip wood)
>>> Corners were half lapped
>>> Rooster tails (boat davits were integrated into the rail base)
>>> Care should be taken to keep rail stanctions vertical although P/S rails lean inboard forward (to clear main shrouds)
>>> I believe I drilled stanction holes in base using upper rails as a template
>>> Poop rails were assembled in place
Regards,
Pete
Next steps address installation of deadeyes and poop rails. Key points include:
>>> Deadeyes were Bluejacket castings
>>> Poop rails fabricated from bass strip wood (counter rails fabricated from sheet stock)
>>> Poop rail stanctions were Bluejacket castings
>>> Rooster tails (boat davit) fabricated from bass strip wood
>>> Poop front rail was an addition to original plans
Pete Jaquith
Shipbuilder
Floyd,
It good to hear from old friends!
Regards,
Pete
Next steps include installing the bowsprit, Samson post, anchor windlass, spray rails, etc. Key points include:
>>> Bowsprit setup with cap bands, cleats, etc.
>>> Bowsprit sub-assembled with Sampson post and anchor windlass components
>>> Bowsprit sub-assembly fitted
>>> Anchor windlass fitted
>>> Foward cap rail sections fitted
>>> Catheads fitted
>>> Spray rails fabricated / fitted from basswood sheet stock
>>> Ship's name fitted on spray rails
Pete Jaquith
Shipbuilder
- fnkershner, GrandpaPhil, Rudolf and 4 others
- 7
Next steps include the design and installation of copper sheathing. Key points include:
>>> Copper layout includes upper/lower gore strakes with no WL dressing belt (typical of small trading and whaling vessels)
>>> Copper layout similar to whaling Brig "Cate Cory"
>>> Copper plates 1/4" x 3/4" (16" x 4' 0") copper tape cut on rotary card cutter
>>> Copper plates embossed on two edges with fine pounce wheel
>>> Waterline located with use of surface guage
>>> Blue painters tape strips used to layout/guide plate installation
>>> Plates cut to shape at gore and waterlines
>>> Some trimming of plates required at WL under counter
>>> LESSON LEARNED - Brigantine "Newsboy" 1854 COPPERED WITH PLAIN PLATES; I PREFER THAT LOOK OVER EMBOSSED PLATES
Pete Jaquith
Shipbuilder
- Elmer Cornish, fnkershner, druxey and 5 others
- 8
Eagle 1847 by Pete Jaquith - FINISHED - Topsail Schooner
in - Build logs for subjects built 1801 - 1850
With spars and masts complete, attention turned to sail making. Key points include:
>>> Sail making was based on Robert Hunt's mini-practum Making Sails
>>> Material was thin cotton muslin
>>> Stitching was done on an old second hand Singer sewing machine
>>> Sail design based on working plans with details from Steel's Elements of Mastmaking, Sailmaking, and Rigging 1794
>>> Rigging setup (blocks and rigging lines) per rigging setup lists
Note that sails only approximate real sails, and they change the look of the model by shifting your eyes from the hull and deck furniture to the masts, sails, and rigging. I will post a separate set of notes on sailmaiking.
Pete Jaquith
Shipbuilder
