Posts posted by glbarlow
5 hours ago, VTHokiEE said:
of one of my 76 gauge HSS bits in a pin vise:
I found these particular drill bits to be junk. They broke faster than I could use them. Too bad as they seem like a good idea in their design. (The cheap ones, not the one in the pin vise).
I think whatever color you like is the color you should use, there is no right answer. It looks great.
Nice work on the belfry solution, end grain char is the worst. I have some luck with a #11 blade but if tolerances allow sometimes I hit ever so gently with the Byrnes sander. That of course wouldn’t work on the belfry, hence another creative solution by Derek.
- DelF, Ryland Craze and BobG
- 2
- 1
I’m sure he means butt joints. He’s new to the hobby, don’t see a reason to call him out.
- Keith Black and LyleK1
- 1
- 1
Have you corrected the garboard plank? Any planking will be difficult without that happening.
For LN I’d advise you just do a full length plank. A shift butt pattern on so small a hull would be aggravation you don’t need first time around. You can see my Cheerful build to see one, but on my LN I just did full run for the reason I note.
My advice anyway.
- LyleK1, Dave_E, Keith Black and 1 other
- 4
On 1/20/2022 at 1:03 PM, BobG said:
how they look when they are made from wire.
Let’s see yours on your Flirt build😊 I replaced all hooks and belaying pins on mine.
3 minutes ago, hollowneck said:
most everything else about this kit is very precise.
I think Chris’ point was the doors are a precise rendering of the actual plans, even though he’s not sure what they’re for. And if Druxey doesn’t know….
- Gregory, Ryland Craze, mtaylor and 1 other
- 4
Keeping in mind the wind and weather was always coming from aft quarters my best guess is to keep some of that from hitting food being prepared or fueling the fires on the stove, nothing more than a wind break. I’m with BE though, while I appreciate Chris being true to the design I’ll leave it off because it obscures a view below the forecastle I’d have spent time building. No one is cooking anything on my models.
- chris watton, mtaylor and hollowneck
- 3
I recommend a Byrnes sander, there are many more angle cuts in our future.
The planing is a great approach, I just don’t have enough experience in using one, I’d take out half a bulkhead😳🤣
Using shades…a true artist you are.
- mtaylor, hollowneck and Blue Ensign
- 3
I really wish Chris had those boats when I built four of them the old hard way for Vanguard, Chris is making it easy for us. I agree that setting up right is a much better look and no problem fitting out for someone with your skills.
The masts look nice, making them from anything other than kit walnut dowels is a big step up. I plan to do the same again with Flirt in boxwood when I get back to her. Meanwhile it’s one plank at a time for me.
- chris watton and mtaylor
- 2
14 hours ago, Blue Ensign said:
Yellow Ochre
Great choice, I’m a fan of Admiralty Paints version, I prefer it over gold (and white), seems more realistic, to me anyway.
Your stern is looking great, creative and just bold enough.
- mtaylor, Blue Ensign and Rustyj
- 3
9 hours ago, hollowneck said:
Heat-shrink tubing
Left the black card behind a long time ago. The shrink wrap tubing works well, I have a selection of sizes but it can be challenging to heat it just the right amount, clearly BE has that down. These days I prefer black masking tape, more of an iron look that artist tape and easy to fit and then paint to complete the look.
- BobG, hollowneck, mtaylor and 3 others
- 6
Well done, impressive work. I enjoy following your progress.
Congratulations on finishing your Cheerful. It looks great.
I believe the boats are always sitting up to make them faster and easier to launch, but i could be wrong. The leather dye is an interesting choice, but I recall from using it back in my time the army as being a total mess to work with. No matter how careful I was it wound up in places I didn’t want it and near impossible to remove. Still a nice effects, you seem to have kept it in control.
- hollowneck and allanyed
- 2
2 hours ago, DelF said:
as pedantic
Thanks for defining “huge,” I knew we could count on you😂🤣
6 hours ago, DelF said:
plenty of scope for exercising personal preference.
A really good point to remember for some that want to point to a book and deem themselves as purveyors of truth and historical accuracy. My answer is more simple, the dark brown looks better on the model than black, and is my personal preference.
On another note, the guy that climbs that rope ladder along the mast is braver than me, and just how huge are those deadeyes and the rope making up the shrouds. 😳
15 hours ago, fnkershner said:
Can you tell me where to install it.
There are instructions for the stove on the Syren website. I suggest reading those.
- FrankWouts and scrubbyj427
- 2
HM Sloop Echo 1781 by VTHokiEE - 1:48 - Cross-Section
I’d be interested to know what that is. I’m fine using a pin vise, all the rotary ones I’ve found are either too fast or too bulky and mostly both.
