glbarlow
Posts posted by glbarlow
  1. That ‘gap’ is pretty standard, it is also on my Winchelsea.
    On my Surprise I’ll defer adding that rail until most everything else around the stern is finished. While building Winchelsea I became very good at knocking it off multiple times. I’ll also paint that top to match either the trim or the shingles before adding the rail, me having less nimble fingers than James.
    I like how it’s coming together.
  2. t’s been a long while since I posted. Mostly because there isn’t much new I can offer on rigging. However I didn’t want to abandon a log on such a nice Vanguard model, so here’s a bit of an update:
    The standing rigging is complete other than the crows feet, not sure I’m going to add them.
    Once again, I do like my quad hands, really not sure what I’d do without them. All sorts of angles and height I can reach, not to mention a steady platform for tying the endless amount of block and rope combinations. I’m using all Syren rope, great stuff. I’m also using my leftover actual wood Syren blocks, hopefully I have enough to finish.
    Nothing as exciting as the meditative peace achieved by the tying of clove hitch after clove hitch. Long ago I adopted the method of both using scaled grid templates (easily made with Excel) behind the shrouds each marked for every 10th and 5th lines. I tie the 10 marks first then the 5 then alternating the remainder in between. All finished off with watered down PVA brushed lightly over each knot.
    I sorta like the rigging process one minute and want to toss the whole model the next. It is a challenge to work in ever tighter space, especially at 1:64, keeping the run of the lines straight and not crossing each other incorrectly. Didn’t take any photos of the process, so here’s Flirt with the standing rigging complete, against the most basic of backdrops.
    As I’ve said earlier in this log and others,Vanguard makes a great model including this one. In my opining there is no better 1:64 model on the market than Vanguard, everything else is a distant second.
    Thanks for stoping by. Merry Christmas to all.
  3. On 2/7/2021 at 2:21 PM, Keithbrad80 said:
    Many experienced modelers will advise against the use of CA glue,
    Just for balance, many experienced modelers will recommend using it. It’s all about experience, practice, and the use of a quality product. I agree with James, those so against using it are old school, more power to them.
    I appreciate your effort testing it but as Greg noted I wonder if you were using an inferior grade (all CA is not the same), a thin viscosity, or both in your tests. If one is over applying it that much they probably shouldn’t use it.
    As others noted acetone, not isopropyl alcohol, releases the bond.
