Everything posted by glbarlow
Thanks. It is bittersweet for sure.
- 778 replies
- cheerful
- Syren Ship Model Company
I’m done. Post to follow in a few days on stancions and anchors, plus another after i take final photos. Meantime, mini-me takes a look around
- 778 replies
- cheerful
Just be sure your blocking doesn’t prevent you from centering the mast including it’s rake. I didn’t add anything because I know from experience I want a bit of play when it comes time to step the mast. You should consider painting those carriages red. They will stand out unpainted. But it’s your model. First hand experience is the best teacher.
- 114 replies
- Lady Nelson
- amati
That’s some nice looking planking.
- 274 replies
- Cheerful
Well done! Excellent photography as well. I now have my go to log when I build my barge.
- 185 replies
- queen anne barge
I’ve learned so much having built Cheerful since this log was done. Still some good information I think.
- 55 replies
- lady nelson
- victory models
The gun port pattern should near equal the first planking. Hold up a strip of that lime wood below it, it should be close. There is some room to sand them to match before the second planking, which covers both the pattern and the first planking. I hope you’re taking advantage of looking at several other build logs, there are many here on the forum.
- 114 replies
- Lady Nelson
- amati
I use black masking tape, not so thick and hard to shape card. Examples are on my Cheerful log
- 114 replies
- Lady Nelson
- amati
Really not a decision you have to re-bend them. Nothing will work otherwise. The Model IS representative of a British cutter, maybe not a named one, but it’s still a cutter. There’s not that much flexibility other than a name on the stern.
- 114 replies
- Lady Nelson
- amati
Come on back to your build. Let’s see how it’s going. 😀
- 26 replies
- First Build
- lady nelson
Thanks for the reference. I’ll follow along and offer what help I can. The log was originally done on another site, I copied it and posted here on MSW so the posts appear a bit long since I combined them. There are some nuances to LN, I recommend reading through a few logs to take advantage of what others learned. My biggest recommendation for any modeler is to learn Chucks plank bending technique. It’s a game changer and worth the time. The LN is a nice model to learn it on. Have fun and don’t be reluctant to ask for help. Every experience level is represented in this forum. I’ve not met one that wasn’t willin to help.
- 114 replies
- Lady Nelson
- amati
Figurines and ornate carving added to your already impressive list of skills. Adapting wildly different figures to convert to your vision is very impressive. This model will end up being quite the conversation starter when you’re finished. Amazing work BE!
- 185 replies
- queen anne barge
Looks like a very nice fit. Not to early to decide if you’re painting them black or leaving them natural. Both have been done. Getting the curve by the Wales is tricky, good job!
- 274 replies
- Cheerful
I posted this as a reply on Derek’s log about technique I discovered making rope coils (described in post #687 and shown above). I thought it might be helpful as additional information here. I made and rejected a lot, but in the end I think they look worthy of Cheerful. So here it is: A couple of nuances I did with my modified approach that might help: a. the loop is top side over bottom to start it, then continue that loop for a full 360 degree turn before putting over the pin on the coil jig, it’s easy to stop with the first loop but it doesn’t look as good. b. Pulling the top rope for tension (referring to post #687) is a bit of the art, not too tight, not too loose, before painting the clear acrylic. c. The smush after it’s dried is, for me anyway, what makes them more realistic. I even paint the inside of bottom the bottom loops of the finished coil with a little water so it’s not so stiff. d. The clear acrylic helps, it dries more natural than watered down glue), but it isn’t a true adhesive so the CA on the back side of the loop is essential in holding it all together. e. My jig has one size for cleats another for pin rails. The difference is the size of the loop and the length of the coil. It’s specific to 1:48 Cheerful, I’ll have to make a new one for a 1:64 model.
- 778 replies
- cheerful
Thanks for the reference 😁. A couple of nuances I did with my modified approach that might help: a. the loop is top side over bottom to start it, then continue that loop for a full 360 degree turn before putting over the pin on the coil jig, it’s easy to stop with the first loop but it doesn’t look as good. b. Pulling the top rope for tension (referring to my post #687) is a bit of the art, not too tight, not too loose, before painting the clear acrylic. c. The smush after it’s dried is, for me anyway, what makes them more realistic. I even paint the inside of bottom the bottom loops of the finished coil with a little water so it’s not so stiff. d. The clear acrylic helps, it dries more natural, but it isn’t an adhesive so the CA on the back side of the loop is essential in holding it all together. e. My jig has one size for cleats another for pin rails. The difference is the size of the loop and the length of the coil. It’s specific to 1:48 Cheerful, I’ll have to make a new one for a 1:64 model. I hope this helps. I made so many and rejected so many to get ones I liked. I’d make more probably if I hadn’t run out of rope. At some point my mini-me standing on the deck said ‘enough, move on. The detail in your rigging looks great by the way. Such detail and precision.
- 725 replies
- vanguard models
- speedy
I’m glad you’re enjoying the log and appreciate your comment. I’m not sure what I’m going to do when I finish it. It’s been a great year (when not much else was great about the year) building it.
- 778 replies
- cheerful
Thank you. I’m watching yours as well, I know it will turn out great.
- 778 replies
- cheerful
Thanks BE, I appreciate your saying so. I have enjoyed the rigging, it’s a different beast than the building as you well know.
- 778 replies
- cheerful
Thanks. I just need more rope to learn from. The bosun keeps tossing my failures into the bin. 😁😟
- 778 replies
- cheerful
Good point🤣 The coils took a lot of experimentation, and a lot of rope, to get better. I feel like I could still replace several of them, but I’m out of rope.
- 778 replies
- cheerful
