Everything posted by No Idea
Thanks mate 👍 Work on the deck continues - Having found the centre line of the beams I placed the templates on each beam to cut out all of the required notches. There's quite a lot of them to cut and I had to look through quite a lot of the plans to find the required sizes. I was cutting for the carlings, binding strakes, bowsprit partners, mast partner and pump partners too. Also some to the cuts follow the curve of the beam and some need to be cut vertically. There was one dimension that I just couldn't find and a quick email to Gerard Delacroix gave me the place to look - Thanks Gerard So lots of cutting which I mainly did on the mill using a 1mm twin flute end mill and then squared out all of the corners with a chisel Once that job was done it was a pretty simple job to make the carlings for the hatches - I was just trying to get the tightest fit that I could. I now need to make and fit the 8 half beams that fit along side the hatches and mast partner. So I guess I'm going to have to make the mast partner too. I think this will take quite a while so I'll update you once I get somewhere with it. Thanks for all of the encouragement Cheers Mark
Hi ya Jason - I use a spindle sander to make the concave profiles with the biggest cylinder for such a gentle curve. Its my most least liked machine if I'm honest - it vibrates - its loud - its just not a great machine to use. I've been asking Jim Bynes for ages to make a decent spindle sander for ship builders for ages (I never miss an opportunity to say it again) and I hope that he does one day 🤣 Its not challenging to do just not one of those jobs you look forward too - Oh but I should have said its a very easy profile to achieve 👍
Thanks Brian 👍 Cheers Vladimir Thanks HH its starting to come together now! I've now done some more work on the forward beams. It's exactly the same principle as before. Here are the beams cut to length and carved. And cut into the deck clamp making sure that they are sitting at the correct height. Just like the stern; at the stem the beams must line up with the breast hook which was fitted over a year ago! A couple more pictures So my next job is to mark the centre line of the beams and then mark out and cut all of the notches for the carlings and hatches. Cheers Mark
If you want the best it really is a matter of opinion and the users experience of how the saws they have used in the past perform. In my opinion I now use a jewellers saw as it does everything that I need. It can hold so many different types of blades (which break often) that its use for me is pretty much limitless. The blades can be installed as push or pull and turned to suit the cut as well. This is the one that I use but it ain't cheap and before this I used many saws which were adequate but never as good as this one. However as has been said a really good knife is essential and can actually quite often do the job of a saw. Your choice is huge and dependant on your budget. I originally started with the cheapest blades and saws that money can buy and they have got me to where I am today. https://www.knewconcepts.com/MK4-saws.php
Welcome to MSW from the Black Country
Thanks Mic_Nao the wood is Castello and its very nice to work with Thanks Albert 👍 Hi Paul - No problem mate I think it's really important to show how we try to make these parts. It took me a few weeks to decide how I was going to tackle this joint and in the end it was quite easy once started. Thanks B-Ram 👍
Well at last I've finally had some time to do a little on my ship. So I've started making the rest of the main beams and this is another very wood hungry job. In fact I was really surprised just how much wood these parts use. Firstly I cut them out and sanded them all to their curved shape. I have decided to do the stern beams first and this is where I found a bit of a discrepancy in my build. The wing transom also acts as the last beam and I found that it sits 1mm too high. I'm not surprised to be honest as this was one of the first jobs I did when starting this build. I didn't realise at the time how much photocopies of plans can be out and also looking back I didn't check my measurements often enough........so I'll take the 1mm as a bit of a win. What it did mean though was I had to gently increase the hight of the beams towards the stern. Not a problem to do so thats what I did. I also had to cut out the dovetails for the waterway and spirketting into each beam which is a job that I was unsure of how to do accurately. I considered using the mill but in the end I decided to cut them by hand as this is a skill that do need to improve. So here's how I did it. Firstly I glued the templated onto the top of the beams and then marked the depth of the dovetails which in my case is 2mm Next using a blade I cut the square ends of each joint to the required depth Then I cut the deepest point of the dovetail which is basically stabbing the blade in and then scored the 2mm depth line along its full length. It was only after doing these cuts that I attempted the diagonal cuts. I found that I had to be very delicate with this cut as its so easy to split the wood. Then I cleaned the joint up by using a chisel And the final result looked like this - I was quite surprised just how nicely they turned out. Its one of those jobs where its just better not to think about it too much and just get on with it. So I'm halfway there now and these beams seem to make the hull look much more solid. And yep it all lines up with the wing transom.......it's just a little high 🤣 So I'll now make a start on the forward beams 👍 I've not yet cut any of the rebates for the hatches and carlings because I want to fire a line straight down the middle using thread once all of the beams are in. That will give me a really good datum to keep things nice and straight. Cheers Mark
Hi Nersch and thanks for you kind comments. To answer your question in my experience Castello is only slightly harder than pear and they are very similar to work with too. They both hold a very good edge so the choice for me is really about your personal preference in regard to colour. Both are fantastic woods for model ships. Hi Adrian thanks for dropping by and your comments are very welcome. Gerard also pointed out my error but thanks for the photo of your barrels. I follow your book very closely and it has guided me through this build so far. I have a lot to learn about building ships! I still haven't had any time to work on Le Rochefort but hopefully work will resume very shortly Mark
Hi Dave - if you are getting bleed you may not be using archival ink pens which are better than normal markers. I use this one https://www.amazon.co.uk/Sakura-Pigma-Graphic-Chisel-Black/dp/B004CSFQ96/ref=sr_1_43?crid=2PMTZ7TRGZFG6&keywords=sakura+chisel+tip+archival+pens&qid=1680449848&sprefix=sakura+chisel+tip+archival+pens%2Caps%2C128&sr=8-43 Apologies if this is the kind of thing you are already using - Mark
Hi Chuck I don't think you will need to worry about the price of your amazing kit. I would guess that so far my scratch build of Le Rochefort has cost me about £400 in just wood to get where I am and it's no where near finished. This does not include any tooling or consumables which would put a price on that I don't want to think about. The finished kit will cost what it does and I believe that the final builders will get a great kit at a price which will be a whole lot cheaper and more accurate to build than a scratch built ship. Fantastic work and if I wasn't building my ship I would build this one.
Hi Dave I use these pens and they do not react to shellac at all so you will be safe there 👍 Your rabbet that you have cut though towards the stern follows the line which is more like the bearding line which would be a little lower. Your rabbet needs to go all of the way to the stern post which also tapers the deadwood and will go the full length of the garboard plank. It's a simple correction and I have to say what great work you are doing on your build!
Hi Mate If you're building this as an RC ship plywood will be fine for your bulkheads. Any ply will do as you will need to give it a good coat of epoxy resin or fibreglass inside to keep it water proof. The reason being water will get inside when you sail it. As for the planking thats entirely up to you - You are going to have to coat it with resin and cloth on the outside so you are right you do not need anything expensive at all. What you really need is space inside to get the motors, esc, receiver and batteries in which do take up a lot of space. So make the bulkheads as narrow as possible to give you the room that you need. Here's picture of my Anteo's frame to give you some idea. Its hollowed out and rienforced to give space to get a boiler in. The same frame after double planking with Castello and mahogany. You will just need to use any wood as you will be painting it for a finish. Good luck - Mark
This is my timber supplier - honestly they know their product and I always tell them I'm a model ship builder. Although it's not cheap they have never sent me anything other than perfect wood for what I do. I cannot recommend this supplier enough.
Hi - I've not really had anytime lately to get much done on Le Rochefort. Hopefully things will ease off soon and give me a little more time. I have now finished the nailing on the hold deck I've also finished making Chuck's barrels and they are now stacked in place. I must mention though that they are historically incorrect as French powder barrels should be circled in chestnut. For some reason though I really like the copper - and its my ship so I left them as they are. Plundered from a captured English ship! Cheers Mark
A great start and very good luck with your build! I'll be following along and look forward to your updates.
- 18 replies
Welcome to the forum mate - I'm only down the M6 from you living in Dudley 😀
