Posts posted by druxey
All part of the learning curve! Things look good, though.
In the old days you had to be either short or tall - nothing between! Three stretcher positions are a positive luxury.
- mtaylor, thibaultron and dafi
- 3
Great progress, Sal. Nice solution to making and installing the stay tackle. I'd caution you about using CA on rigging, though. Eventually it make the lines brittle and they will fail. Use either PVA (white glue) or acrylic matt medium.
- _SalD_, bobandlucy and Canute
- 2
- 1
Well done! Not only have you gained valuable experience, but three very nice models as well. At some point you might wish to protect your models from dust and inquisitive fingers with cases.
Lovely work, as always. I note the issue of the sides aft spreading a little (post #1102). I have had this problem with framed models as well. In one case I had to install three threaded rods permanently across under the poop deck level with the beams, the nuts concealed under the outer planking and friezes.
Best wishes for the holiday season to yourself and the ship's cat!
- bruce d, Hubac's Historian, mtaylor and 3 others
- 6
While rigging, you can fine-tune the rake (if any) and plumb of the masts.
- allanyed, HardeeHarHar, mtaylor and 1 other
- 4
The problem is that the rig of a New Testament era Alexandrian grain ship was very different from an 18th century man of war! A semi-swamped boat, even a small one, would have considerable weight. How this was wrestled aboard (in a storm, yet!) would be hard to imagine. An attempt lower it, once bailed, can be imagined with a pair of lines, presumably with some kind of block and tackle that were then cut away.
- mtaylor, Gregory, thibaultron and 2 others
- 5
Make sure that the garboards just overlap the bottom.
Welcome aboard, Tyler. You will find plenty of resources on this site. There are tutorials on planking, for instance. (More > Planking techniques) Check out other build logs and then start one of your own.
- JeffT, Keith Black and mtaylor
- 3
Scale rose lashings! Whatever next? Amazing.
- Keith Black, Jack12477, davyboy and 4 others
- 7
"Unbleached titanium" is simply a marketing name. It was first produced accidentally. A batch of titanium white was slightly contaminated with yellow ochre. Rather than throw it all out, the colorist simply labelled it 'unbeached' and it sold well! So it is now regularly available.
- wefalck, allanyed, Chuck Seiler and 5 others
- 8
!!!!! is the only comment I can make to those photos. A builder's style model at that scale today is most unusual.
- mtaylor and cajunrandy214
- 2
Yes, those are for the stretchers, as Chuck has said. The double set of wiggly lines are a carriages for a small set of steps which presumably turn slightly.
- thibaultron, bruce d, mtaylor and 2 others
- 5
HMS Bellerophon 1786 by AON – scale 1:64 – 74-gun 3rd Rate Man of War - Arrogant-Class
Nice, Alan! And a merry Christmas to you also.
