Everything posted by druxey
Perhaps we can advise you better if you can post some photos of their condition to begin with.
- 8 replies
- santa maria
- restoration by a novice
- (and 4 more)
Barque? Schooner? Why not a Scuaque (as in The Hunting of the Snark)?
Nice to see you back in the saddle after your move, Bill! Looking forward to seeing further progress soon.
- 382 replies
- sovereign of the seas
- carving
Vossie: we say 'Mole grips', you say '"Vise grips'. Two countries separated by a common language!
Loved your poem on the Planker's Lament! Here is a response, Keith: It takes a while to figure out That you will need to spile. A plank can only bend so far But not the second mile. It will bend and twist all right But edge bends just a bit, Then it's time to spile that plank So that the thing will fit.
Is it a case of "Do as I say, but not as I do."?
- 740 replies
- Tudor
- restoration
(and 4 more)
If you are worried about the joints showing, there's always automotive putty.... We'll never tell!
- 740 replies
- Tudor
- restoration
(and 4 more)
Impeccable work as usual, Amalio!
Masking the funnels for painting must have been interesting! The finished result looks far superior to the brass rod stealth versions.
- 238 replies
- leviathan
- troop ship
Creating Brass Blister Detail
druxey replied to P_Budzik's topic in Metal Work, Soldering and Metal Fittings
Well done, both Paul and Wefalck, for demonstrating the application of machining techniques to complex shapes. -
Thought: would producing spars to four- or eight-square shape by machine be a practical proposition? It is then easy for the modeler to round off eight-square spars using strips of sandpaper. The spar is held in a vise and the sandpaper 'sawed' back and forth, rotating the spar every few strokes. No lathe or electric drill required!
ancre Le Gros Ventre by ChrisLBren - 1/36
druxey replied to ChrisLBren's topic in - Build logs for subjects built 1751 - 1800
Good for you to be willing to go up the learning curve, Chris. There will be scrap (with and without the 'c'!), but the end result will be well worth it.
