Everything posted by druxey
Slight digression on the alignment of slot screwheads: When I was young my father, who was a mechanical and electrical engineer, taught me to always align screw heads on wall switch plates vertically. The reason? Vertical slots gather less dust than horizontal ones!
- 2,207 replies
Now that stay won't carry away in gale! Looks much better, Rob.
- 1,208 replies
- great republic
- clipper
Also, make sure that the model is secure on its base and the base is secured to the bottom of the protective case. The best thing to protect the model inside is air space, not foam or bubble wrap! (You might need foam wedges underneath the hull to prevent sideways movement.) And don't forget to prominently label the case Fragile! This Way Up!
Availability of DMC Cabella Cotton for Rope Making
druxey replied to tlevine's topic in Masting, rigging and sails
You were just looking for an excuse, weren't you, Toni? -
Looking very nice indeed. I like the subliminal advertising for Jim Byrnes in the background!
Incredible, Doris. But you cheated with wooden trunnions. However, we forgive you!
- 1,035 replies
- royal katherine
- ship of the line
I'd hate to tangle with you, wielding that long-handled axe, Steven. I presume you use that for your carved work?
Hello! Question About Rehoming a Ship
druxey replied to Charlie B's topic in New member Introductions
I think Chris has summarized the situation well. There are many such models in existence. Also, sorry that the information is not more encouraging. -
You are more or less correct, Kevin. Fixed blocks had 'ears' the thickness of the inner planking. These were wide enough to take bolts. These bolts could be withdrawn and the block pulled inboard for repair.
- 1,082 replies
Lovely progress, Cathead. The background bottles appear to be getting up a small head of 'steam'!
- 599 replies
- sidewheeler
- arabia
(and 4 more)
I find that the work does not 'catch' if the feed rate is kept down, the oscillating rate not too slow, and one exerts a downward pressure (with the hold-down removed). A new blade from time to time also helps!
The model that appeals to you the most!
Just found this thread. The quantity and quality of carved work on the gondola is amazing. Congratulations, Merchen. Wunderbar! Perhaps you would get more responses if you posted the pictures under the subject 'scratch built models' rather than 'organization of wood'.
