druxey
Everything posted by druxey
  1. Seems like Greg the vet is trolling for your business....
  2. But...if the boat does not turn around, won't you need to swap port and starboard nav light colors every half trip?
  3. Whoever carved Queen Anne gave her an orb the size of a football! No wonder she doesn't look happy.
  4. I'm sure shellac would work, but why use nasty flammable solvent-based products if it's not necessary?
  5. Stepping on the lower deck of the mizen mast appears to have started very late in the 18th century: perhaps not as early as 1770. Looking at contemporary draughts of Endeavour, (online at RMG Collections) although the mast steps are omitted in the profile drawings, the distance apart of the lower deck beams aft suggest that the mizen step is on the keelson, not the lower deck. Looking at the replica Endeavour may not be helpful (unless you are building a model of it!), as many modifications were made to meet modern safety standards.
  6. Thank you for my morning smile, Ed. I love the little adjustable jig!
  7. Usually there was a small eyebolt (called a sprig) in the end of the gaff with a small single block attached. The halliard, as mentioned above, was continuous. It might belay to a small cleat or eyebolt aft.
  8. It certainly can be interesting figuring out the lead of lines until nothing fouls anything else. A belaying plan from Grice would have been nice, wouldn't it? I can see you are having fun, Maury!
  9. I have used professional museum and art object movers in the past. They are bonded and insured and are used to packing, crating and moving delicate items. However, they are not cheap.
  10. Beautifully executed, Karl.
  11. I knew that your hull planking was individually laid with self-adhesive foil, but not the decks as well. Impressive!
  12. Questions, questions - always more questions! I agree that those slides would have been ideal to hold the lower halfport/washboard. With gravity, there would be no need to hinge them. I still feel that a ready source of splinters would have been stowed away when clearing for action. The upper halves must have been detachable.
  13. I get it. Fortunately, my wife has a dread of sharp-edged or noisy tools.
  14. I didn't realize that the decks are individually laid strips. Beautifully done.
  15. Surely the half-ports, if fitted, would have been removed and stowed away for combat?
  16. I hate to criticize a lovely job but, to my eye, the run of plank into the bow rabbet looks a little steep. Is the top of the main wale at the correct height or a little too high? If it's not exactly right (as I discovered from personal experience) the headwork will not sit correctly at the bow. Hopefully it's just due to camera angle or distortion.
  17. The Wylie painting is 20th century, so he may have been mistaken in showing half-lids to the ports. The lid thickness in the painting is suspect as well! However, the image is full of atmosphere and activity.
