Everything posted by druxey
Terry: that is an excellent photo of the capstan. It should be easy to develop scale drawings from this if plans are not available. Assume the shorter man is about 5' 5" and the taller one 6' 2" and go from there.
- 21 replies
- capstan
- hand windlass
(and 3 more)
Interesting supposition, Mark, and quite plausible. That structure - whatever it is - is represented fairly consistently in the images that have been posted.
Looks like you have spiling down well, Hakan! It's hard to tell from your photos, but are you fitting the plank ends to change from clinker to flush at the stem and stern? If not, you have to make a small rolling bevel on the planks until they fit flush into the rabbet.
I believe that scarphs in 'hook and butt' were formed as your sketch number 3. The Tiger's draughts seem to show a single, broad wale rather than the earlier style of three strakes, two of which were thicker and black. It would be reasonable to assume that the earliest 'broad' style wales were laid as three parallel ones, rather than top and butt or anchor stock.
Had you considered tapering using hand tools (fine rasps, sandpaper) only?
I don't normally follow kit build threads, but your work on this card model is amazing, Dan!
Atlantis by Thistle17 - FINISHED - Robbe
druxey replied to Thistle17's topic in RC Kits & Scratch building
Just catching up on your disasters and triumphs, Joe. Kudos for sticking with it despite setbacks. Your model is looking great. -
Thanks for adding the coin to give us a better idea of the size of your model, Dan. Nice observation (and recovery!) on the monkey deck: the model looks like the photos now. It always makes one wonder about 'design' vs 'as built' plans!
- 287 replies
- michelangelo
- ocean liner
Congratulations, Blue Ensign, on a lovely result. You have done a really fine job on your Peggy!
- 366 replies
- pegasus
- victory models
Another possibility is Volume IV, The Fully Framed Model. The rigging is identical in type and size to that on Cook's ships.
A lathe for masts and spars
druxey replied to Don Quixote's topic in Modeling tools and Workshop Equipment
A lathe is really a sledgehammer to crack a nut. I agree that there are many other ways of 'turning' spars. That's what the old-timers did in the shipyard! They planed or adzed a spar to a square cross-section first, then eight sided and finally rounded off the parts of the mast that were intended to be round. I use a simple 45 degree 'V' shaped jig to hold the squared spar in order to make it eight-square. Holding the spar in a vise, I use sandpaper strips to round things off, section by section. Advantages? You are not limited to any length and you've saved a ton of money. Of course, if you are planning on doing a lot of turning and machining, then go for a good lathe.
