Everything posted by druxey
The stay collar should loop around behind the gang of shrouds rather than over them. As the stay tightens, the shrouds will be cinched in slightly. As Chuck says, avoid that strap!
- 452 replies
- cheerful
- Syren Ship Model Company
Nice to see you back with progress, E&T. Lovely work as usual.
- 346 replies
- terror
- polar exploration
I doubt we would have spotted the flaws if you hadn't circled them!
- 184 replies
- ruby & arthur reed
- lifeboat
That's a lot of add-ons required for a top of this era! Beautiful as usual, Ed.
- 3,618 replies
- young america
- clipper
HMS Naiad 1797 by albert - FINISHED - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Lovely work as always, Albert. -
Very impressive and crisp detail, bobo!
- 184 replies
- lifeboat
Wait a minute, Maurys: the original Grice drawing shows a plugstock rudder. The center of rotation is such that the round c/s rudderhead passes through a circular hole in the counter!
- 525 replies
- anchor hoy
- hoy
That rudder only needs about 15 degrees each way: more helm than that and you have a brake!
- 525 replies
- anchor hoy
- hoy
I suggested the centerpunch for consistency of 'strike'.
- 3,618 replies
- young america
- clipper
I don't know whether this will work at your scale, but I cut short lengths of tube, just a little wider than the thickness of the thimble, and flare each end with a centerpunch (light spring setting!) on a steel surface.
- 3,618 replies
- young america
- clipper
The railing is looking very good. You are best likely to match paint colors under good daylight if you can.
- 749 replies
- albertic
- ocean liner
No forgiveness required, Michael. In the color photo of Atalanta posted above you will see the black timberheads (for hitching lines to) below the roughtree rail. This was common before belaying racks and pins were more universally adopted. This was necessitated by the closed in and built up bulwarks.
- 1,449 replies
Michael: those protruding timbers are formed into timberheads. I suspect that on the port side Toni will add these as separate items.
- 1,449 replies
But do it you did, and very neatly, Mike. Nice!
- 452 replies
- cheerful
Congratulations, Gaetan! That is one magnificent model. The puzzle pieces fit perfectly. Now please protect her in a case.
- 728 replies
- le fleuron
- 64 gun
