Everything posted by druxey
Poor results with carpenters glue
druxey replied to a topic in Modeling tools and Workshop Equipment
Neither white or yellow glues take happily to freezing, unfortunately. It's rotten luck if you happened to get a bad bottle. -
Coming along nicely, Maury! That cat davit is massive. Michael: just because da Vinci drew it, means the idea probably didn't catch on for a few more centuries. Look at his flying machines....
- 525 replies
- anchor hoy
- hoy
Roger: this begs the question of when ball bearings and races were first introduced. Do you have a date for this?
- 525 replies
- anchor hoy
- hoy
Nice stove and delightful cap! I envy you having CNC milling available to make those skylight frames.
'Slush' i.e. tallow was probably used for lubrication, not oil. Bearings were generally pretty simple. I imagine the spindle or shaft end would simply ride in a cast iron cup. 18th century capstans were done this way.
- 525 replies
- anchor hoy
- hoy
Whew! Building that capstan is quite the saga! Well done, Frank.
- 649 replies
- dunbrody
- famine ship
Are you pre-bending your planks, or are they simply sprung into place? You really need to pre-shape them using heat and/or moisture. -
Nice to see a bit more progress, Michael!
- 749 replies
- albertic
- ocean liner
A Lorch Micro-Mill that never was ...
druxey replied to wefalck's topic in Modeling tools and Workshop Equipment
Love your attention to detail such as 'improving' the large washer! That is a beautiful as well as practical machine you have there. -
Definitely check out a planking tutorial or two. Try David Antscherl's version and see if that computes for you.
To clarify Allan's sketches: the pin of the pintle is set in line with the forward edge of the rudder and the strap inset, so that the fore edge is a straight uninterrupted line. The fore edge is also bevelled off to each side (not shown) so that the rudder can rotate against the stern post. The idea is to eliminate any gap between rudder and post.
Also, the surfaces should be slightly porous. If sealed (with some type of finish, for instance), then adhesion will be an issue. -
Ouch! High tech has its limitations. Sorry to read of the malfunction. Hope you are soon back up and running again.
If it's a short length of tube, the wire will capture it and prevent the piece from flying off into the 5th dimension.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Lovely work there. That was a lucky fix with the spreader!
- 1,051 replies
- cheerful
Maybe the lift needs adjusting; the end of the boom looks a bit low right now. Very neat rigging work though!
- 452 replies
- cheerful
Very nice progress, E&T. Good to see you back again.
- 346 replies
- terror
- polar exploration
I applaud your optimism, Dave! If I were choosing, Winchelsea would be my hands-down favorite.
- 1,051 replies
- cheerful
I understand what you are saying Sawdust Dave. However, one can hedge one's bets by building a cutter rather than a 74 when one is 74!
- 1,051 replies
- cheerful
Both are of SilkSpan, Allan. The tasselled fringe is of treated canvas. The canopy is not shown on the lines drawing, but I found an oil painted elevation showing this, the color scheme and ensign on the Royal Museums Greenwich web site. (BHC 1117)
- 9 replies
- greenwich hospital barge
- royal barge
