druxey
Everything posted by druxey
  1. Well done, Daria (and Dad)! That is going to be very impressive. I'm looking forward to your progress.
  2. Whether manually drafting or on computer, never completely trust anyone else's draughts! There is always at least some re-fairing required, I've found. That example thlbaultron has posted is not that unusual. A proof diagonal is an excellent way to check fairness.
  3. Chuck: Heat may make the glue release on planking (and other structural components) already in place. That would be a more likely risk than damaging wood. Of course, it's an alternative method of un-glueing joints without isopropanol....
  4. I didn't know that holly is very expensive in Europe. That's unfortunate. By the way, I've been using shoe dye (alcohol based) which seems to have good penetration. Wood dye doesn't work so well (for me, at any rate).
  5. I've had generally good luck dyeing holly black. Seems to accept the dye well. Try that and compare the results with the pear.
  6. Good to see you back, Glenn. Hope you are feeling A1 again. Nice to see your update as well. Too bad that lovely decking will all be covered.
  7. Coming along there! Hopefully everything aligns as it should.
  8. Terrific result, Montanes. But how did you get the first piece of the plug out of the model?
  9. Just looking in as I do from time to time, Kevin. The modified Proxxon heads will do a very nice job. Hope you get a small royalty on each one sold! You seem to be making good progress on Thorn. Good stuff!
  10. Brilliant, Michael! Looks like a must-have. I simply have to persuade the Admiral....
  11. Hopefully equanimity and peace will return to your studio after lunch, Michael. I trust that the cat was not too traumatized. Several light passes with the airbrush rather than a heavy coat will help, methinks!
  12. The use of shellac to both seal the mast and secure the bands is a stroke of genius, Ed!
  13. Yes, Erik, druxey is hidden rot, or, if you will, 'rotten to the core'!
  14. Sorry, Mike: it's a legitimate nautical word! Just a fancy term for dragging the gun around to point forward, in this case. 'Dragged' isn't as rafeened, is it?
  15. If those guns were used as bow chasers, they would be slewed round a bit and thus give tad more space for recoil! Lovely clean work as usual, Mike.
  16. I couldn't tell from the photo that there is a nice patina you wish to preserve, Michael. Now I understand why you are choosing the masking route.
  17. Perhaps the other possibility is to spray the whole funnel, then gently scrape the paint off the bands later?
  18. Try SilkSpan.
  19. The sea and sky are not as defined as in a Dawson painting. It's a pleasing piece, though.
  20. The forecastle looks very plausible. Nice reconstruction of it, Dick.
  21. So that's why there's a world shortage of thumbtacks! Well done.
