Everything posted by druxey
Interesting idea for making blocks, but the grain of the wood runs the wrong way. They may fall apart, especially in smaller sizes. You can slip the tube back on the dowel before cutting the rings, you know!
Lovely work, Gaetan! That grotesque carving must have been fun.
- 728 replies
- le fleuron
- 64 gun
I agree, Dan; the visual contrast 'jumped' too much with version 1. That looks much happier.
That things match the contemporary planking expansion must give you a warm feeling! Good stuff, Chuck.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Thanks for the photos, Tadeusz. However, Victory has been re-furbished many, many times over the years and very little "original manufacturers' equipment" remains in her. Jylland is of a later time period and country and Batavia is also a modern re-creation. Your Admiral is lovely, though! Mark: I agree with your latest assessment. However, I don't have either a theory or an answer to your final question at the moment.
That is a terrific model and setting! I really enjoyed the sociological and sartorial history that you provided as well, Wefalk. Thank you.
Many folk make mast hoops by taking a rod of the right diameter and waxing it. Then they take planed wood shavings, coat them in glue and wrap them around the rod until the desired thickness is achieved. After the tube of wood is dry, suitable width pieces are sliced off.
The black stripe
druxey replied to SaturnV's topic in Building, Framing, Planking and plating a ships hull and deck
I agree with Russ. However, sometimes the first strake of planking above the wales was also painted black, the 'black strake'. -
Looking very nice indeed, Toni. I bet you are glad only one side is planked!
- 1,449 replies
Mark: thank you for your latest comments. I don't think the 'tall' pumps were intended to be worked by crews on both levels. The arrangement was merely to place the team on one set of pumps on the lower deck, the other on the middle deck. As the shafts of the brake pumps were almost in alignment, both sets could not be worked simultaneously at the same level.
Some Castello needs a neutralizing color in the mix to 'bring it down' in chroma (color) to match. A tiny amount of green or blue does the trick when you need it. Looks very good, Maury!
I agree that the fore octagonal (discontinuous) chambers on the Queen model's middle deck are simply guides for the chains to the wheel and cranks at that level. There is no intention of lifting water to discharge at middle deck level. The long octagonal tubes to the middle deck are the brake pump tubes. The above confirms the thesis that this arrangement of chain pumps increases manpower on them when required. QED!
Try mixing yellow ochre (oxide), a tiny amount of orange, and a small amount of titanium white or 'unbleached' titanium white to get the correct tone to match your wood.
