druxey
Everything posted by druxey
  1. For technical information and plans from the surveyed wreck, the book you might consider is Mary Rose, Your Noblest Shippe edited by Peter Marsden. It comes in a slip covered set: one book and a folio of plans.
  2. Nicely adapted from Ionic capital geometric construction, Mark. Now let's see it translated into 3D reality!
  3. Ed; you wrote: "I made the deck hook in two pieces to save on wood and was not too particular about the way the pieces are joined since this will all be covered by decking and the forecastle." Your 'not too particular' is other folks' excellence!
  4. Well done. The lofting was obviously correct and your workmanship excellent, Juergen!
  5. Tartarus was one of the Thais class of fireship, built to the same lines as Comet, but far less decorated. Wasp was lucky, as Tartarus and her sister ships were very fast.
  6. Guess you wanted your model to have room to breathe, Toni! You probably left the fillers out because the spacers were in your way.
  7. The edge should be sharp enough to act as a scraper. It would be difficult to put an even burr on a tiny profile. If the scraper does get dull, hone the flat sides of it to restore the edges.
  8. For small shapes, use escapement files (watchmakers' supplies or eBay). A piece of old hacksaw blade, softened by heating to cherry red and air cooled, makes an excellent and durable scraper. Light cuts with little pressure to gradually form the moulding are best: heavy cuts will tend to wander.
  9. 1) Mahogany is not the best choice of wood for bending to the curves required on models. 2) Ammonia is unpleasant and, as many have already suggested, not the best choice or, in fact, any choice. So, choose a specie of wood that will readily bend with either hot water or steam (or a temperature controlled hot iron). Then all will be happiness.
  10. 'Birnbaum' is literally 'pear tree', i.e. pear wood.
  11. Thursday evening at the hotel bar? What time, Clare?
  12. Looks pretty darn good to me, Jason! Well done.
  13. For stable wood that is unlikely to warp, Castello or degame would be my first choices.
  14. I don't know the definitive answer to your question. However, the lower plan is a little suspect as reef points came in about the end of the 17th century. I'd go with Van de Velde: he was around at the time! His lateen mizens are definitely triangular. Bonnets went out of fashion as reefing came in.
  15. This continues to be very impressive work, Karl!
  16. Those blind mortises look very tricky! Nicely done, Tadheus.
  17. Please, please don't use power tools when tired or distracted! I'm glad that the damage was only minor, Jason.
  18. According to Lyon, The Sailing Navy List, Licorne was initially armed with 26 12-pounders on the upper deck. These were reduced to 9-pounders on 2.11. 1778. This would imply that the forward port was used. Possibly the gun carriages here would need modification to fit a cannon.
  19. A 'small' (narrow) port forward was probably a bridle port, used for anchor handling rather than armament.
  20. I've card maquettes of Bristol Board and illustration board that are still fine after decades. They were assembled using white glue, sprayed with grey automotive primer and then painted with acrylics. I think that, as Ed points out, excluding air and direct light helps longevity.
  21. Yup, once you've spiled planking the proper way, you'll never go back to the frustration of trying to edge-bend, curve and twist a piece of wood again! Looking very good so far, Rusty.
  22. Use the new toys in good health, Michael!
  23. One can treenail a model subtly. It depends on the diameter of the material used and the specie. However, at any scale below 1:48 it would be very difficult to carry out subtly enough!
  24. Your question is an interesting one. Tony. I've never seen any reference to whether the lining was omitted from the hinged side of a sweep port. If the port was on a weather deck, I doubt if a lid would have been fitted. This needs further investigation, but my hunch would be that all sides of the port would have had thin linings.
