druxey
Everything posted by druxey
  1. A very informative discussion of actually seeing what Steel describes carried out in detail! Thank you, Sizzolo and Trevor. By the way, I found applying the line over the buoy rope at 1:48 a real challenge. Your example is beautifully done.
  2. Well done so far! Triangular ringbolts? Yes, they are tricky. I cut a hardwood stick to the inside dimensions and drill a small hole through. One end of the wire, well annealed, is inserted in the drilled hole and the wire wrapped tightly around the stick. The assembly is then held securely in a soft jawed vise. (I use disposable pieces of illustration board, rubber cemented in place.) The rings are parted off using a fine jewelers' saw blade. The tiny gap in each rig is closed up and optionally soldered.
  3. The other big difference between a bullseye and heart is that the heart has grooves in it to accept the turns of the laniard so that the crushing effect Trevor mentioned is eliminated.
  4. Just found your log, Willi. A lovely job on a challenging subject.
  5. Actually, the rudder should sit a little high; if the ship takes ground, the rudder won't get torn off.
  6. Those tilted Corinthian capitals are exceptional! Well done.
  7. I anneal brass tube, cut off slices and put them in a thickness jig to file both cut edges flat. I then place the ring on a steel block and flare both sides using a centerpunch.
  8. Please read the pinned planking topics on this site! It will explain everything you need to know about planking a hull. https://thenrg.org/resource/articles Scroll down to Chuck Passaro's and David Antscherl's articles.
  9. Thank you, Bruce. With a little practice, one can get the consistency of paint right (rather like airbrushing!) and a ruling or bow pen will lay down a consistent line. I can see the advantage of the striping pen, except that you are limited to white and yellow.
  10. How does a road striping pen differ from a bow pen, Bruce?
  11. Chuck; you make a very good point that has otherwise bothered me; the output looks too perfect! For figures such as the captain above, it's great, but for carved work on a ship, the surface lacks the markings of actual tools. Your concept of hand carving the output before hardening addresses this issue.
  12. For a chewed mole, he looks very good! Well done. (We are always our own worst critic.)
  13. Is this water-based paint? Wait until the moisture has completely evaporated and see if the planks sit down again. Then reglue from the inside. (I assume this is still accessible.)
